07-13-2022, 07:08 PM | #45 | |
Rep 190,807
No point In creating one thread to compare data as the logs will be pulled from different cars with different tunes, running in different temps. ER is an excellent intercooler; it's got a high fin density, is not too heavy, has superb finish quality, and is the only intercooler made in the US. the only drawback for me is the single core vs. the dual-core most brands use I have created a thread to discuss the different intercoolers. https://f30.bimmerpost.com/forums/sh...light=ultimate
07-14-2022, 03:45 AM | #46 |
Rep 2,358
Don't understand the comparison to stock...? Anything is better than stock.
A comparison to the VRSF/ER/Wagner would be more useful - no?
(A Dane in China) |
johnung4528.00 |
07-14-2022, 10:09 AM | #47 | |
Rep 190,807
With the stock intercooler, you get timing corrections which leads to power loss. When you upgrade to a good intercooler, the goal is to eliminate any timing correction that's due to high temp. If you compare different brands, especially the good ones, they will all do that. So you'll see people start comparing which IAT numbers are lower. This derails the thread as 1- it does not make any real-world performance difference as long as timing and boost are the same 2- it's never accurate as the data logs are done on different cars, different conditions The summary is that the stock intercooler leads to timing corrections, if your upgraded intercooler takes care of that, your car is performing at its best.
johnung4528.00 |
07-14-2022, 11:28 AM | #48 | |
1296
Rep 3,533
07-14-2022, 12:16 PM | #49 | |
Rep 7,607
Also the problem with most IC debates is that they are trying to compare ICs on paper. Each person should evaluate their IC on their car. Its pretty simple - if your IATs are increasing too much in a single pull, or increasing too much from the duty cycle you are driving under (back to back pulls, track usage, etc), then you need to upgrade your IC. That's why the "best" IC for one person might be different than the "best" for someone else. This is a test anyone with datalogging capabilities can do... |
n55david1295.50 |
07-14-2022, 12:27 PM | #50 | ||
Rep 107
2016 M235i RWD 6MT, Full E85 Custom Tune via BM3, Stock Turbo, DS2 hpfp, stock lpfp, VRSF bolt ons, CTS Turbo Inlet
Pussiwillow521.00 |
07-14-2022, 12:37 PM | #51 | |
Rep 190,807
15-20 lower IAT is better; 5 IAT lower will not make any difference on the street. Also, you forgot the part that more fins equal more weight. If you are nitpicking the density of air molecules, you need to consider the weight. You cant pick and choose what suits your argument better. Again, all this conversation is useless for daily driving. Some people tend to make this a lot more complicated than it needs to. I feel that you want something to discuss, so you start nitpicking, and that's fine; keep the forum alive. But again, for a daily driver, if your intercooler keeps the target timing and boost, the car performs at the max on the street. In this case, The intercooler, even an eBay one, is doing a great job. If your IAT is rising and you are getting timing corrections, your intercooler needs to be upgraded. I don't care what brand it is and how much it costs.
alohasurftoad3081.50 |
07-14-2022, 03:51 PM | #52 | ||
Rep 7,607
Of course, other people judge their IC using different criteria |
n55david1295.50 Pussiwillow521.00 |
07-14-2022, 05:53 PM | #53 |
1296
Rep 3,533
You and anyone else who cars about performance
Pussiwillow521.00 |
07-14-2022, 08:18 PM | #54 | |
Rep 190,807
it keeps your temps in check, and your ECU reaches the target ignition timing and boost. That's a good performer. Performance is based on ignition timing and boost. Read the post again.
07-14-2022, 08:39 PM | #55 | |
1296
Rep 3,533
You are aware is not actual boost that dictates power correct and that it's the amount of oxygen you can get into the cylinder and that the colder the air the more dense it is with oxygen and based on air flow, air temp and wide band 02 readings the computer decides how much fuel to add right? The more fuel you can burn the more power you'll make and you want the most oxygen you can get etc.. and again, density and fuel amount is key.. AND AGAIN, the cooler the air the more dense it is etc. You can Google it.. its physics
07-14-2022, 09:41 PM | #56 |
Rep 7,607
I was just messing around yunno, with the warm and fuzzy feeling part
07-14-2022, 09:51 PM | #57 | |
Rep 190,807
I have been checking this thread for days, and I told myself I'm not getting involved. And I truly believed that I would do it this time.
07-15-2022, 09:39 AM | #58 |
Rep 187
Drives: BMW F36 435i FBO
Swedish Do88 intercooler. Includes airflow test compared to stock IC and wagner evo 2
https://www.do88.se/sv/artiklar/bmw-...tercooler.html |
07-15-2022, 10:12 AM | #59 | |
Rep 190,807
Im not saying one is better than the other, I don't have the data to make these claims, but I'm saying that we need the correct data to make such a claim.
lucasborka40.00 |
07-15-2022, 02:02 PM | #60 | |
Rep 7,607
johnung4528.00 |
07-15-2022, 02:05 PM | #61 |
1296
Rep 3,533
Yeah. What's strange is I had a guy on ig telling me that and asking me about my oil tenps after the ic swap etc. I was so confused.
johnung4528.00 |
07-15-2022, 02:09 PM | #62 |
Rep 7,607
Yeah i mean the coolant temp is controlled electronically so it shouldnt deviate significantly unless you are pushing past the limits of the cooling system (which doesnt seem to be a problem even on track cars), so even if IAT differences did slightly affect how much heat the engine is putting into the coolant, the temp should be stable. And i know they arent claiming that the bigger IC provides more flow to the radiator (which again shouldnt make a difference unless the cooling system is at its limits)
n55david1295.50 |
07-15-2022, 02:11 PM | #63 | |
1296
Rep 3,533
07-15-2022, 02:12 PM | #64 | |
Rep 187
I think they included oil and water radiators they sell to. Don't know why😁 |
07-15-2022, 02:13 PM | #65 |
Rep 7,607
ohh reading fail on my part i guess. But I am still going to say that doesnt really make sense given the way oil and coolant temps are controlled. They would need to change the oil T-stat and flash cooling targets for example.
07-15-2022, 02:14 PM | #66 | ||
Rep 5,392
intercooler, ptf |
