09-29-2021, 08:45 PM | #1 |
Rep 1,862
Drives: powered by bootmod3
PTF Race Intercooler - Dyno testing and datalogs
Hey guys, wanted to share some data on our recently announced intercooler. Testing was completed on the dyno at a tuner shop in Europe, their comments below...
Background on intercooler/design: There are many aspects during mechanical engineering and CFD that are taken into account when designing any mechanical part. In the case of our intercooler we wanted a balance between flow and IAT control. Designing for either one of these on its own is not possible as you end up with either high pressure drop (i.e. intercooler doesn't flow well at all but cools well, very high fin count) or you end up with one that flows really well but it isn't a great heat exchanger (i.e. poor IAT control due to very low fin count). There are a number of other details but that is the gist of it when it comes to the core itself. Start to finish it has taken a full year to develop with full CFD (computational fluid dynamics analysis), 3D printing end tanks, test fitting, flow testing, manufacture our custom designed end tank molds (custom in terms of internal volume, angles, and the hot side having a built-in vane for flow direction). This vane that has been added works out great in the case of our design. We experimented adding more than 1 and it'd impose more restrictions then it was worth adding. Our outer core spec is 12.7 FPI (fins per inch). Internal FPI spec is different from the outer core. Lastly, designing intercoolers is a fine balance especially when working within fixed OEM space constraints. Increasing fin count without changing frontal surface area, results in increased wastegate duty cycle (more work for the turbo) and higher pressure drop, which in turn reduces peak power potential due to reduced airflow through the core. Increasing depth on our intercooler design did not provide measurable advantages in IAT. What really matters is the frontal surface area of the intercooler core in this case and the relationship between front surface area and the depth of the intercooler is a non-linear one. In short, choosing a core is based on power goals (i.e. airflow, pressure drop) and there is no single intercooler in the world that checks off all the boxes in one design. We feel we've designed an intercooler that works great for well past what built N55 motors can put down with turbo upgrades of various sorts and one that works very well on stock turbo applications as shown in the data below. Happy to discuss all aspects around our design, data and dynos shared below: ============= We did our tests within 30 minutes of each other on the dyno. So dynoruns -> upgrade intercooler -> dynoruns again to have as similar conditions as possible before and after the upgrade. The testcar was our in house BMW M135i (N55-EWG) with 326PS/450NM stock, the car is bone stock and has the bootmod3 Stage 1 93 octane OTS map flashed. During dynoruns it was clear to see a huge improvement on intake temperature throughout the pulls. The biggest delta on intake temperature but also power on the dyno was when we did some multigear pulls. Datalogs showing huge improvement on intake temps: Stock intercooler: https://www.bootmod3.net/log?id=614b...729b7e99770ad3 PTF intercooler: https://www.bootmod3.net/log?id=614b...729b7f195af9a7 Moreover, dynoruns provide a great visual of what a good intercooler is about: The intercooler is overall very easy to install and was done by our mechanic in less than 30 minutes
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
09-30-2021, 09:34 AM | #2 |
Rep 190,807
Thank you for sharing
Looks like the IAT delta is 34 whp on high RPM
10-03-2021, 04:12 PM | #3 |
Rep 1,862
Thank you
07-05-2022, 08:02 PM | #6 |
1296
Rep 3,533
What's even weirder is that the guy doesn't even have an n55..
07-08-2022, 12:41 PM | #8 |
Rep 931
07-08-2022, 01:09 PM | #9 | |
Rep 4,146
Edt: Worse.
Mods: Yes.
07-08-2022, 01:17 PM | #10 | ||
Rep 7,607
07-08-2022, 04:14 PM | #11 | |||
Rep 5,392
https://www.mishimoto.com/search-sim...drive?id=14917 |
07-08-2022, 05:25 PM | #12 |
Rep 4,146
From their build page on the intercooler, it doesn’t do much of anything but make their intercooler look different. The area where the core is angled, is dead space that doesn’t have any rows.
So far, in the most absolute sense, nothing does better than the VRSF Race. |
07-08-2022, 05:26 PM | #13 | |
Rep 7,607
I suspect the design is to force air from going through instead of over the top of the IC. Similar to old RX-7 "V" radiator/IC setups. I need to look at the front of the car again, but i think if you have a race IC (or any taller one), the air can't really go anywhere else? But need to look again. Either way, i'm sure they did it for that reason |
LA1Z24357.50 |
07-08-2022, 05:37 PM | #14 |
Rep 931
You have to be working for some FMIC manufacturer or retailer. No way you’ll post nonsense every time someone mentions this intercooler LMAO I don’t owe you anything. Get it for yourself and get all the data you need. Its way bigger than the CSF as well, smoother end tank design, get your facts straight. I bought it, I’m happy with it, it works perfect, you can run whatever makes you feel happy.
alohasurftoad3081.50 |
07-08-2022, 05:51 PM | #15 | |
Rep 7,607
AmuroRay2282.50 |
07-08-2022, 05:54 PM | #16 | |
Rep 931
07-08-2022, 06:13 PM | #17 | ||
Rep 5,392
https://cdn.mishimoto.com/media/prod...ringReport.pdf Also here's a video from the Mishimoto design engineer... |
07-08-2022, 06:51 PM | #18 | |
Rep 7,607
Anyways, I don't see how you can call real-world data collected on a car with this IC installed baseless or utterly childish. I mean, you can even look at the datalog posted by PTF in the OP.... We originally posted on that, then the thread was delete, this new one was started, and here we are again. There was the whole "oh its on a dyno" argument, that's why we looked at the data from the IC installed and ran on a car doing pulls on the road. I don't understand why you are so adamantly defending the IC and attacking those of us who, based on the data available, make conclusions about its performance related to IAT control. I dont care what brand of IC it is - the data shows what it shows. |
AmuroRay2282.50 |
07-08-2022, 07:02 PM | #19 | |
Rep 7,607
In the video he also says they tested different diverter plates inside the end tanks, and they concluded the IC actually flows better without them. Doesnt the BM3 IC have such a plate? ("built-in vane for flow direction"). The conclusion about the shrouding is interesting, but would need to know more about how they tested that to comment. One thing i noticed in the report is that the IAT rise during the dyno pulls actually looks pretty high... its kindof hard to see with the Y axis scale but it looks like around 15F rise during a pull. A datalog from a car would be helpful, but that seems higher than i would expect. |
AmuroRay2282.50 |
07-08-2022, 08:13 PM | #21 |
Rep 4,146
07-08-2022, 09:57 PM | #22 |
1296
Rep 3,533
Unless you're willing to share the data you have to prove otherwise, the existing data doesn't paint the ptf in a very good light man. Thats facts, not opinion. You could simply post some logs and shut everyone up, you know? Has nothing to with a flow bench as that has nothing to do with intake air temps and entirely different conversion.
intercooler, ptf |
