05-05-2016, 03:55 PM | #1 |
Rep 201
Replace 4 tyres on xdrive?
Is it necessary to replace all 4 tyres on an xdrive if you have only 1 or 2 worn?
I'm sure I read a post on here to that effect. |
05-05-2016, 03:57 PM | #2 |
Rep 588
05-05-2016, 04:10 PM | #4 |
Rep 201
Well that was my thought as it isn't a true 4 wheel drive.
On the Calibra...I had a 4x4 turbo when I was about 23. It had a switch which toggled something that made it 2wd (so the garage told me). It was wild and I owned it for 3 weeks and nearly crashed twice in it...very scary. It went into the same garage that sold it to me to fix the speedo cable. Garage went on fire over the weekend. Car had been due back to me on the Monday but they called me to say it was a charred shell. Think that was an omen |
05-05-2016, 04:13 PM | #5 | |
Rep 32,881
I would just change them in pairs on same axle, as you would on any car. |
05-05-2016, 04:15 PM | #6 |
Rep 201
05-05-2016, 04:19 PM | #7 |
Rep 32,881
05-05-2016, 04:40 PM | #9 |
Rep 3,664
When I was getting px values for my 435d one of the things that the dealer was interested in was tread depths. Apparently, tyres have to be within 2mm of each other otherwise they would need to change all 4 before they could sell it as an AUC.
I took it with a pinch of salt until the second dealer said the same :
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 |
05-05-2016, 04:48 PM | #10 | |
Rep 32,881
05-05-2016, 04:49 PM | #11 | ||
Rep 3,664
Current: M4 G82
05-05-2016, 04:53 PM | #12 | |
Rep 5,681
05-06-2016, 02:14 AM | #13 | |
Rep 2,060
Was the turbo version just badly set up or was it a combination of things that made it bad? |
05-06-2016, 02:16 AM | #14 | ||
Rep 2,060
I can only think because the fronts do the steering they probably get more wear but I'm no expert. |
05-06-2016, 02:27 AM | #15 | ||
Rep 32,881
05-06-2016, 03:25 AM | #16 |
Rep 3,068
On some 4x4 systems you have a tolerance in tread depths front to rear, if this is too great the rotation of the smaller diameter is greater and as a result will 'windup' the centre diff causing problems. If you have a clever system where you can change the bias front to rear then I believe it doesn't matter.
05-06-2016, 03:30 AM | #17 |
Rep 4,935
Drives: 340i MPPSK
That just means they're both crooks
Life is a state of mind |
05-06-2016, 03:58 AM | #18 |
Rep 9,709
There is a wet clutch in the transfer case. If both front and rear axles are turning the same speed, there is no slip on the clutch.
If there are different axle speeds the clutch is continuously slipping which will wear it out over time. The bigger the difference the more wear takes place. So it is advisable to have similar rolling radius front and rear, but as BMW have chosen to fit staggered tyre sizes that aren't equal in the first place, they are obviously not that concerned. |
05-06-2016, 04:07 AM | #19 | |
Rep 2,511
I thought 4WD systems had to be fixed or mechanically variable and possibly even have locking diff's. AWD systems are the electronically variable ones... Clutches vs diff's. Just being pedantic. (And, hopefully correct)
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
05-06-2016, 12:58 PM | #20 | |||
Rep 2,060
2k?? Glad I never got one..... I do recall at the time the motoring press didn't seem that impressed. Do still see them very occasionally but almost unrecognisable due to the industrial strength chav makeover they appear to have gone through. |
05-06-2016, 01:47 PM | #21 | |
Rep 201
Is the power distributed evenly to each wheel on a conventional 4 wheel drive? On the xdrive is it biased to the rear or actually always fluctuating so never locked at equal portion to the corners? |
05-06-2016, 01:56 PM | #22 | |
Rep 32,881
"Four-wheel drive, 4×4 ("four by four"), 4WD, and AWD is a form of drivetrain capable of providing power to all wheel ends of a two-axled vehicle simultaneously. It may be full-time, or on-demand, and may be linked via a transfer case to provide multiple gear ranges." And xdrive is the full time full time type, unlike my sister's Rav4 which is two wheel drive unless their is wheel slip or at under 20mph you press the 4WD button. |
