04-03-2022, 03:58 PM | #16149 | |
Rep 12
Brandon |
04-03-2022, 04:03 PM | #16150 | |
Rep 40,761
AMPLIFIER_VARIANT AUDIO_SYSTEM
04-03-2022, 06:06 PM | #16151 |
Rep 12
04-03-2022, 06:16 PM | #16152 |
Rep 12
04-03-2022, 10:36 PM | #16153 |
Rep 12
Checked my car with bimmerlink and amplifier has 0 errors, but headunit is showing 2 errors. Think my next steps going to be buying bimmerlink and finding out what those errors are. Hopefully lead me to my no audio issue. As I stated before, this car was a mechanic special so I have no idea what issues it had prior to owning it =/. Appreciate your help Shawn
04-03-2022, 11:10 PM | #16154 | |
Rep 40,761
04-06-2022, 02:01 PM | #16155 |
Rep 12
Afternoon Shawn! So I just got back from the local import shop and what they've found was the front electronic module is throwing 250ish faults with their scanner(they tried to clear the faults but were unsuccessful)and suggest starting there. I asked if it's possible for me to order and program this myself and they suggested not to and go to the nearest bmw dealership. Well that's 3 hours away in Minneapolis =/. So my question is. IS this something I could possibly do myself with esys or would you also suggest taking it to a dealership?
I'm planning on getting down there and checking all the wiring/fuses etc just to be safe prior to making a decision of course. They say these are notorious for getting wet due to their location. Thank you, Brandon |
04-06-2022, 03:07 PM | #16156 | |
Rep 40,761
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 04-06-2022 at 04:45 PM.. |
04-06-2022, 06:31 PM | #16157 |
Rep 12
Thank you Shawn! I just wanted to take the time to tell you thank you so much for all you do for everyone here, and on other bmw websites. Your comments on alot of other people's posts have helped me figure out alot with my newly acquired f30
04-06-2022, 06:35 PM | #16158 |
Rep 40,761
04-13-2022, 04:27 PM | #16160 |
Rep 153
Hi Shawn,
I have a 2015 F36 420d. Which is currently the right combination of E-sys version and psdzdata lite? I coded some things some years ago and I would like to retake the coding ;-) But what I have installed does not work. Should I uninstall what I have first? Thanks! |
04-13-2022, 05:10 PM | #16161 | |
Rep 40,761
05-24-2022, 02:44 AM | #16163 |
Rep 38
Thinking about getting into coding my vehicle. I’m in the UK and have a 2016 F30 320i. I’ve just ordered an enet cable…..what else do I need? Just esys and data files? Would someone be kind enough to point me in the right direction. Thanks.
05-24-2022, 05:47 AM | #16164 |
Rep 40,761
PM sent.
06-01-2022, 07:44 AM | #16166 |
Rep 40,761
PM sent.
06-03-2022, 10:39 AM | #16167 |
Rep 3
Hi Shawn.
Reading through this you seem to be the man. I replaced my valve cover, coil packs, spark plugs, and crank case vent tube. After replacing I have a permanant code that won't go away even with the battery dme reset procedure. Car will start and rough idle a few seconds at start up but then runs fine after just with no power due to being in limp mode. I believe it has to do with a vannos issue that was corrected with a service bulliten update. Is ESYS able to do this? I already have an wireless OB2 adapter and bimmerlink and bimmercode which has an ethernet port. |
06-03-2022, 10:46 AM | #16168 | |
Rep 40,761
06-03-2022, 11:42 AM | #16169 | |
Rep 3
Do you know of a good place to get this? I can find it online but if you have a recommendation for a reliable source that would be great. I found a local shop that has one but I can't get in until two weeks out and the closest BMW dealer is 2 hours away so I'm trying to see if I can fix it myself and cancel the appointment. |
06-03-2022, 12:17 PM | #16170 | |
Rep 40,761
