05-22-2019, 03:30 PM | #1 |
Rep 45
Clutch judder
Hi, took car (320i manual) for end of warranty check at weekend. I said it occasionally had clutch judder. On reviewing after check they confirmed but said I would need to pay for labour (4-5 hors I. E. Approx £400-500) to check if wear and tear or if manufacturers fault. If the latter they would replace under warranty, if not I would foot the bill.
I see some other threads on this and other websites about clutch judder being common. The service guy asked if I could not just live with it. I probably will but what are people's thoughts? The car has a 5 year service pack and 2 mot protection (taking in for an mot in couple of weeks before 1 year AUC warranty runs out. Not planning on taking out extended warranty - quote with 250 xs is £440 Thanks |
05-22-2019, 03:38 PM | #2 |
Rep 1,094
Mileage and age of the car would be handy to know but :
If the car is still covered under the used car warranty , which it is , and they agree that there is a genuine fault , which they do, then why should you need to pay for anything ?? K |
05-22-2019, 03:45 PM | #3 |
Rep 3,967
because clutch wear and tear isn't covered?
05-22-2019, 09:47 PM | #6 |
Rep 797
Give it more gas and feather it back in a bit .. if you lug it too much it will slip real fast at engagement, hence the chatter.
I think it's kinda normal .. I've had it here and there in every car including this one when I bog it real bad. I had a heavy clutch and light flywheel in my Honda, that setup even brand new would easily chatter unless I bounced around 3k and feathered in. It was such a nice setup though. This car is great, cdv delete, and I am really really liking the ultimate clutch pedal. It's fantastic would recommend 10/10. |
05-23-2019, 12:30 AM | #7 |
Rep 3,216
The problem is that it's entirely possible to wreck a clutch in weeks (watch virtually any OAP manoeuvring around a car park) , or just as possible to make a clutch last 100k+ miles (if driven by someone with a lot of mechanical sympathy, a lot of motorway miles, etc).
That is why clutch wear, rather than faults, are not covered by the warranty. |
05-23-2019, 02:06 AM | #8 |
Rep 777
I have always bought automatics but, my son in law bought his 3 Series used around 35000 on the clock but came with a 12 month warranty. After around 7 months I felt a slight clutch judder when driving and a slight difficulty to engage gear.
Told him to take to BMW for warranty repairs as BMW were having a problem with clutches. Clutch wear causes slipping not vibration or complete disengagement. After speaking with BMW they do state if its worn then he would have to pay however my argument was that the clutch was distorted not worn causing the clutch to engage/disengage unevenly which resulted in the problem. They checked the clutch and changed it FOC. When he put his car in for a 4 Series I drove the car and even on that I could feel a slight vibration and this was logged and mentioned to BMW and they changed that one also without any problems FOC. I know BMW were having problems with clutches and were changing them when needed under warranty, don't put this off as it will eventually get so bad it cant be driven when pulling away then you wont get any help from BMW. |
05-23-2019, 07:47 AM | #9 |
Rep 241
My 320i is 5/1/2 years old and just coming up to 39,000 miles. I took the car over from my wife, 2 years ago, and the judder has been there occasionally, often most noticeable when I have passengers. In the 2 years I've been driving the car, though, it hasn't got worse. I find it's better giving the car more revs, than I'd normally feel happier with, if I have a heavier load than normal.
320i Sport - AW, 397 alloys
05-23-2019, 07:55 AM | #10 | |
Rep 777
05-23-2019, 07:56 AM | #11 | |
Rep 609
Drives: F31 330D xDrive MPPK ACS
F31 Mineral Grey 330d Xdrive, ACS, Adaptive, MPPK.
Gone but not forgotten: 1967 Triumph GT6 Mk1 (6 pot 2 litre widowmaker) 1966 Triumph TR4A (4 pot 2.2 litre, huge torque, lovely car) 2004 Audi TT 3.2 DSG Quattro (weak springs & nose heavy) 2006 VW Golf GTI (brilliant on good tyres) |
05-23-2019, 08:45 AM | #12 |
Rep 594
Do you experience the clutch judder primarily when pulling away in 1st gear?
