09-19-2020, 05:59 AM | #23 |
Rep 2,357
Thanks for the info. I have long been thinking of these as I am out of octan and don't want to run the turbo any harder. Ignition system is the last place to gain engine performance. However, I have never really been able to understand how these should improve much unless you run really high boost and maybe even increased gap.
(A Dane in China) |
09-19-2020, 11:15 AM | #24 | |
1296
Rep 3,532
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
superherorockstar63.00 |
09-19-2020, 08:58 PM | #27 |
Rep 353
Pussiwillow521.00 |
09-19-2020, 09:00 PM | #28 |
Rep 1,148
I'll look into them thanks
09-19-2020, 09:01 PM | #29 | |
Rep 353
09-22-2020, 04:41 AM | #30 |
Rep 2,357
5300miles If they can last that long then definitely a solid product
(A Dane in China) |
09-23-2020, 12:20 PM | #32 |
Rep 14
Pussiwillow521.00 |
09-23-2020, 01:16 PM | #33 | |
Rep 353
I just didn't want to deal with the precision raceworks install and wanted to try something new. Car felt better after changing over, fwiw. $900* |
01-04-2021, 08:55 PM | #34 |
Rep 378
So I replaced my Spark Plugs only at 75,000km and the lesson learnt at 79,500km is I should have done my coils too. Check Engine light came on and it was the P0306 Cylinder 6 Misfire, rough start up idle, and reduced acceleration.
Ended up going back to the OEM Delphi's and installed myself based on the videos here on the forum and YouTube. And what a difference! Much more responsive and even getting exhaust burbles in Comfort Mode.
2022 Audi RS5 Sportback
SOLD 2013 BMW 335i M Sport Xdrive / MPPK / MPE / Alpine White / Black Dakota Leather / M Sport Brake / 19"Style 403m / M Perf Diffuser |
01-05-2021, 12:13 AM | #35 | |
Rep 7,598
01-06-2021, 10:05 PM | #36 | |
@lbb_kev
490
Rep 512
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | Dorch Stage 3 HPFP | Nostrum S2 Injectors | Walbro 535 | EOS EKP | BendCalibration Flex Fuel Kit | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage |
01-25-2021, 03:25 PM | #37 | |
Rep 1,279
Drives: 2007 e90 335i
13.01 @ 107.6mph Mods: OETuning........
13.00 @ 108.89 JB4 Times |
01-25-2021, 06:17 PM | #38 |
Rep 462
I just installed these over the weekend on my 2015 f36. Work perfectly. You should be good.
04-11-2021, 09:14 PM | #39 |
Rep 135
I'm having the same issue - apparently they don't fit my 2013 F30 335i, but they will fit 2014-2015 335i models. Would anyone happen to know why? I've been searching for Eldor coils that would fit my car but can't seem to find any.
04-17-2021, 07:51 PM | #40 | |
Rep 10
N55's up to 07/13 were PWG and after that they switched to EWG. I believe that's the reason they are different. |
04-27-2021, 11:18 PM | #41 |
Rep 135
I had suspected it had to do with PWG vs EWG, but does that really make a difference for which coils you run? After much research, it seems that a lot of folks with my particular model run the same coils just fine.
04-28-2021, 09:34 AM | #42 | |
Modder of everything I own
147
Rep 491
part # 12138657273
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
06-07-2021, 09:55 PM | #43 |
Rep 125
Guys, my F30 320i after changing spark plug and did a timing chain replacement, is having a bit of a idle issue at cold start up. Its only for like a minute after that it seems to run fine. At one time I put the car in reverse right after starting and I can feel the car jerks a bit while reversing and this tells me its either the spark plugs or ignition coils are having issue. I am not sure how to correct this without changing either the spark plugs or the ignition coils. I guess the cheaper route is changing out the spark plugs first to see if they are the culprit.
Is there another way to find out? Will putting a code reader to the car produce some fault codes or something to indicate which bay is having the issue? It would have been easier if one of the bay is not firing up and testing out with one good coil or plug would do the trick, however, its only at cold start and goes away after a minute of warming up. |
06-07-2021, 10:10 PM | #44 | |
1296
Rep 3,532
if the check engine light is on you will have codes so checking them with a scanner will help. it could be a plug issue, may be a bad plug, could be a bad install.. who knows without checking it. who did the timing chain, can you confirm that it's done correctly?
