BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Factory OEM F30 Wheels Offsets (18, 19, 20 inch) and Brake Sizes
      04-23-2021, 11:06 AM   #309
Musashi
Drives: BMW 335i XDrive Laguna Seca
Originally Posted by .BMW. View Post
I'm happy to help!
105,000 kms, 40,000kms on Rays, ZERO bends zero dents, that says it all..
      07-14-2021, 08:22 AM   #310
damwie
Drives: G30, F20,
What is the standard ET for F31 ? 17" ?
      07-14-2021, 08:23 AM   #311
damwie
Drives: G30, F20,
What is the standart ET for F31 and F20 ? Is there any difference (17" wheel) ?
      07-27-2021, 09:55 AM   #312
Three20i
Drives: BMW 320i
Hi guys,
I have a 2014 320i M-Sport package with the standard tire size:
225/45/18 Front
255/40/18 Rear
I'm looking to upgrade to:
235/45/18 Front
265/40/18 Rear
Is this possible? It's worth mentioning that I have 12mm spacers in the front and 15mm in the back. Thank you for your help.
2014 BMW 320i | BM3 Stage 2 E30 | eBay Downpipe | eBay Intercooler | Muffler Delete | Rev9 HyperStreet II Coilovers | Full LED Bulb Conversion
      07-31-2021, 03:09 PM   #313
mrdude1
Drives: f30
I'd like to know this as well
      10-05-2021, 03:19 AM   #314
mikko2
Finland
Drives: F30 320ix
F30/F31: 225/50R17 7.5Jx17 ET37
      10-14-2021, 02:08 PM   #315
mustang_
Drives: N55
Can you fit a 18" 8J ET43 square setup on F30/31 (340i)? Would it rub on the shock/spring?
For winter wheels.
      11-13-2021, 12:14 PM   #316
Santi
Santi's Avatar
Drives: 2014 BMW 328i xDrive F30 N20
waddup peeps.
i've never done any tire/wheel upgrades myself, and all my vehicles have been fitted thru the dealers or shops and, i just didn't really pay attention to it.
and now i'm attempting to learn so please bear with with me.
car: 2014 f30 328i xdrive
current: 225/45/r18 91v m+s (summer tires)
i'm also looking for my car's tire/wheel oem spec sheet. i found the user manual so far.
1) what's the widest/narrowest tire/wheel combo i could use without making any mods or adding adaptors etc? looking for the min/max range i guess.
2) winter tires: is it better to have smaller and/or narrower rims but higher tire profiles?
i'll prolly have more question, but i think, item 1 would cover most
thanks peeps.
      01-21-2022, 01:18 PM   #317
Seehorn12
Seehorn12's Avatar
17
Drives: F31 Toyota FJ
@.BMW
Hey, read through ALOT of your tire recommendations but still didn’t find the answer I am looking for. I have a 16 328i xdrive with the track package, m sport etc. Still keeping the orbit 398 wheels and currently have a square set you with 225 run flats. I want the MPSS, how aggressive can I go and stay within the 1% for the xdrive.
Thank you
      03-14-2022, 09:01 PM   #318
Pinhigh73
Drives: 2018 340i xdrive
Thanks all
      03-31-2022, 02:03 AM   #319
remyygaaa@gmail.com
Drives: F30 328i xdrive
Setup front and rear R20 8.5 225/35
Hi all, just want to share my setup front and rear R20 8.5 225/35. (stretch look tires). BMW F30 328i xdrive. No problem with steering. In front abuot 5mm clearance rim from shock abrobber.
P.S. all wheels same ET45.
      04-12-2022, 08:58 AM   #320
BeFitty8_F32
Melbourne Red F32 B58
BeFitty8_F32's Avatar
Drives: 2017 440ixm
I am still slightly confused on my brake package. 2017 440i xDrive M Sport.
Front brakes are Brembo, but gray and unpainted. Rear brakes are single piston gray and unpainted.
Is this the standard brake package? If you upgrade at BMW (M Package), do they only add a painted front set (same caliper type) but upgrade the rears to 2 piston as well?
Currently stock wheels on M Sport 18x8s with Pirellis.
