BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Brakes and rotors replaced multiple times and still squeak in the front
proTUNING Freaks
      05-04-2024, 01:30 AM   #1
F30guy
Drives: BMW 430i Convertible
I have a 2018 430i convertible and I've replaced the front brakes and rotors twice at pep boys and they still continued to make noise so I got my money back.
Went to firestone and they lubricated it and it was good for a week or so. I had them replace the brakes and rotors. Made noise after 2 weeks. Then they replaced them again and told me they used higher quality parts this time.
About 3 weeks in and its squeaking again. I'm lost on what to do other than go to BMW which is going to charge an arm and a leg.
      05-04-2024, 09:09 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Squeaking comes from metal to metal contact. Proper lubrication prevents that. You either have to find a good brake mechanic or learn how to do it yourself. The good news is that brakes are about the easiest items to DIY. Youtube it.
      05-04-2024, 09:36 AM   #3
Mkesler75
Drives: BMW f34
It would be helpful to know when they squeak, what brake kit, pads and rotors you have.
      05-04-2024, 10:42 AM   #4
Shred Sled
Drives: 2016 BMW 328ixDrive Touring
If the brake pads are not already chamfered out of the box, that could be an option to ask the shop to try.
Chamfering not only the leading and trailing edge of the brake pads, but also the top and bottom edges. Trying the eliminate any 90 degree edge.
Not exactly the same thing, but I’ve thought of it as how one might “de-tune” the edges of their snowboard or skis near the tip and tail, so that the edge does not “catch” as too easily. You’d typically “dull” 1” of the edges at the tip and tail.
On the brake pads, the 90 degree edges could possibly be a contributing factor to brake squeal as it makes contact with the rotor/disc when braking.
      05-04-2024, 11:41 AM   #5
mbanks21
mbanks21's Avatar
1276
Drives: 2015 335i MSport
Would be nice to know what brand rotors and pads if you want good answers
      05-04-2024, 08:01 PM   #6
cfm56d7b
F30guy, echoing the same.
Please share the details including
- What brake pads and rotors were installed prior to being replaced by "higher quality" parts
brakes, noise, squeaky brake noise
