09-29-2020, 04:08 PM | #1 |
Rep 13
Welcome Rear Lights soft on/off
Hi Guys
Anyone know what I need to change via Bimmercode to enable soft on/soft off for the rear lights? Also would like to enable to same for the number plate light. Thanks |
09-30-2020, 12:07 PM | #2 | |
Rep 332
Expert Mode Rear Electronic Module 3062 LceLampMapping1 Number Plate Light MAPPING_KENNZEICHENL_PART_OF_WL soft_on Rear Lights MAPPING_STANDL_H1_L/R_PART_OF_WL soft_on MAPPING_STANDL_H2_L/R_PART_OF_WL soft_on |
09-30-2020, 05:45 PM | #3 |
Rep 13
Hi CJN. I changed what you recommended. I she. The LCI lights and the outer light is hard on and off. The inner light and I believe the brake light are soft on and off. The number plate light also is hard on and off. Any ideas?
10-01-2020, 04:03 AM | #4 |
Rep 332
Sorry, that's all I know. I don't have the car any more so that's the limit of my knowledge. Good luck with it.
10-03-2020, 02:01 PM | #6 | |
Rep 30
Had the same problem with my lci, finally found the solution in: REM 3063 LceLampMapping2 MAPPING_SMALL_SL_L_PART_OF_WL not_active = 00 MAPPING_SMALL_SL_R_PART_OF_WL not_active = 00 MAPPING_UNIVERSAL_1_PART_OF_WL not_active = 00 Last edited by bringmywallet; 10-04-2020 at 02:51 AM.. Reason: adding quote |
10-04-2020, 08:49 AM | #8 |
Rep 13
It worked. Thanks alot. Do you know how I can get the front lights to be soft off, they are currently soft on?
10-04-2020, 03:09 PM | #11 |
Rep 30
Sorry, i don't have the side lights, so no experience with that.
I just switched off the dipped beams at welcome lights: FLE -> 3000 -> WELL_LED_INSC_EIN -> 0 FLE -> 3000 -> WELL_LWR_INSC_EIN -> 0 |
10-04-2020, 04:36 PM | #12 |
Rep 13
Sorry. When I mean side lights I mean the front led rings on the LCI
10-07-2020, 08:45 AM | #14 |
Rep 13
10-14-2020, 02:51 PM | #17 |
Rep 13
