BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > PSdZData Full vs. Lite
      03-14-2019, 08:49 AM   #793
shawnsheridan
shawnsheridan's Avatar
Originally Posted by FrederikD View Post
Can I get a link for the Lite data please?
I have the 3.27.1.
PM sent.
      05-20-2019, 03:36 PM   #794
ggggbmw
Drives: 2017 M2 Manual
Could I please get a link to the Lite version of the psdzdata?
Trying to get ISTA+ 4.15.32 working, and it's apparently missing the psdz/sdp info, and then erroring out after scanning the car. Only need lite for running diagnostics only.
      05-20-2019, 03:54 PM   #795
shawnsheridan
PM sent.
ggggbmw432.50
      05-23-2019, 03:36 AM   #796
kamilm
Poland
Drives: BMW F30 328I
Hello
Can I have a link to the full data?
Thank You!
      05-23-2019, 04:41 AM   #797
atzebmw
Drives: Tesla Model 3
Originally Posted by kamilm View Post
Hello
Thank You!
https://mega.nz/#!pO4n2Kia!-f7z2JtOvqs9VWuNGPQ2GeR5EQdIjb0KIH4mxf_HDvw
      05-23-2019, 07:15 AM   #798
shawnsheridan
Hello
Thank You!
PM sent.
      05-23-2019, 02:54 PM   #799
ferbmw
Drives: BMW 330i G20 2019 Sportline
Hi, may I get the link for the newest Psdzdata full? Thanks
      05-23-2019, 02:57 PM   #800
shawnsheridan
PM sent.
      05-24-2019, 11:15 AM   #801
Icetrd4
Drives: BMW Series 3 & BMW X5 F15
Hello, may I get the link for the newest Psdzdata full? Thanks (BMW X5 F15)
      05-24-2019, 11:32 AM   #802
shawnsheridan
PM sent.
      05-24-2019, 01:09 PM   #803
Icetrd4
PM sent.
thank you so much
      06-13-2019, 05:48 PM   #804
XGamer
Drives: BMW M3, M5
Hello
Can you send the OLD PSdzDatafor the
Need for a BMW M5 F10 MY 2012
also if needed the right Esys Version Thanks
Because the KOMBI ECU has to Factory Reset and now need FULL PSdzData for the BMW M5 F10 MY 2012
Now much problems how can fix only with Flash OLD PSdzdata to the ECU / KOMBI ECU or also any other method to fix ? Because Factory Reset of the KOMBI ECU
, original factory condition made much problems now nothing work anymore right
Kind Regards
      06-13-2019, 07:56 PM   #805
shawnsheridan
Originally Posted by XGamer View Post
Hello
Kind Regards
Old PSdZData versions are not maintained. Why can't you use latest version?
      06-14-2019, 02:02 AM   #806
XGamer
Drives: BMW M3, M5
Hello.
Because of the Button miss clicked with Code Default Values.
Now much errors.
So i read i need FULL PSdzdata do Flash the KOMBI ECU again with the OLD Software version to fix it .
or you know a other way ? to fix it.
Kind Regards
      06-14-2019, 02:30 AM   #807
atzebmw
Hello.
Kind Regards
Wie sieht es denn aus in E-Sys?
Siehst du das Kombi noch?
Kannst du einen Screenshot machen?
Man kann das Problem wohl inzwischen auch ohne die alten psdzdata lösen.
      06-14-2019, 07:00 AM   #808
shawnsheridan
Hello.
Now much errors.
Kind Regards
Flash it with latest 4.17.30 PSdZdata Full. No need to use old version.
      07-16-2019, 06:25 AM   #809
expl0de
Drives: BMW f30 320d and e92 320i
May I have the lastest lite version, please?
Also, My car got updated to 2018 i-step and on my Esys I have 2015 i-step. I VO coded some CPU's with the stock FA after the update, to delete custom FDL coding and return settings to stock. Everything went well and without errors. Did I do any harm by using older psdzdata than that loaded on my car?
Thank you.
      07-16-2019, 06:37 AM   #810
shawnsheridan
Thank you.
PM sent. No harm. Either you can code ECU or you will have missing CAF and can't code it.
      07-16-2019, 07:22 AM   #811
expl0de
Thank you, you are great!
      07-23-2019, 04:41 PM   #812
elthox
Drives: E91 330xd stage 1
May I have both full and lite versions?
Thanks in advance
      07-23-2019, 05:02 PM   #813
shawnsheridan
Thanks in advance
If you have Full, there is Zero reason to also have Lite, and not that you would ever need it, but you could just make Lite from full. PM sent.
      07-24-2019, 11:07 AM   #814
paul223
paul223's Avatar
Drives: F10
May I have the link for latest psdzdata full.
