04-22-2014, 06:44 AM | #1 |
Rep 243
Air Force Master Blaster
I just bought a Porter Cable XP7424 and am getting into detailing my car.
I have seen the Master Blaster and am thinking of getting it. It makes sense not to wipe down the car to avoid swirls. Anyone have this?? How does it work for you? It's kinda of pricey for a blower and I'm on the fence about this. |
04-22-2014, 09:53 AM | #2 |
Rep 254
Drives: E30 M3 & 325ic-F30 335i Xdrive
Do your self a favor and go to sears to get a craftsman electric leaf blower for under $50 (see link below). That is what I use to dry my car every time, does the same thing as that bs $300 "master blaster." In my opinion its a complete waste of money.
http://www.sears.com/craftsman-12-am...1&blockType=G1 |
Billfitz8220.50 WallySlash96.00 |
04-22-2014, 01:22 PM | #3 |
Rep 169
I have the Master Blaster. I use to use an electric leaf blower. The advantage of the Master Blaster is that it uses filtered warm air. I have Sonax Polymer Net Shield as my LSP and when I use the Master Blaster, the water just blows right off. It will definitely help you minimize swirls as you asked since you don't need to really touch the paint to dry (as long as you have the car protected well), except maybe a few touch-up spots.
The Master Blaster is very well made and puts out a lot of air and it is very concentrated so easy to direct and control. They also stand behind their product if you have any problems. |
04-22-2014, 07:28 PM | #4 |
Rep 1,101
I use a Stihl gas power leaf blower. Works great and it wasn't too expensive. I prefer it to the electric ones as I HATE draging power cords around.
I use Menzerna power lock sealant and the water just runs right off with the blower. I usually do 2 trips around the car and that gets off 90-95% of the water. Then I just do some spot drying with my waffle weave microfibre drying towels. My 135 is jet black so it is soft paint. I have had very good luck with what I have been doing on my car. |
04-23-2014, 08:02 AM | #5 |
Rep 25
Leaf blower works well from what i have seen. But in all honesty if you are careful and take good care of your wash mitt and towels you will be ok. Make sure you use 3 buckets with grit guards, 1 for wheels and 2 for the wash process. Wash 1-2 panels rinse your mitt out and continue. When drying spritz the drying towel with a quick detailer this will help prevent towel scratches. Do not use quick detailer to get dust off your car just wait until it is time to wash it. Make sure you wash your microfibers in microfiber wash in hot water and dry on the lowest setting if you use the dryer.
If your looking to learn how to polish we offer training. |
Desertnate390.50 WallySlash96.00 |
04-23-2014, 11:49 AM | #6 | |
Rep 243
04-23-2014, 11:57 AM | #7 |
Now in the dark side !
65
Rep 1,136
Been using a Shop-Vac Wet-Dry vacuum on the exhaust outlet with a homemade filter.
Been working great for the last 4 years I've been doing this. This is if you don't forget to clean and dry it correctly beforehand. Don't ask how I know...
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey) Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed) 2010 X5 35d Black fully loaded (Sold) 2007 335i sedan Antracite (Sold and missed !) |
04-24-2014, 06:58 AM | #8 |
Rep 25
Send me an email and I will be happy to send you the details Jason@esotericdetail.com
04-26-2014, 03:55 PM | #9 |
Rep 702
I just purchased this dryer from Chemical Guys and am looking forward to using it. Fairly inexpensive so should be worth it
http://www.chemicalguys.com/Chemical..._p/acc_303.htm
2014 BMW 328i Sportline--Arctic White/Black, 8 speed
04-26-2014, 08:40 PM | #10 |
Rep 123
I have a Masterblaster and it works well. I used to use an electric leaf blower. Keep in mind that you need at least a 20 amp circuit for the MB. This is more than most garage outlets put out.
12-20-2021, 10:58 AM | #11 |
Mini Cooper, Present F15 Owner
Rep 90
I opted for a DeWalt cordless leaf blowers. I have two different ones (the smaller DCE100B, about $129.00 and the larger, CDBL770B, about $188) but like the larger one as it moves a lot more air on the flex volt battery.
https://www.thespruce.com/thmb/_CH3K...0001d920a8.jpg This particular model has a concentrator tip which really moves the water off the car, nicely. No cord to drag around behind you is a plus. I would recommend wearing hearing protection when you use it as either of them howl. Best thing is it also works on leaves and snow. We don't get a lot of snow and often times it's fluffy enough that I can use the leaf blower instead of a broom or shovel. One charged battery is enough to do the whole car, very nicely. |
Billfitz8220.50 |
12-24-2021, 07:01 AM | #12 |
Rep 153
Drives: 2014 428xi Sport Line
Same here. Put on the crevice tool and you get a direct and powerful stream of air.
12-24-2021, 12:58 PM | #13 |
Rep 16,054
I use my cordless leaf blower, which shares the same battery as my string trimmer and hedge trimmer. I can't see spending major $$ on a blower that you'd only use on the car.
12-26-2021, 11:53 AM | #14 |
Rep 282
This is what I do. I typically blow out areas that drip (trunk, door handles, wheel lugs, front grill, side mirrors) and then wipe the rest of the vehicle with a microfiber towel. You'll eventually get swirls overtime no matter what you do even washing the vehicle correctly. Just polish the vehicle when it gets to that point.
Billfitz8220.50 |
01-02-2022, 11:32 AM | #15 |
Rep 303
I use my Stihl gas leaf blower to dry the car before I pull it into the garage to finish detailing. Before I use the blower I tilt the side mirrors in just to get the excess water off. One thing that always annoyed me was the fact that there is no drainage under the wiper arms where water can pool up on the plastic cowling. I know someone in this forum drilled small holes to allow it to drain, though
03-23-2022, 03:17 AM | #16 |
Great Teacher
1076
Rep 1,303
Drives: 06 e91 325ix
I used my leaf blower as well, then bought the detail garage one cause I wanted something less awkward and smaller to chase water along those long long touring gutters and shadow line trims and roof rails plus out of the mirror housings
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