This weekends brake job includes:
Clean and paint all Calipers
Replace all rotors (hoping I bought the right ones since I am still slightly confused)
Replace pads with EDC Reds
Flush brakes
Replace Stock wheels with TSW Tabac 18x9.5 +40 and Michelin SAS3
Photos will come next week
      09-21-2022, 04:44 AM   #321
Krenforum
Drives: BMW F31
Hey guys,
quick question. I have F31/2017, used, got it on 18" BMW 254 wheels (225/45/18). If I understand correctly, this are 8Jx18 ET30. And according to internet I should have 8JX18 ET34.
https://www.alloywheelsdirect.net/bm...254_wheel_3077
https://www.alloywheelsdirect.net/in...ting_chart/bmw
Is this OK? Since this wheels are probably from 5 or 7 series? They are really nice though.
      09-21-2022, 06:47 AM   #322
johnung
Originally Posted by Krenforum View Post
Hey guys,
The BMW 254 wheels are list for the 2016 5-series and a 7-series car. They have the same 5x120 bolt pattern as the stock wheels for your car. The 254 and say the 400M, which may have come with your car, are both 18x8.0" wheels.
In simplest terms, the offset indicates how much the wheel is pushed in or out of the wheel well. So your 254 wheels having an offset of ET+30 means that compared to the 400M wheels with an offset of ET+34, your wheels stick into the wheel well by 4mm more than the 400M wheels.
4mm is tiny, just a little more than 1/8 of an inch. Very difficult to notice and no fitment issues.
There are many articles if you wish to learn more about offset. Here's just one:
https://www.turnermotorsport.com/t-wheel_guide
Tip: when you eventually need new tires consider upgrading to a wider size on the same wheels if you would like better handling and stability. The widest, best handling on an 8" wheel is 245/40-18. 235/45-18 is also an option. The Continental DWS06 Plus is a very popular all season tire.
Hope this helps!
      09-21-2022, 11:19 AM   #323
Krenforum
Drives: BMW F31
Thank you for explanation. For the moment I will keep them. They look awesome..
      11-13-2022, 08:16 AM   #324
smartg
Greece
Drives: f48
2016 f48   [0.00]
      11-20-2022, 09:30 AM   #325
Arthur15
Drives: 340i F31 Xdrive
Hi,
My 340i Xdrive F31 with stock wheels but on square 245/40R18
      12-23-2022, 10:16 AM   #326
Luke330d
Drives: BMW f30 330d xdrive
Angry
does anybody know if these will fit my 2013 f30 330d xdrive? i had a little accident last night and my two front wheels are completely destroyed, ive found somebody selling these i just want to be sure they will fit, any help is greatly appreciated, thank you Luke
Front:
639 19x8 5jj et35
Rear:
639 19x9 5jj et 40
      12-23-2022, 10:39 AM   #327
alohasurftoad
Front:
639 19x8 5jj et35
Rear:
639 19x9 5jj et 40
what is the pcd/cb? if it's 5x112/66.5 they won't fit. if 5x120/72.56, fits
      12-23-2022, 10:55 AM   #328
Luke330d
how do i find out the centre bore? i know its 5x120, thanks so much!
      12-23-2022, 11:42 AM   #329
alohasurftoad
if it's 5x120 it has 72.56cb
      12-24-2022, 02:32 PM   #330
Luke330d
so a quick update! i lost my locking wheel nut key! managed to find somebody to come out and remove them, was expensive (Christmas and all) but i got my old wheels off, now my new wheels when i try to put them on they wont go on the hub properly because the wheels hitting the springs, do i just simply get some wheel spacers or? im new to all the car scene any help would be greatly appreciated as my car is off the road until i can get my wheels sorted thanks for the help!
f30 3 series wheel offset, f30 3 series wheel offsets, f30 328i wheel offset, f30 328i wheels offset, f30 328i wheels offsets, f30 335i wheel offset, f30 335i wheels offset, f30 335i wheels offsets, f30 offets, f30 offset, f30 wheel offset, f30 wheel offsets, f30 wheels offset, f30 wheels offsets, wheel offset f30, wheels offset f30, wheels offsets f30
