10-25-2018, 12:58 PM | #683 | |
Rep 521
But at the drag strip, I had no issues with bogging after shift. It shifts great at speed... as long as you're in DTC or better. |
10-25-2018, 02:37 PM | #684 |
Rep 228
I believe removing the Clutch Delay Valve helps with this.... I think...
10-25-2018, 09:07 PM | #686 | |||
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
I purposely try to slow down my 1-2 shift as it's too easy to beat the synchros and crunch gears. Quote:
I found especially frustrating at the drag strip. Quote:
MHD only just released a shift bog fix for the N54 at the end of August so I'm not expecting this will be resolved any time soon. This coupled with the rev hang issue makes me think I should have just got an auto. |
eluded3046.00 AddictedTo///M217.00 |
11-12-2018, 11:05 AM | #688 | |
Rep 465
"Racing is life. Anything before or after is just waiting." Steve MCQueen
11-13-2018, 11:55 AM | #690 |
Rep 1,219
Very interested in trans flash.
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance 10.84@127.43 / +1912 DA NH Dragway | 10.6@130 Dragy / +820 DA The Streets | NOW: Tesla Model Y Performance |
11-16-2018, 02:22 AM | #692 |
Rep 7
Hi I would really purchase the flash for the B58.
How do I load the flash file? Does the flash come with the cable or do I get the flash software via email? I have tried searching and emailing Mission in regards some clarity even saw all videos, seems like a bit of a grey area. Thanks |
11-16-2018, 06:02 PM | #693 | |
Rep 1,219
11-17-2018, 02:32 PM | #696 |
Rep 113
I wonder how the trans flash will be applied and how much power if anything much it will add. Is a trans flash a true power adder or the trans will have better shift points only?
11-18-2018, 03:08 AM | #697 |
Rep 504
yes, transmission generates power along with the engine for sure. you will see +30 hp easily.
11-18-2018, 09:12 AM | #698 |
Rep 113
😁 That would be great. Surprised there hasn't been any HPLP fuel pump talk if that's the case. One thing that makes me wonder is the other guy releasing a flash soon M flasher doesn't talk anything about hplp preventing his stage 2 from making power and I spoke with him directly about this. He said it wasn't an issue. 🤔. Eventually as we know more about this engine facts will come out on what u can and can't do to the B58.
335i/335d?21.00 |
11-18-2018, 04:33 PM | #699 |
Rep 1,219
11-18-2018, 07:12 PM | #700 | |
Rep 259
Drives: 16' AW 340i xDrive
Their whole life sheep are scared of the wolf but in the end, it's the sheppard who eats them.
eluded3046.00 |
11-18-2018, 08:51 PM | #701 |
Rep 1,369
He's got one of those darn fancy, new-fangled internal combustion transmissions. Got its own separate gas tank and all, don'tcha know? Runs best on straight E85. Generates almost as much power as my new red start/stop button I just installed.
eksigned139.00 |
11-19-2018, 01:17 AM | #703 | |
Rep 504
transmission flash will convert 8HP into internal combustion engine-transmission which uses ATF as a fuel when you floor it. You will need just to add ATF more often, that's the only drawback. P.S. dumb question (how much hp will add transmission flash) - dumb answer. |
