03-28-2023, 01:04 PM | #1 |
Rep 24
coding new SZL in E-SYS
Hi
I’m pretty new to coding so wanted a simple step on how I can code the LCI stalk into my pre LCI F33 Everything works except the indicators that don’t turn off with the turning of the steering. I also wanted to calibrate the steering sensors before I actually started driving it but the option was not available Any help direction on what I need to do I much appreciated A simple step by step would really help |
03-29-2023, 03:00 AM | #8 |
Rep 218
You have it in ISTA fault code 030351 wrong LIN.
You cannot VO code the LCI SZL as your car is telling the system its pre LCI. You need to FDL code the SZL in the FEM. And here it becomes a litle bit dificult as the LCI ones is not self explaining as the pre LCI. Cant remember the code you need but somting like ?????2 ending at 2 |
03-29-2023, 03:59 AM | #11 |
Rep 24
Thank you Siki78
You really took the time out today and resolved the issue for me where I installed a pre LCI stalk on my F33 and installed a LCI stalk giving me an error for invalid version installed I can’t thank you enough 🙏🏽 |
09-15-2023, 06:16 PM | #12 |
Rep 30
Drives: 2018 BMW F30
Hello,
I have installed the pre-lci steering column stalk on my 2018 F30, but the indicator does not function for long press. Can you help me choose the correct code? |
01-07-2024, 05:22 AM | #13 |
Rep 6
Hello, I have the same problem as kav247. I installed an LCI SLZ in a preLCI. Everything coded and now I have error 030351.
Everything works except that the turn signal doesn't go off when you steer back. @Siki78 can you maybe help me too? or write what I need to change? Unfortunately that's not clear from this thread. @Kav247 maybe you can help me? Siki helped you. Maybe you still know the solution. I am thankful for every help. |
01-07-2024, 05:29 AM | #14 |
Rep 24
Hi
Unfortunately Siki did this for me remotely as I don’t have the correct software I am hoping he can reach out to you and help you as he was amazing resolving my issue |
01-07-2024, 05:34 AM | #15 | |
Rep 2,046
01-07-2024, 05:47 AM | #16 |
Rep 6
Which Lin variant should I use? I think there are 5 or 6
Do you perhaps have the correct coding value? CODDT_Byte_00_SLZ_Lin=LHZ_active LIN_Variant_LRE=lre_tcl_lhz LIN_Variant_SLZ=slz_4Band LRE_Verbaut=active I coded that Do you recognize an error? |
01-07-2024, 06:01 AM | #19 |
Rep 6
01-07-2024, 06:08 AM | #20 |
Rep 591
Vo code fem with you original vo then change LIN_VARIANTE_SZL
Same like you have just to have r Example if you original is szl_aic_4Band change to szl_r_aic_4Band
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
01-07-2024, 06:15 AM | #21 | |
Rep 6
Ok, I'll try it and get back to you. Thank you in advance. In any case, an SLZ from the LCI 2020 works in the preLCI from 2012 + steering wheel heating |
