06-30-2023, 06:17 AM | #23 | |
Rep 12,253
06-30-2023, 07:25 AM | #24 | |
Rep 6,945
Looking at the configurator, 'Interior Design Atelier' seems to be the new name for Vernasca / Dakota which I'm not keen on. And 'Interior Design Suite' is probably the new equivalent for perforated extended Merino, although I haven't seen the olive leaf extract mentioned with Merino. The 8 does have perforated extended Merino, but I was too cheap to get the £3k option which includes ventilation. Mine was 6 months old so I had to find the one with the best fit of options rather than my exact spec. Interested to hear how you get on with the new toy. |
KRS_SN13537.00 |
06-30-2023, 08:04 AM | #25 | |
Rep 5,211
I also wanted bowers and wilkins on the IX that's the only option that was left to add. But a car with B&W too ie the 100%spec was 4k more expensive. As I'm not an audiophile and youtube music via android auto I saved that 4k. |
JD64270.50 |
06-30-2023, 08:26 AM | #26 | |
Rep 6,945
I have B&W in the current 8, having had HK in the previous one. I’m not at all convinced that B&W is worth the extra. It’s better than HK, but the difference is pretty modest to my ears at least. If it was a 1k option then perhaps, but it doesn’t justify the price difference in my view. It only really adds a little bling to the car with its shiny steel grilles and light-up speakers. |
06-30-2023, 08:42 AM | #27 | |
Rep 5,211
JD64270.50 MashinBenzin8459.00 |
06-30-2023, 02:42 PM | #29 |
Rep 4,451
I liked the ventilation in the X5 - it works in a different way to what you may expect, it doesn’t blow air onto your body but sucks the moisture away.
I think the problem is that it doesn’t do what people expect so there is disappointment as a result. |
KRS_SN13537.00 |
06-30-2023, 02:54 PM | #30 |
Rep 5,211
Took the ix for a drive down country roads. Aurs road etc. It grips like glue on wet roads today. One pedal driving means as soon as you release the accelerator it slows right down. Its very quick once you press the accelerator it flies. Body lean is minimal. It handles brilliantly while gliding over broken roads. I've never driven m car but this is the best handling plus comfort car I've driven even better than the g05 x5 by miles and the 330e 530e 335d on acs/billyb8 etc. The test drive was in chill. Once sport is selected its more rewarding.
06-30-2023, 04:48 PM | #31 |
Rep 5,211
A quick question to people used to this. I charged for the first time and think limit was set at 80% should I go for like 95% or just leave it at 80%. Bearing in mind battery warranty lasts till 2030 ?
07-01-2023, 02:35 AM | #33 | |
Rep 8,783
I doubt 90/95 makes a huge difference, but all the same it seems worth restricting when the range isn't needed (almost all the time). I limit the charge on my S23U to 85% too. Nice feature Samsung.
Drives - 2020 LR Discovery HSE-L Previous - 2019 LR Discovery HSE-L // 2016 F36 440i // 2009 E90 320D SE |
KRS_SN13537.00 |
07-01-2023, 02:41 AM | #34 |
Rep 8,783
NB. I also try and avoid going below 20% for battery protection.
My usual home charging routine is set the limit to 80% and charge once below 30-40% depending on expected usage. It sounds like a lot to think about when new to EVs but within days it becomes second nature. The hassle-free nature of it is wonderful. Have had free supercharger miles in use for a few weeks and that's brilliant. The speed of charging is great.
KRS_SN13537.00 |
07-01-2023, 04:09 AM | #35 |
Rep 25,115
Depends on your battery type and BMW recommendations. 80% sounds wise, I charge to 100 most of the time as it’s the Tesla recommendation on the LFP battery if the RWD.
It was another factor in the LR Vs the RWD. 80% of the bigger battery felt sinailt to 100% of the RWD for daily/weekly mileage use. Up in Northumberland this week now and no issues with the journey up here, charging infrastructure seems to be getting there. I signed up for Electroverse on the back of OI and it gets discount on several places, Ionity was impressive at some M1 super aervices that had a Nando’s. 20-80 sounds wise for iX but best have a check of their manual etc
My car made front page of Bimmerpost
KRS_SN13537.00 MashinBenzin8459.00 |
07-01-2023, 04:12 AM | #36 |
Rep 5,211
MashinBenzin pmgreenwood thanks...makes sense..with daily usage around 70 miles there's plenty with 80%..says 180 miles available..which is fine.
The other question is ..with ice constant revving up causes engine wear. If EV is driven foot to the floor a lot does it cause battery damage? Long trips may be around (leeds) may have to check out superchargers. Great that you've got free SC miles |
07-01-2023, 04:16 AM | #37 | |
Rep 5,211
07-01-2023, 06:50 AM | #39 | |
Rep 25,115
KRS_SN13537.00 |
07-01-2023, 11:07 AM | #42 |
Rep 5,211
07-01-2023, 12:53 PM | #43 |
Rep 5,211
More experiences..
1.Going over metal speed breakers in the school car park. The X5 would thud slightly and shake a bit before settling. . This shruggs it off its as if Going over a minor road imperfection no sound no shake! 2. Drivingin rain. . I'm aware of how the rainwater usually makes a sound in wheelerarches. In this sounded like a distant stream. Actually relaxing. 3. 3 of us in the rear its very spacious. Note how the seats flow on to the door arches and the material on the doors is also very soft. 4. The back floor is flat and there is space for feet under central console. |
07-02-2023, 01:35 AM | #44 |
Rep 954
