BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > KW V3 owners please share your thoughts
      11-25-2020, 08:00 AM   #1
radicalrev
Indonesia
104
Drives: F30 320i B48
Hello guys,
Recently stumbled across a used KW V3 for pretty good price locally.
I couldn't find much information regarding the ride quality especially in terms of comfort for the KW V3.
I currently have the Eibach Pro Kit with stock shocks, and wondering those who have the KW V3 or rode a F30 on them before could share some thoughts regarding the ride comfort compared to lowering springs or the stock suspension.
Thank you!
      11-26-2020, 04:13 PM   #2
cfm56d7b
KW V3 coilovers offer independent rebound and compression controls. You will be able to tune suspension behavior across a much wider envelope. Lowering springs offer one setting - and it cannot be changed.
I suggest to explore whether KW V3 lowering range is what you want. If the price is right, then these coilovers would be worth a serious consideration.
      11-27-2020, 09:29 AM   #3
radicalrev
Indonesia
104
Lowering range should fit my needs as this is a daily driver, even with Eibach Pro Kit I am pretty satisfy with the drop.
What about the comfort? Does it offer smoother ride and feel when going over uneven surfaces compared to the lowering springs + stock shocks?
      11-27-2020, 10:40 AM   #4
cfm56d7b
What size wheels are you planning to use with KW V3 coilovers: 18", 19", 20"?
      11-28-2020, 04:02 AM   #5
radicalrev
Indonesia
104
Probably will stick with the 19" setup I currently have
      11-29-2020, 10:42 AM   #6
jv004
Drives: X3M Comp
You'll like the KW3 once you adjust them to your liking and comfort would be a bit better or more then the lowering springs but not worse and they'll last you a long time. The lowering springs will eventually bust out your shocks causing you to fishtail on hard acceleration lol
      12-01-2020, 10:45 AM   #7
cfm56d7b
radicalrev, 19" wheels are a good match for KW V3 coilovers. In fact, if you decided to install 20" wheels, KW V3 would be a practical necessity in order to have the flexibility to adjust compression and rebound since the smaller sidewall would transmit more road imperfections, making the ride harsher.
