10-27-2020, 06:47 AM | #23 |
Rep 1,236
I have this same problem based on the description. A faint rubbing noise that the bmw tech can't even hear. Only at low speeds, and I hear it better with the windows up, it's so faint. It is definitely a rubbing noise of some type. It coincides with speed and is gone by even 30mph. There are a lot of possible culprits in this thread so I thought I'd bring this back around in case I'm not the only one.
2023 M2. ZB. Manual.
2024 m235i |
11-23-2020, 08:49 AM | #24 | |
Rep 39
11-23-2020, 07:14 PM | #25 |
Rep 649
Yes, I had this too.
I thought it was the rear diff failing but it turned out to be the wife, singing to the kids.
Q
2018 440i Gran Coupe, MPPSK, Champagne Quartz, Ivory White, Adaptive Susp., Sunroof, Active Security, CA and a few other bits.
12-22-2020, 11:26 AM | #26 | |
Rep 49
04-02-2022, 11:16 AM | #27 | |
Rep 3
08-06-2022, 06:19 PM | #28 | |
Rep 67
I’ve fastened the cable with a zip tie till the oem part arrived and when arived I’ve replaced it. HINT: to make sure the noise is coming from the hand brake cable hitting the , place your hand over the wheel well, I did that and felt the cable hitting the wheel well whenever the sound happened. I found out that ECSTuning had a metal replacement for it 34406854898 , but it’s very expensive https://www.ecstuning.com/b-aga-tool...a-pcc-854-898/ |
