06-14-2017, 03:45 AM | #1 |
Rep 105
How to fix Wastegate rattle on 2012 328i?
Hey guys, my wastegate is rattling as hell on my 2012 328i.
It's pretty much annoying every time I let off the throttle. Here's a picture: at the pointed out marks the rod is rattling like hell. I appreciate every type of help! |
06-15-2017, 01:46 PM | #3 |
Big Turbo Boys N Girls
327
Rep 579
Mostly all turbo's with internal gates rattle as the joints wear over time. You can try to loosen the nut by the actuator rod and adjust the L bracket that attaches to the actual rode either left or right to put some pressure on the flapper arm than tighten down on the thread. This can minimize the issue a little but eventually will wear on the joint a little more. If you are not loosing boost than that is OK and it something you are gonna have to deal with or take the turbo off and go to a import shop where they will need to rebuild that actuator rod with a new bushing etc. Cost will be around 300 range or depending on the shop charges.
06-19-2017, 09:19 AM | #4 | |
Rep 105
06-20-2017, 01:32 PM | #5 |
327
Rep 579
Correct. But your rattle is most likely at the flapper arm where your 1st pic was that you blurred out. That entire bushing inside the turbo manifold is wearing down and if you grab that arm that the tension rod is connecting you will more than likely be able to see play moving up, down, left, right. This means your turbo is on it's way out as the bushing is wearing. How long it will last is unknown but you will eventually in a few years or sooner have sealing problems and you will have erratic boost spikes or low boost condition cause the flapper will not seat right/ close fully to build boost.
You can also shift the L bracket slightly up or down (left or Right) to put pressure on the Tension rod assembly to minimize the rattling at the flapper inside the turbo exhaust housing. Last edited by D041987; 06-20-2017 at 01:55 PM.. |
06-21-2017, 09:45 AM | #6 | |
Rep 105
Actually this is a really cool idea. Will definitly try! |
06-21-2017, 09:47 AM | #7 |
Rep 105
06-22-2017, 04:18 AM | #8 |
Rep 105
Well, no chance on changing the angle of the L-Bracket.
It's sitting there really tight. I don't want to play with the screws because they're marked. Is there any way? |
06-22-2017, 03:11 PM | #9 |
327
Rep 579
Unfortunately, no. Your flapper bearing inside the turbo is wearing down so it will always rattle than. Only way to change is to have it rebuilt. I would personally rebuild it rather than getting a new turbo as the new turbo will fail again cause they use cheap parts. Once you rebuilt, the parts will usually be stronger and you wont have the issue again for a long while.
06-23-2017, 04:28 AM | #10 | |
Rep 105
BMW doesn't like it when people touch mechanics themselfes |
06-23-2017, 01:40 PM | #11 |
327
Rep 579
If you have warranty than go complain to BMW and say you felt the arm wiggle and want it replaced. You complain enough they will replace it.
08-30-2018, 02:22 PM | #14 |
¯\_(ツ)_/¯
945
Rep 1,762
I replaced my wastegate actuator because it was not moving properly. New OEM unit doesn't have the black plastic near those two nuts. DO NOT MOVE THOSE NUTS. Doing so you are changing the tension on the arm which affects the amount of boost. You turn it you can damage the turbo. The rattle problem lies where the arm goes to lever that comes out of the turbos wastegate. When I do my downpipe I will check to see how much play there is.
One thing that is interesting... that I cannot figure out and I want you guys to test this out for me. Leave the car in comfort with your windows down, see if you have the rattle when driving. Then drive the same but in sport mode and let me know if the rattle goes away. I have a rattle at 1500-2000 rpm in comfort but GONE in sport same RPM range. I think the sport mode tightening up the actuator/wastegate arm and it keeps it tight preventing it from closing all the way and letting it rattle. If you guys have the same then it is most definitely the wastegate inside of the turbo...
08-30-2018, 03:27 PM | #15 |
Rep 3,679
You say you'll check for play when you do your downpipe install... what exactly are you checking? I know there is a flap inside of the housing that can be easily accessed when removing the downpipe from under the car. Is that what you're checking for play, I don't know what it's called. Anyway, when I did my downpipe, that little flap had lots of play. Is that bad?
08-30-2018, 03:40 PM | #16 |
¯\_(ツ)_/¯
945
Rep 1,762
rjdnyy224 The play was going side to side?
Check this out.
Noelified228.00 |
09-11-2018, 11:37 AM | #17 |
Rep 2
Hey guys, i cannot find anywhere wastegate flapper arm for my bmw 528 f10 n20. Can you please give the link ? Where can i buy it? Is the one for n54 compatible with my car?
Thx in advance |
09-11-2018, 02:10 PM | #18 |
¯\_(ツ)_/¯
945
Rep 1,762
More details on the car please. Since you're in Georgia the specific year/month makes a difference. If you can post the last 7 of the vin that would pinpoint the exact model/region/which side the steering is on. Thanks
09-11-2018, 02:12 PM | #19 |
¯\_(ツ)_/¯
945
Rep 1,762
nikaslash A quick look on www.realoem.com you might have the pneumatic wastegate
https://www.realoem.com/bmw/enUS/sho...diagId=11_4786
09-13-2018, 03:18 PM | #20 |
Rep 2
Thank you for reply last digits of VIN: dw16382. 2012 july i guess its an American model, i exported it from US. This is what i need. Im searching for few days and all can find is flapper arm for n54 not n20. I really need help, car is in service waiting for this part
10-01-2018, 04:29 AM | #21 | |
Rep 105
10-01-2018, 07:59 AM | #22 | |
¯\_(ツ)_/¯
945
Rep 1,762
Looking at the bootmod3 dashboard in sport the car has more PSI/boost so I assume the wastegate is open? Then in eco/comfort there is almost no PSI so I assume the wastegate is closed. With it being worn out and in the closed position it has that play and rattles. Having it in sport mode keeps the wastegate open a bit so it's not touching the turbo housing.... what a shame. Looks like we might need new turbos
