09-24-2021, 08:54 AM | #1 |
Rep 5,456
Drives: F30
Simple (rear) side to side Wheel rotation/swap
Can rotate rear wheels side to side in under 10 minutes with this bottle jack, most helpful for those running a staggered setup. Please note: I would not work under the car or perform any jarring maintenance/repair with the car suspended like this. On a flat surface however, it is perfectly safe for a quick rotation or wheel swap.
Wondering if anyone knows of something similar to a bottle jack with a very low profile to fit under front central jacking location? The point here is easy mobility and general compact size (not a trolley jack or stationary garage jack). |
09-24-2021, 09:12 AM | #3 |
Rep 4,876
No clue on the front. I have a pretty low profile floor jack, and that doesn't fit under my front. Need to use the side jack points.
Just a FYI for others trying the single rear approach, my rims are always corroded around the wheel hub when I swap my summers for winters. They never just fall off, and require some pretty substantial "abuse" to break them free. I would never try that with a single bottle jack. |
sspade2464.50 |
09-24-2021, 09:42 AM | #4 | |
Rep 5,456
Drives: F30
Im in a warmer climate currently and even when I was out west in the snow, had my wheels off enough to not have a ton of corrosion (every 5k miles). I still do have to give mine a gentle mule kick (standing backwards) to get them off... full disclosure. If that did not work, I agree with you... STOP and bring the car down. Not worth going full retard mode and making a mess! |
09-24-2021, 02:43 PM | #5 |
Rep 4,876
I should add what I've did in the past for the front is to jack up one side, but a couple pieces of 2x6's under the that wheel, let it down, and then I can use my floor jack on the center front jacking point.
Sort of a PITA, but works when I need to. |
09-24-2021, 03:10 PM | #6 | |
Rep 259
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 Now they come off with no effort. This stuff is terrific and a lifesaver if you swap wheels and live where hub corrosion can be an issue.
Garage:
2020 F32 440i 6MT 2018 Mazda 3 6MT 2013 Mazda 3 6MT 2008 Honda Oddyssey |
sspade2464.50 |
09-25-2021, 05:01 AM | #7 |
Rep 844
I have a low profile jack that fits under my front and rear no problem. It is 3" high when not active. Car is lowered on dinan springs/bump stops too. Pretty sure it's this same model although i got it about 5 years ago. It's been great, no complaints. Once you jack the car up, slide in your esco jack stands and you're good to go.
https://www.harborfreight.com/3-ton-...ack-56617.html
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
09-25-2021, 09:21 AM | #8 | |
Rep 4,876
Winters need to go on in the next couple of weeks, so that will be the plan this time. Wire brush the hubs, put on some anti-seize, and then I can eliminate the "mule kick" to get mine off! |
