12-18-2017, 09:20 PM | #1 |
Rep 709
Boost Leak from CP to IC
So while under load sometimes, I can hear a very high pitched squeal coming from the front of the car. Sounds like air forced through a pin hole, leading me to believe it's some sort of boost leak.
What confirmed my belief is slight oil leakage between the connection of my CTS intercooler and my FTP chargepipe (from throttle body to IC). I know that both o-rings were installed properly so that is not the issue. Wondering if anyone else ever ran into this issue and what the fix could be. Someone mentioned it could be the material CTS uses on it's connections and that it was contracting/expanding from heat soak leading to an improper fitting. Really don't want to buy a new intercooler but not sure what else to do. Plan on putting the system under pressure and looking for leaks, or possibly performing a smoke test to see where it is escaping, but based on the oil i'm pretty sure I know the culprit.
Current: 12' E70 X5D | 04' Yamaha Warrior
Past: 13' Audi S6 | 13' E70 X5M | 13' E92 M3 Comp | 14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i | 06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL | 85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger |
12-19-2017, 06:29 AM | #2 |
Rep 775
No need to just blindly 'throw darts' to see what it might be... Agree, do pressure/smoke test, then report back.
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
12-19-2017, 11:49 AM | #3 |
Rep 709
More so starting this in preparation for the results. If my suspicions are correct I'm wondering if there are any fixes other than buying a whole new intercooler or chargepipe.
12-19-2017, 11:57 AM | #4 |
Rep 775
Well, if you have the rings in and still getting leak after re-seating everything.... bad interface. Solution = ________ yup. That's part of why i went with ER TIC/CP plus the Dinan IC. It works, is solid/know good, etc. And hey, while you're in there, if your near the DV may as well do that to the DV+
One of those "while i'm in there" kinda things. You know
Enjoy the Drive,
GTBrandon260.00 |
12-19-2017, 12:24 PM | #5 |
Rep 1,499
So I noticed while installing the FTP CP to my CTS Turbo IC the fitment was a little loose (even though it was nice and tight once I got it all installed) so instead of taking chances of a boost leak I applied some high-temp silicone gasket maker (I used the same at the corners of the valve cover gasket on my wife's E46) to the inside flange of the CP then bottled everything up. No issues.
GTBrandon260.00 |
12-19-2017, 01:03 PM | #6 |
Rep 4,333
before buying all sort of replacement parts, personally, i'd drop the intercooler and check the o-rings as well as everything else. the factory o-rings seem a bit thin and could easily tear.
12-19-2017, 01:30 PM | #7 | |
Rep 190,807
12-19-2017, 02:10 PM | #8 |
not good, but bad
333
Rep 361
FWIW after I installed my intake I noticed a pretty loud whistling/squeel sound, I just chocked it up to the intake
They are spelled BRAKES not breaks!!!! Oh FFS, not another spark plug thread!
BreadsBMW on Youtube |
12-19-2017, 02:12 PM | #9 |
Rep 709
That's common with open filter intakes, but might be a different noise
badbread332.50 |
12-19-2017, 02:13 PM | #10 | |
Rep 709
12-19-2017, 02:55 PM | #11 |
Rep 1,499
I replaced the CP and FMIC at the same time so I dry fit the new parts (CTS Turbo FMIC and FTP CP) before I installed them on the car. With the o-ring seal installed and clip engaged the fitment was a bit loose and I had suspicions. I added the gasket maker as a little insurance but when I actually got it all installed on the car it was tight. I made sure that I spread the upper pipe and lower pipe as far apart as possible at the silicone coupler which I think helped. I have had no issues since the installation.
12-19-2017, 04:18 PM | #12 | |
Rep 775
Hey, it could just be that you're a bit low on Blinker Fluid
Enjoy the Drive,
blowby, boost leak, chargepipe, cts, intercooler |