I have had two BMW manuals in the past and both have had this issue. I just lived with it (although it was a nightmare in slow moving traffic), although I heard that the bmw clutch delay valve was the reason behind this and some people have had it removed completely to solve the issue. I never went down this route, but I guess you could see if they would replace the valve as a starting point. |
05-23-2019, 09:48 AM | #13 | |
Rep 3,967
05-23-2019, 03:16 PM | #14 |
Rep 45
Thanks for all your responses. Yes it occurs pulling away in 1st gear - it sonetime occurs when cold sometimes when warmed up, sometimes in comfort and sometimes in sport.
05-24-2019, 04:06 AM | #15 | |
Rep 268
Clutch wear just feels different and tends to be more consistent, a faulty DMF can be intermittent like yours. |
05-27-2019, 01:32 PM | #16 |
Rep 45
Thanks. If it is the DMF would that be a smaller job? Reason I ask is when I googled it as suggested one poster said they had paid £79 upfront for an inspection (that would be reimbursed if within the warranty ) and this is a lot less than the insection I was quoted of 4-5 hours to remove the gearbox
Is it possible to check the DMF first, and then if it isn't that only then check clutch ?(apologies I am not mechanically minded). I'm torn with the replies above as some recommend living with it, others to get it seen to. I plan to keep the car for a while but don't want to fork out tons of money if it can be avoided. Thanks Nick |
03-12-2020, 05:12 AM | #17 |
Rep 320
Hi everyone.
I don't want to start a new post so I will try to describe my problem here. I currently own a 2016 F30 320i with B48 engine and 29k miles on the clock. I'm the second owner and I've only had it for 2 weeks now. I previously owned a 2014 F20 116d with just 40k miles on it. My F20 had a really bad judder when cold and sometimes it wouldn't go away for days. I had to rev it higher to get smooth take off. Car went to we buy any car because I just didn't want to spend a grand to fix it, plus I wanted to change for a petrol anyway. I got this F30 and it being a petrol I thought that it would be a lot better. During the test drive everything was perfect. 2 days later, early in the morning setting off to work, the clutch judders, not as bad as my f20 but judders on take off in 1st gear. I genuinely felt like someone just kicked me in the balls. I've been driving it for 2 weeks now, took it to a dealer on monday for diagnostics but unfortunately this judder comes and goes and it doesn't happen when car is warmed up. So they said they couldn't feel anything. I would have to leave it with them overnight but even then there's no guarantee it would judder the next day. The other worrying symptom is that when I press the engine start button and the engine is starting, the gearstick shakes a lot (a lot more than on my f20 diesel) and it is rather loud and it sounds and feels like something is knocking underneath. Once the engine is running it's quiet and ok although the gear stick seems to be shaking a bit (a bit more than my f20 again). I have 3 months warranty on this car and I don't know what to do. I am worried that this could be the DMF and if they don't diagnose it and fix it before my warranty ends I will be in shit. Any suggestions or ideas??? Thanks! |
03-12-2020, 07:42 AM | #18 |
Rep 104
This is one of the reasons I was pushed towards automatics and now I wouldn't look back as two BMWs I had before both experienced this and I felt on a "luxury" car brand it should be a smooth and nice experience driving but in stop start traffic it was a nightmare as the clutch got hotter it got worse I hated it so I feel your pain
Matt. |
03-12-2020, 08:17 AM | #19 |
Rep 810
My Z4 used to have judder when cold. BMW fit a "clutch delay valve" to them to prevent the drive-train shock (i presume). After removing the valve it was night and day better. I would suggest looking into removing it.
Mr's has a F20 1-Series manual and is just the same. Virtually impossible to set off and do a 1-2 shift without judder and bouncing. |
03-12-2020, 08:31 AM | #20 | |
Rep 320
It just shocks me because I've been doing a lot of reading for the past couple of days and a lot of people say that this is quite normal. I find it hard to accept that this is normal. I've only ever had manual cars and the only time I came across this kind of problem was when I got my first bmw f20. |
03-12-2020, 08:32 AM | #21 | |
Rep 320
03-12-2020, 10:28 AM | #22 |
Rep 115
Just to chime in that my E91 320d juddered when setting off from cold. I learned to live with it. Didn't get any better or worse over 4-5 years of ownership but outside temperature/moisture seemed to affect it.
