BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > 335i EWG Pulling Timing
      11-28-2020, 03:56 PM   #1
SlumpLord3000
Drives: 335i 2014 x Drive Luxury
I have a FBO 335i EWG. Charge, boost, 5" FMIC, DV+, Catless DP. I have replaced spark coils and I replaced Bosch spark plugs with Bosch spark plugs gapped at .03. The timing is all over the place and I think I'm getting micro-knock.
Would NGK 2 step colder @ .024 - .022 would solve my issues?
Also is 0.1/0.2 knock a micro knock?
I didn't do WOT because it's already pulling timing in regular driving.
Any advice is welcome.
Stage 2 - 93
https://www.bootmod3.net/log?id=5fb8...0b43791b7e80c0
https://www.bootmod3.net/log?id=5fb8...0b4379a0d81037
https://www.bootmod3.net/log?id=5fb8...729b32856eb2d4
Stage 2 - 91
https://www.bootmod3.net/log?id=5fbe...90c61927713bab
https://www.bootmod3.net/log?id=5fbe...90c61897db89c6
2014 335i xdrive Luxury |VRSF 5" HD FMIC|AA catted DP|FTP Charge & Boost pipe|GFB DV+|BM3 STG 2|XHP STG 2|Afe Scoop|Match UP 7BMW amp|NGK 2 Step Colder(.024gap)|Dinan Ignition Coils|Weichers Steel Strut Bar|Michelin A/S 3+
      11-28-2020, 05:19 PM   #2
Munchi435i
Munchi435i's Avatar
Drives: 2014 Alpine White 435i M-sport
Stage 2 - 93
Stage 2 - 91
None of those logs help tell us anything. You need to do a 4th gear pull starting from 2500 rpms to 6500 rpms. But if you are 6speed Manual trans then do a 3rd gear pull. Do some searching in this forum for logging tips. thejeremyman9 wrote an extensive post on how to log and how to read a log. Please read all the information thats available to you and then post some proper logs for us to give you proper feedback.
      11-29-2020, 07:20 AM   #3
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Stage 2 - 93
Stage 2 - 91
everything you're seeing is normal. timing is never a consistent thing, its fluid at partial throttle. so during normal driving its going to be all over the place.
so get the thought of something being wrong out of your head and move on to WoT runs and let's take a look then.
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      11-29-2020, 08:00 AM   #4
nabil123
Drives: 2013 335i e93
I got nothing
      11-30-2020, 12:18 PM   #5
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
For OP, here is my thread/post to read:
https://f30.bimmerpost.com/forums/sh....php?t=1732327
Give it a good read through, maybe twice, then come back with 1-3 WOT pulls in 3rd/4th gear as described there.
      05-01-2021, 06:58 PM   #6
SlumpLord3000
Just a follow up. I got NGK 2 step colder plugs put in (.024 gap). They resolved my issues.
Here's a log Stage 1 91 Octane Bootmod
https://www.bootmod3.net/log?id=608d...729b364fde9c87
      05-02-2021, 03:09 PM   #7
thejeremyman9
4364
How can you tell anything from this log? Also, this is stage 1 and the original logs were stage 2? How do you know the plug change "fixed" anything?
I'm not saying they can't make a difference, but want to understand why you think the plug change was responisble for what you are seeing, since most people dont need or even want to use those plugs and a smaller gap, especially on stage 1.
n55david1295.50
      05-06-2021, 06:08 PM   #8
SlumpLord3000
I was getting 0.1-0.2 micro-knock I guess at high boost. In the new driving log you can see I did 4th gear all full throttle to 14psi and I got 0 knock.
Can't do stage 2 because I got my stock cat installed. I will do Stage 1 93 tune tomorrow.
https://photos.app.goo.gl/nEhymSMcC47DXHnu5
      05-06-2021, 07:23 PM   #9
thejeremyman9
4364
I guess i am just confused because you posted stage 2 logs initially, then posted stage 1 logs later after the plug change, and concluded that the plug change "fixed" the issue? It could have been other things, though? Different gas? Colder IATs? Correlation doesnt equal causation. Also the different stage tune?
I'm glad you arent getting knock just not sure how you can conclude the plug change was the reason when there appears to be several other variables lol.
      05-07-2021, 06:05 PM   #10
SlumpLord3000
Yeah i went from standard Bosch gapped at .03 to 2 step colder NGK gapped at .024 like BM3 recommends. I was getting micro knock even at stage 1. If you read from the beginning I got all the details on the plugs.
Also I read thru the forums and nobody mentions microknock and what 0.1 knock means. I'm guessing it's microknock. That's why I'm posting my experiences hope it helps someone.
BM Stage 1 93 Octane tune 4th gear pull today:
https://www.bootmod3.net/log?id=6095...729b602cd333d2
      05-08-2021, 12:11 PM   #11
thejeremyman9
4364
Yeah i know what BM3 recommends and the recommendation is, in most cases, unnecessary. Especially for stage 1. But everyone's car responds differently. You still have pretty bad timing corrections after like 4500 rpm so i dont think the plugs "fixed" anything.
      05-08-2021, 08:41 PM   #12
TSA8151
Drives: 2013 F30 335i msport
Try an ACN map and see if that fixes timing
      05-26-2021, 10:10 PM   #13
SlumpLord3000
It's a daily with no knock or 0.1 knock or anything. I'm ok with little pull, I don't track it or do OWT over 1 second since I'm mostly driving at 30 PMH in the city(NYC) or cruising. I don't see a big deal with stage 1. Once I put in a better cat like the Wagner Sport pipe with cat and do stage 2 again, then I will revisit the issue if it comes up. Thanks for all the help guys. Much appreciated.
bm3, bootmod, bootmod3, knock
