BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > BMW AH3 N55 335i F30 512 WHP 526 lb-fts 1/4 mile 10.917 sec
      12-26-2020, 10:43 AM   #1
me06305
bt5000
Thailand
Drives: BMW AH3 F30 2014
How to modify AH3 N55 335i F30 to have 512 WHP 526 lb-fts 1/4 mile 10.917 sec?
Please give an idea:
HPFP, LPFP, PI, bootmod3 custom tune, e20,e85, upgrade turbo, meth
Car installing Dorch stage 2 + pure turbo stage + E20 or
Pure turbo stage + fuel it lpfp stage 2 + PI + E20 achieve my target? or I need to run full e85 and meth injection (I think it's not practical for daily use)
Please advice.
      12-26-2020, 07:29 PM   #2
sqwinny
Drives: 2013 6MT 328i M Sport
Budget ?
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
      12-27-2020, 02:06 AM   #3
weehe126
Drives: 2017 340i
You will need a pure stage 2 turbo, upgraded hpfp (dorch stage 2), lpfp, down pipe, charge pipe, E40-50. Shouldn't need PI.
      01-26-2021, 08:26 AM   #4
me06305
bt5000
Thailand
Originally Posted by sqwinny View Post
Budget ?
6k
      01-26-2021, 09:15 AM   #5
435gc
435gc's Avatar
174
Drives: 2015 435i Gran Coupe xdrive
You can do it for 6k if you can diy some of the install.
What wehee126 said for mods. Though a lpfp may not be needed for those power levels unless you choose PI over hpfp. Also will need a tune like MHD/BM3/JB4 and a race intercooler.
If you don't have easy access to e85 you will need meth.
      01-26-2021, 01:27 PM   #6
thejeremyman9
thejeremyman9's Avatar
4343
Drives: 2015 BMW 335i
Correct except no LPFP needed for E40-50 and add IC (bigger than a 5'' stepped) as noted above, and custom tune. BM3 OTS stage 2+ might get you close without a custom tune, assuming that works for AH3.
While you are upgrading the turbo you probably also want to do turbo inlet and DV like turbosmart. Stock intake and exhaust are fine.
      01-27-2021, 12:44 PM   #7
j2nicee
j2nicee's Avatar
55
Drives: 2009 E92
Why issues with running meth on a daily? I do it just fine.
      01-27-2021, 02:01 PM   #8
thejeremyman9
4343
There are no specific issues so long as your tune is made for it (if you run OTS tunes you rely on fuel trims to compensate). But if OP has access to ethanol and upgrades the HPFP, that is a simpler solution for additional octane and fueling.
      01-27-2021, 07:29 PM   #9
sqwinny
I'd say go speedtech turbo kit. You'll need supporting mods of course but you'll get there little by little and supports 100% oem fitment for everything. You will need to upgrade fueling to take advantage of the turbo, but the hard part would be done for you.
https://speedtech.com/pages/bmw-n55
      01-27-2021, 07:54 PM   #10
435gc
435gc's Avatar
174
Won't be able to go speedtech with 6k budget.
      01-28-2021, 07:50 AM   #11
j2nicee
j2nicee's Avatar
55
Drives: 2009 E92
Yeah Im on custom tune.
      02-01-2021, 10:27 AM   #12
me06305
bt5000
Thailand
How much to go speed tech? https://speedtech.com/products/bmw-n...8474-turbo-kit + anything else?
activehybrid 3, e20, e85, hpfp, lpfp, port injection, turbo
