BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > F30 328i XDrive 193 Wheels?
      04-20-2020, 12:58 PM   #1
jishent
Drives: BMW 2014 328i xDrive
Hello all,
I just wanted to double-check what I gathered around from other threads around 193 e90 wheels on F30 xDrive (below).
If I use 225/45-18 front and 255/40-18 rear tires (F30 default xdrive staggered setup) with 193 wheels it wouldn't wreck the xDrive nor give me phantom miles...Is that correct?
Thread 1
Thread 2
Thread 3
      04-20-2020, 01:13 PM   #2
alohasurftoad
225/45/18, 255/40/18 are tire sizes BMW uses on OEM staggered fitments for X-drive or RWD.
      04-20-2020, 03:03 PM   #3
jishent
Apologize if this is a noob question,
If the OEM Offset for the rear is ET 47 and the 193 rear are ET37 would that affect anything?
To my knowledge that would mean 10mm more inside clearance with the 193 and 10mm more protrusion to the outside. Not sure if it affects the xDrive.
      04-20-2020, 06:59 PM   #4
alohasurftoad
If the OEM Offset for the rear is ET 47 and the 193 rear are ET37 would that affect anything? To my knowledge that would mean 10mm more inside clearance with the 193 and 10mm more protrusion to the outside. Not sure if it affects the xDrive.
that is correct. +37 equals adding a 10mm spacer to +47. it does not affect x-drive. it affects the suspension geometry a little. but nothing you'll notice or need to be concerned with.
      04-20-2020, 07:52 PM   #5
jishent
Awesome, thank you!
      04-22-2020, 03:30 PM   #6
draggy
sucka for a longroof
29
Drives: F31
Might want to consider this post in your link to Thread # 1 if you have M Sport calipers.
      04-24-2020, 09:44 AM   #7
jishent
I don't have M Sport Calipers so it should be fine right?
      04-25-2020, 01:16 PM   #8
draggy
29
Drives: F31
should be OK with base brakes
      05-15-2020, 04:00 PM   #9
jishent
End result
      01-18-2022, 11:34 AM   #10
Shaz25
Drives: Bmw 328i Xdrive
@jishent
Hey I was literally looking to do the same thing to my F30, I know someone selling those wheels. I just had all types of questions, did they fit good? Any issues? Anything I need to know. I wanted to go for a squared setup instead. Also I heard there's a bolt difference was that an issue?
      02-02-2022, 02:36 PM   #11
Jem55
Jem55's Avatar
Drives: BMW 328i xDrive
Thumbs up Looks great!
Recently went with Apex Arc-8s and took a few days but they grew on me and I like them a lot now.
193 wheels, f30, tires
