12-07-2020, 03:25 PM | #1 |
Rep 19
Condensation in Headlights - 2018 F36 440i GC
Hi can anyone tell me if this amount of condensation in my headlight housing is normal, and if not, can this be replaced under warranty by the dealer?
I noticed the condensation yesterday afternoon and it hasn't gone away on its own even after i took it out for a drive. I also didnt see any cracks in the housing itself. Thanks! [IMG]file:///var/folders/81/0hphp1t51_75gkpffbr8_hj80000gn/T/com.apple.iChat/Messages/Transfers/IMG_4281.jpeg[/IMG] |
12-07-2020, 03:30 PM | #3 |
Rep 833
Drives: BMW F36, E36, E93
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
12-07-2020, 03:32 PM | #4 |
Rep 19
There is a gas station I go to that uses a pressure washer hose, but last time i did that I didnt see any condensation inside the housing. I rinsed the car with a normal hose two nights ago and thats when I noticed condensation the next day.
12-07-2020, 03:34 PM | #5 |
Rep 92
12-07-2020, 03:36 PM | #7 | |
Rep 92
12-07-2020, 06:21 PM | #8 |
Rep 1,236
How does a pressure washer cause this? Because I'd like to avoid it lol
2023 M2. ZB. Manual.
2024 m235i |
12-08-2020, 04:14 AM | #10 |
Rep 1,508
BMW considers some condensation in headlights normal, esp if it burns off after turning on the headlights. Your experience may vary, they may or may not replace. Check post #9 here...
https://f80.bimmerpost.com/forums/sh....php?t=1346014 |
12-08-2020, 05:25 AM | #11 |
Rep 178
Agree. No pressure washer should be able to cause that. Unless OP didnt try to wash it from inside the engine bay lol. Maybe the lens was very cold and the water in the washer very hot?
12-08-2020, 08:56 AM | #12 | |
Rep 19
12-08-2020, 09:05 AM | #13 |
Rep 1,119
Drives: 2015 BMW 435i Xdrive MSport
Not normal. I'm having yet another headlight put in my car this Thursday for the same issue.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
12-08-2020, 09:33 AM | #14 | |
Rep 833
All the people, I know, who discover the defect use a pressure washer on the car.
Such Fun
12-14-2020, 07:05 PM | #15 | |
Rep 4,876
Heck, if you want to use your logic, then if the car has a defective sunroof seal from the factory, you cannot park it outside -- ever -- in case is rains. |
12-14-2020, 07:33 PM | #16 | |
Rep 833
The logic I am using is that if someone has the defect he might not even know about it and maybe should use a pressure washer to test before running out of warranty. How about that?
Such Fun
12-14-2020, 07:48 PM | #17 |
Rep 327
I think a slight haze/fog from time to time can be considered normal.
But anything beyond that where it is enough to start forming condensate droplets I think there is a hole/opening, however small, where moisture is getting in. |
01-19-2022, 09:27 AM | #18 |
Rep 26
This is unreal. This is a car at BMW I went to look at.
https://i.postimg.cc/3xb2f4bW/61099-...-EEFB81-C4.jpg |
01-19-2022, 06:05 PM | #19 | |
Rep 4,876
01-20-2022, 12:24 PM | #21 |
Rep 4,876
01-20-2022, 06:19 PM | #22 |
Rep 26
