BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Simple (rear) side to side Wheel rotation/swap
      09-24-2021, 08:54 AM   #1
sspade
sspade's Avatar
2016 BMW 320i  [0.00]
2014 BMW 328i  [5.00]
Can rotate rear wheels side to side in under 10 minutes with this bottle jack, most helpful for those running a staggered setup. Please note: I would not work under the car or perform any jarring maintenance/repair with the car suspended like this. On a flat surface however, it is perfectly safe for a quick rotation or wheel swap.
Wondering if anyone knows of something similar to a bottle jack with a very low profile to fit under front central jacking location?
The point here is easy mobility and general compact size (not a trolley jack or stationary garage jack).
BimR180.00
      09-24-2021, 09:01 AM   #2
BimR
Drives: 2016 328
I can't answer your question but this is very convenient for small things that need to be done but not to get under car. Cool!
sspade1087.50
      09-24-2021, 09:12 AM   #3
Wires
Drives: 2016 340i xDrive
No clue on the front. I have a pretty low profile floor jack, and that doesn't fit under my front. Need to use the side jack points.
Just a FYI for others trying the single rear approach, my rims are always corroded around the wheel hub when I swap my summers for winters. They never just fall off, and require some pretty substantial "abuse" to break them free. I would never try that with a single bottle jack.
sspade1087.50
      09-24-2021, 09:42 AM   #4
sspade
sspade's Avatar
This is a good point, for sure.
Im in a warmer climate currently and even when I was out west in the snow, had my wheels off enough to not have a ton of corrosion (every 5k miles).
I still do have to give mine a gentle mule kick (standing backwards) to get them off... full disclosure.
If that did not work, I agree with you... STOP and bring the car down. Not worth going full retard mode and making a mess!
      09-24-2021, 02:43 PM   #5
Wires
I should add what I've did in the past for the front is to jack up one side, but a couple pieces of 2x6's under the that wheel, let it down, and then I can use my floor jack on the center front jacking point.
Sort of a PITA, but works when I need to.
      09-24-2021, 03:10 PM   #6
Psi5
Psi5's Avatar
Drives: 2020 BMW F32 440i
I had that rust issue too until I started using anti-seize on the hubs when I swap summers and winters. Just a thin film around the hub is all it takes. Note - use a non-metallic scrubbing pad to knock off any rust and clean the hub before applying.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Now they come off with no effort. This stuff is terrific and a lifesaver if you swap wheels and live where hub corrosion can be an issue.
Garage:
2020 F32 440i 6MT
2018 Mazda 3 6MT
2013 Mazda 3 6MT
2008 Honda Oddyssey
sspade1087.50
      09-25-2021, 05:01 AM   #7
njdangelo
njdangelo's Avatar
302
Drives: 340i xdrive Msport THP
I have a low profile jack that fits under my front and rear no problem. It is 3" high when not active. Car is lowered on dinan springs/bump stops too. Pretty sure it's this same model although i got it about 5 years ago. It's been great, no complaints. Once you jack the car up, slide in your esco jack stands and you're good to go.
https://www.harborfreight.com/3-ton-...ack-56617.html
340i Xdrive Estoril Blue II - Track handling package - Dinan springs/bumpstops - Remus exhaust - AP intake - CTS Turbo Catted Downpipe - BM3 stage 2 - XHP Stage 3 - Carbon fiber interior trim
      09-25-2021, 09:21 AM   #8
Wires
That was my genius plan AFTER I put all 4 summers back on! I'm muttering to myself why BMW has rims and hubs that have galvanic corrosion and bond, while having a jar of anti-seize on the shelf right next to can of fluid-film.
Winters need to go on in the next couple of weeks, so that will be the plan this time. Wire brush the hubs, put on some anti-seize, and then I can eliminate the "mule kick" to get mine off!
