10-02-2021, 11:15 AM | #1 |
Rep 148
How the heck do I install this boost tap?
I bought this boost tap "P3 Boost Tap - BMW B48/B58' and I expected it to tap into the hose closer to the charge pipe but still on manifold.
Instead I got this item (https://cdn.shopify.com/s/files/1/00...g?v=1630091748) which looks like it taps closer to the manifold here (https://cdn.shopify.com/s/files/1/00...g?v=1630091752). I can't tell if it's tapping into the bottom or the right hose based on the picture. And I'm not sure how to take these off. I see some clips I can push in but I'm not sure if I have to do anything before that. I always disconnect the battery. I doubt there'd be any pressure in here but just wanted to confirm with someone. |
10-03-2021, 12:18 PM | #2 |
Rep 148
Update: It's definitely the right most hose in the picture as I suspected. The product obviously inserts in the middle. I had my battery out but I doubt that's required.
10-04-2021, 11:18 AM | #3 |
Rep 599
Is there a reason why you are using the add-on boost tap? P3 can read boost from OBD port. Only reason I can think to use the add-on boost tap is if you are using a JB4 since the OBD would report stock boost levels and not true boost levels that the JB4 is making.
10-04-2021, 04:21 PM | #4 | |
Rep 148
10-04-2021, 05:27 PM | #5 |
Rep 11
My P3 boost tap for a 2017 B58 goes into inlet manifold under other end of that plastic vent pipe immediately downstream of throttle body. Doesn't seem to be much happening in that vent pipe as I get exactly the same pressures on gauge whether vent pipe is sealed closed or remains open as original. So your tap should work the same even though it is in other end of the same vent pipe. Well advised to disconnect front end of vent pipe and unclip it from mount on manifold to raise it up then squeeze those clips to pull it out.
10-06-2021, 07:37 PM | #6 | |
Rep 4,876
OP, for me, I bought the BMS meth spacer which mounts between the charge pipe and throttle body, and then plumbed the P3 into that. Only "downfall" on the B58, is you cannot get a vacuum reading, only boost reading when doing it this way. On my E90, I "t'd" into the line off the turbo, and you got both. |
10-07-2021, 04:48 PM | #7 | |
Rep 148
problem with taking boost reading from that for meth is that you'll get meth spraying when you don't want it. For example, when throttle closes boost will spike there in the charge pipe. |
10-07-2021, 04:54 PM | #8 |
Rep 11
Hi Wires.
On my install, as stated above with boost tap immediately downstream of throttle body I see only the most minute vacuum if any at all. Even when diving down the side of a mountain in a lower gear with closed throttle there is virtually no vacuum. I've been told that the throttle just swings wide open the moment the start button is pressed and remains that way till switch off. Apparently Valvetronic is what dictates the air into cylinders and can vary from 0.2mm to something like 9mm at full lift. And so there is no vacuum in inlet manifold ever. Interesting. |
10-07-2021, 04:59 PM | #9 |
Rep 4,876
I should have clarified I don't run Meth, I just use their spacer since it allowed me a boost tap port.
FalconAus Where did you tap off for your setup? When I was looking a couple years ago, I couldn't find a spot, hence why I put the meth spacer between the charge pipe and the throttle body. |
10-07-2021, 07:07 PM | #10 |
Rep 11
Ordered P3 boost tap. It is sandwiched under the coupling of plastic pipe that enters top of inlet manifold immediately behind (downstream) of throttle body. It does raise that plastic pipe up about 10mm so it does very slightly raise the engine cover. I don't use engine cover as it seems to cause more dust to settle on engine than when it's removed.
Boost tap is well designed with an "O" ring seal as original bimmer part. |
