BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY: F30 Surround view retrofit
      06-21-2017, 09:36 AM   #67
jdr78569
jdr78569's Avatar
180
Drives: F31 328d sport wag
Back from the dead! Im trying to get all the wiring for this install but 1. having issues finding the door and 2. can't find the mirror wire for a good price (only new about 70$) 61129281712.
Question is. Would the eBay seller be able to make the wire for the outside mirror? What is the length of that cable so i can try that.
I found a guy who made the wires for his F10 and doesn't seem too hard but i would rather get it right and order the 61119281258 Surround view HSD. Has anyone tried the before?
When ordering has anyone had any issues? I told them the same thing "eBay seller rfbat - This can be ordered custom from several sellers on eBay. The exact terminology used for my order and for another forum member was “FAKRA HSD LVDS Straight Female to FAKRA HSD LVDS Right Angle Female Dacar 535 4-Core 1M”, with a pin chart of “1-4, 2-3, 3-2, 4-1”.
and he said its about $20 a wire.
Any other parts i will be needing? How is coding? Im looking into picking up the coding cable and software for about $20 but idk how to use it. If its easy to use ill get it if its not then it ill charge me a bunch for that. I also need to code my new LED fogs and anything else i get
      07-06-2017, 10:58 AM   #68
wiluspyder
Drives: BMW F30
Cable type
Hi,
Does anyone know what type of cable is used from the control unit to the passenger side door hinge pillar?
I think it's female to male straight through but I'd like to confirm.
Mine got damaged and I found a supplier on eBay that can provide any length and type needed but I need detailed specs.
The one I'm looking at is FAKRA HSD LVDS Straight Female to Male
http://www.ebay.com/itm/For-BMW-Merc...gAAOSw-RRXB0HQ
      07-18-2017, 09:38 AM   #69
rkspeck33
Drives: 2014 428xi - F32
Can we get the photobucket images updated? Since they are now charging to host images.
      10-08-2017, 04:00 PM   #70
player_pl
Drives: BMW F36 430xd
Here you have.
Mbeans35.00
VipinLJ1941.50
      10-16-2017, 01:12 PM   #71
macs
macs's Avatar
Italy
Drives: f31
Hello, can somebody please indicate the lenght of the reverse camera cable (blue connectors) that is part of 61119281258 kit? I have a F31 and that kit is for F30 so I'm not sure if it could be ok the same. Specific kit for F31 (61119281259) is almost double price, don't know why, the only difference should be in that cable lenght.
      10-20-2017, 09:37 AM   #72
Mbeans
Originally Posted by player_pl View Post
Here you have.
Solid work. That must have been some long hours!
      10-21-2017, 07:22 AM   #73
jdr78569
jdr78569's Avatar
180
I made a DIY on this too since the pics were gone
http://f30.bimmerpost.com/forums/sho....php?t=1418932
      10-21-2017, 07:23 AM   #74
jdr78569
jdr78569's Avatar
180
Are you trying to do surround view or reverse cam ?
      10-21-2017, 04:05 PM   #75
macs
macs's Avatar
Italy
Drives: f31
Both, but my doubt is about reverse camera wiring, surroud cables should be the same in F30 and F31
      10-21-2017, 04:13 PM   #76
jdr78569
jdr78569's Avatar
180
Mine came with the reverse cam so I couldn't tell you the length. But I do have a cable and reverse module on module on the classifieds. Do you have the length of the part # u put?
      10-22-2017, 03:44 AM   #77
macs
macs's Avatar
Italy
Drives: f31
I saw the picture, I suppose that is cable part of 61119281258 you didn't use because you already have rearview camera. Can you please tell me the lenght of that?
      10-27-2017, 02:41 PM   #78
macs
macs's Avatar
Italy
Drives: f31
At the end I bought the harness 61119281258, hope it fit on the F31 chassis. For whom who may be interested, the rear camera cable included in the kit is 5,6 meter long. Next Sunday I will try it and I'll post updates.
      11-05-2017, 12:48 PM   #79
macs
macs's Avatar
Italy
Drives: f31
So, finally, I've installed the camera and everithing worls as it should, even on my HU_ENTRYNAV with 6.5" display. Only the HSD cable is little bit shorter (about 50/60cm) to be routed in OEM way and I had to find an alternative I didn't wanted to, but no alternatives. Now ahead with surround view....
      12-07-2017, 10:51 PM   #80
accloginsell
What i Need to do if i like to Build it myself?
      01-06-2018, 11:11 AM   #81
Diljee
South Africa
Drives: BMW 2015 F32 420d Msport
Hi,
I have an issue with my rear camera install. I have the parking lanes and the obstacle identification which works, however, I get a rear camera failure error. After checking with Rheingold, it says the cable might be damaged. The problem is, the camera pinouts are the same as what roxxor quoted as this is an OEM cable which I bought from a scrap yard. I tested the continuity and all is fine. Basically all works fine except there is no image from the camera on the iDrive.
      01-06-2018, 03:19 PM   #82
macs
macs's Avatar
Italy
Drives: f31
Originally Posted by Diljee View Post
Hi,
Did you correctly code all the modules? Did you initialize rear camera?
      01-08-2018, 01:51 PM   #83
Diljee
South Africa
No Rear View Camera Image
Hi, I added 3AG, coded all modules just to be safe. Also, I coded the actual ECU's and not the underlying CAFD. Here are some pictures.
https://drive.google.com/open?id=1K2...FSunUWzl2uGC5J
      01-08-2018, 01:58 PM   #84
Diljee
South Africa
Can you please confirm all the modules? I have a F32. I know this is the F30 thread but its the same retrofit pdf. When I calibrate/ Initialize the camera it does nothing or maybe I'm doing something wrong. I t also says no camera installed.
      01-08-2018, 04:48 PM   #85
macs
macs's Avatar
Italy
Drives: f31
You need to code at least REM, HU, FEM BODY and TRSVC then you need to initialize the camera with ISTA. If nothing happens check the cable again to see the correct pin alignemt and/or perform a troubleshooting with ISTA.
      01-16-2018, 05:59 AM   #86
THE_AVIATOR
THE_AVIATOR's Avatar
Egypt
Drives: F30 320i LCI M-Sport
Hi all,
I have a question for those who did the retrofit. Why must the car have PDC front? If it has only rear, would it not work?
      01-16-2018, 06:57 AM   #87
jkwhar
Drives: F30 328i Xdrive | F15 x35i
Originally Posted by THE_AVIATOR View Post
Hi all,
Not sure exactly why other then cars that came with surround view from factory came with front PDC. Its probably one of those things that can't be coded out so you're not always getting a PDC error.
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD)
      01-16-2018, 01:37 PM   #88
dynamik
dynamik's Avatar
Drives: 2018 340i xDrive
Anyone in the NYC/tri-state area able to do this for a fellow member?
I'm not much of a DIY person nor do I trust myself doing this. My wife has been wanting this feature forever. I have a 2016 340i with Rear View and PDC (front and back) already.
