08-02-2021, 12:35 PM | #1 |
Rep 61
Discoloured roof gutter trims on my F33...
Good evening all.
I picked up my new to me F33 440i last Saturday and I have noticed that the roof gutter trims (is this the correct term?!) are discoloured. I rubbed the area to to the right with my finger (very technical!) and it seemed to reduce the discolouration sightly, but is there something I can use to get rid of this or is it new trim time? |
08-02-2021, 12:40 PM | #2 |
Rep 2,246
Try a simple polish, something like autoglym super resin polish. There are many other solutions, but that's readily available.
The question is why is it so bad. Do you wash the car yourself? If so what products? |
mustremembermylogin30.00 |
08-02-2021, 01:02 PM | #3 |
Rep 61
Thanks - I'll give that a go - I've got a bottle of that which is good.
I've only owned the car since last Saturday so can only assume the previous owner used something that caused this. It didn't seem that bad when I picked it up from the dealer - they probably used something horrific on it to make it look nice for me.... |
08-02-2021, 01:15 PM | #4 |
Rep 2,246
It's probably been cleaned with an aggressive solution (TFR) traffic film remover. It's all fixable with the right polishes/tools but SRP is the easiest first option ion.
If it's a film type issue sitting on the top of the trim, the cleaners in SRP should remove it. If the trim feels as if it's etched then it'll need a different approach, like a mildly abrasive polish and elbow grease (or machine) to clean up. |
08-02-2021, 02:21 PM | #5 |
Rep 2,246
Incidentally, do you have comfort access that allows you to open the roof from the key?
Mine doesn't, but I bought the SmartTOP box. Well worth looking at if you are looking for the functionality. Took 5 mins to programme and 5 to install. Great piece of kit. |
08-02-2021, 02:22 PM | #6 |
Rep 61
Thanks for the tip - it's made a massive difference. The trim isn't etched thankfully.
I will have a proper go when the weather improves as it's now chucking it down... Can't quite believe it's August - want to get the roof down |
08-02-2021, 02:29 PM | #7 | |
Rep 61
I've had them before in previous cars and they are a really good upgrade. What I really want to do is to be able to set the mirrors to fold on locking but I don't think this is possible on an F33? Also would like to have a play with Bimmercode and set things such as the digital speedo (no HUD, sadly) but reading some threads on here has put me off as it looks like BMW are getting stroppy about this and mine is an AUC so don't want to risk the warranty.... |
08-02-2021, 04:19 PM | #8 | |
Rep 1,060
useful bit of kit. Regarding coding I had several items coded from new with no problems but recently car had a head unit problem and had to go to dealers, I was concerned due to recent reports of stance of BMW dealers with coding and warranty so decided to revert back to standard. Car had full update to sort head unit fault nothing said regarding coding and covered with extended warranty, so nothing picked up by their computers regarding previous coding. Since then I have decided to leave as standard just incase I need any other warranty work
G15, 840i M Sport
08-03-2021, 01:28 AM | #9 |
Rep 2,246
I think the big issue BMW have with coding is when factory options, like CarPlay are added. This type of coding is more of a structural change to the system and is doing them out of revenue.
Something like folding mirrors on lock, digital speedo or doors lights on when reversing are just changed to options that already exist. On my 335dx my dealer never had an issue with the coding (via BimmerCode) that I'd done. Even told me that after a software update one time I'd need to redo the boot closing from the remote and it was such a useful feature. I'm going to try and get the mirrors to fold on the F33 but not holding out much hope from everything I've read |
08-03-2021, 04:03 AM | #10 |
Rep 8,636
They will only fold if you have the option spec'd. Unless its different on the F33 you had to have either full electric seats or the folding mirror option on the F30/31.
08-03-2021, 04:52 AM | #11 | |
Rep 2,246
I've got full electric seats and mirrors, but the coding is different as selecting the options, like I have done previously on my F31 does not yield the same results. There's talk of a change from 2015 for the cabrio that seems to be when people started to struggle to add folding mirrors on lock from the remote. |
08-03-2021, 01:49 PM | #12 | |||
Rep 61
I'd also love Carplay but I think it might be a bridge too far and too risky with the potential warranty issues. |
08-03-2021, 01:51 PM | #13 |
Rep 61
08-03-2021, 02:18 PM | #14 | |
Rep 2,246
08-03-2021, 03:00 PM | #15 |
Rep 61
Beancounter_74601.50 |
08-03-2021, 03:33 PM | #16 | |
Rep 2,246
I coded them on my M140i today and it worked fine, but noticed they now include some narrative about not working on convertibles. Will keep looking…. |
08-03-2021, 03:43 PM | #17 | |
Rep 61
View post on imgur.com This is what the Bimmercode site says for the 4 series, which is remarkably similar... |
08-03-2021, 04:17 PM | #18 | |
Rep 1,060
G15, 840i M Sport
08-04-2021, 01:35 AM | #19 | ||
Rep 2,246
I'm thinking it could be the comfort access that's allowing you to do this, but as you say if it's possible on one, then there should be some coding to allow it. |
08-04-2021, 03:24 AM | #20 |
Rep 498
I have an F33 with power folding wing mirrors and comfort access and Yes if I hold the close button on the remote the mirrors do fold similarly I do the same on the door handle and someone here offered to code the car to do it automatically to save me constantly walking to the car to check whether it was locked. I asked the dealer but they said it wasn't possible. So I push the fold button when I leave the car and occasionally walk back to check to see if the red light is flashing.
In summary, let me know if you find way to get the car to fold the mirrors when locking. Also let me know about the Smart Top module. |
08-04-2021, 05:42 AM | #21 | |
Rep 2,246
Easy to fit/programme and adds great functionality. I have it set up as follows: 2 x press unlock = all windows down. 3 x press unlock = windows lower, roof goes down, windows raise back up. (You can make the windows stay down if preferred. 2 x press lock = all windows up 3 x press lock = roof up and all windows up. Also adds functionality to operate the lower/raise roof button in car as a one touch, rather than holding it. Cost me £319 delivered the next day. Very pleased with it. Happy to try and answer any questions. I may try and start another thread with pics and video too. |
GOF_430d286.00 |
08-04-2021, 07:17 AM | #22 |
Rep 498
How simple is it to install the module?
Usually I lower / raise the roof when I am in the car and I understand that the module means that I don't need to keep holding the switch whilst the roof sections go through their manoeuvres. |
