BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > N47 used oil analysis w/ TBN
proTUNING Freaks
      06-13-2019, 05:44 PM   #1
328iX
David
328iX's Avatar
Drives: 2015 328iX F31
Oil is newer spec BMW LL-12FE 0W-30 changed at the dealership, i'm guessing the paper that was found in the oil came from them as the sample was taken from a new bottle mid drain. TBN surprised me, that's pretty good for 5,000 miles, meaning it could do 10k+ no issue.
Additive explanation:
Molybdenum & zinc found in the oil are anti-wear additives
Calcium & phosphorus are the detergent additives
      06-13-2019, 06:34 PM   #2
FaRKle!
Drives: '17 328d Wagon, '21 M2 Comp
That also confirms that LL-12FE is a lighter weight oil than LL-04. Viscosity numbers for LL-04 are 57-65, and 9.4-11.9.
At 5k mi wear, your LL-12 was already lighter than the minimum LL-04 spec.
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
POBEP57.50
      06-13-2019, 06:39 PM   #3
328iX
David
328iX's Avatar
What grade of LL04? I thought LL04 that BMW ran was 5w-30?
I'm currently running Pennzoil 5w-30 LL04 and will do a test on that too in about a month.
      06-13-2019, 06:45 PM   #4
FaRKle!
5w-30 LL04, but it shouldn't matter since both 0w-30 and 5w-30 are 30 viscosity at 100C. Clearly one is "less" 30 viscosity than the other...
      06-13-2019, 06:50 PM   #5
328iX
David
328iX's Avatar
True but when i drain a 0w-30 vs 5w-30 the 0w-30 always looks thinner so it's no surprise to me, same goes for 5w-30 vs 10w-30
      06-13-2019, 07:01 PM   #6
FaRKle!
So if your oil's viscosity doesn't fall within the SAE spec for that weight oil you're fine with it?
      06-13-2019, 07:13 PM   #7
328iX
David
328iX's Avatar
No, I'm saying it's always been common sense to me that a 0w-30 will be thinner than 5w-30 at 210F based on what I've noticed over hundreds of oil changes.
I always drain hot and a 0W-30 it always visually thinner than 5w-30, i'm not ok with it, hence why i always do 5k intervals.
Even cold flow is visually noticeable, you pour in a 0w-20 it's thinner than 0w-30, they're both 0w oils cold. I don't understand how the scale works or what the tolerances are.
Lastly, I always prefer 5w-30, I'm in california just like you, 0w-30 is unnecessary, but my oil changes are free until 75k miles, and I go in just to get it documented for carfax and BMW maintenance records
      12-19-2020, 09:05 PM   #8
POBEP
POBEP's Avatar
Drives: E70 X5 xDrive35d
FaRKle! 328iX - my first post-warranty oil change is coming up on MY2016 F25 28dX.
While the manual calls for 0W30 LL12FE, it is my understanding that 5W30 LL04 would be better choice for N47 engine that never see ambient startup temps below 0C.
Did I get it right?
      12-20-2020, 12:52 AM   #9
328iX
David
328iX's Avatar
Did I get it right?
Yeah I would agree. If you're in a warmer climate that's what I would prefer.
POBEP57.50
      12-20-2020, 11:14 AM   #10
catskillclimber
Drives: 328d
was your EGR cooler replaced under the recall?
      12-21-2020, 08:58 AM   #11
eugene89us
Drives: 2018 BMW 328d
Will provide my report to the greater community. I run LL12 FE 0W-30 oil currently and have done so since new. Car has 52K miles. Report was run at 49K miles at roughly 9,950 miles on it. Climate in Central MS is quite hot most of the year, but frequently drops to below 0C in winter with infrequent lows between 0C and -10C. Hardly any snow, 0 to 1 day a year.
I am pretty happy with my report after 10K miles. The engine is tolerating well. My car is a garage queen that gets about 15K miles a year, most of it Interstate driving. No heavy driving, I do sometimes haul a trailer from HD or Lowe's. This oil probably had more trailer use than average. If you do spirited driving or track use, you would have to use LL04 for better protection. For me, LL12 checks all boxes and the report put me at relative ease. There is always a give and take with that decision.
      03-02-2021, 07:35 PM   #12
Donnf08
Drives: BMW 328d f30
I been having high sodium in my oil results... has anyone else have this issue?
      03-03-2021, 09:25 AM   #13
andreigbs
Dr Drei
Drives: X3d
'16 X3d  [0.00]
Pretty good results, thanks for doing UOAs and posting them! I typically only see UOAs at bobistheoilguy, not expecting to find them here.
I'll be curious what @328iX finds out on the PP Euro L stuff, since I've used that oil before. Currently running Motul X-Clean+
X3 x28d // 70xxx miles // 34 MPG // Motul 8100 X-Clean+ 5w30
GLK250 // 123xxx miles // 32 MPG // Mobil1 ESP 5w30
      03-03-2021, 10:41 PM   #14
328iX
David
328iX's Avatar
Sold the vehicle a long time ago sadly, currently have a N20 .
      03-04-2021, 09:26 AM   #15
andreigbs
Dr Drei
Drives: X3d
'16 X3d  [0.00]
Boo! J/K
I take it you're not enjoying it as much as the diesel then?
      03-04-2021, 12:14 PM   #16
328iX
David
328iX's Avatar
Boo! J/K
I enjoy the engine more, higher redline, more power, etc.
What sucks is I feel it's more unreliable, timing chains already replaced at 40k, turbo went out at 35k, valve cover leak at 35k, direct injection pump replaced at like 45k.
Also mpg went down from 34-36 or so in the diesel to 24-26
Thankfully most of it was under warranty but now I'm skeptical lol.
They both had transfer case replacements tho, my diesel and gas.
      03-05-2021, 10:00 AM   #17
andreigbs
Dr Drei
Drives: X3d
'16 X3d  [0.00]
Indeed, the transfer case plagues many X models, but especially the diesels due to the extra vibration harmonics. So far so good on the original TC in mine.
Other than maintenance, my X3d has been very reliable with no unscheduled repairs.
The fuel economy was the main reason I bought it since I was doing a 200 mile daily commute pre-COVID.
In my neck of the woods, diesel BMWs are unicorns. I haven't seen another except very rarely, on road trips.
