01-19-2022, 05:59 PM | #1 |
Rep 60
so i recently got my car back from bmw service for a leak that i noticed on my differential, can anyone explain in simpler terms what they did? Is this a common thing?
01-19-2022, 06:02 PM | #2 |
Rep 558
The pinion seal was leaking, so they replaced it. Everything else on the list is just things they needed to do in order to do that.
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
01-19-2022, 06:03 PM | #3 |
Rep 60
01-19-2022, 07:05 PM | #4 |
Rep 216
I recently had them tell me the same thing. Quoted me 1300 CAN for the job.
Is that reasonable?
2017 340i M Performance Edition: Fashion Grey, MPPSK, M performance front splitter, rear diffuser, side sills, black grille, CF spoiler, 405M 20s, 8AT, full Marino interior and dash, adaptive suspension
01-19-2022, 07:08 PM | #5 |
Rep 60
01-20-2022, 12:20 AM | #6 |
Rep 10,255
01-20-2022, 12:21 AM | #7 |
Rep 60
44k was never tuned or abused
01-20-2022, 06:58 PM | #8 |
Rep 1,452
My passenger side rear diff was leaking under warranty. About 5-10k miles later, the driver side leaks but I was out of warranty. I ordered the new seal and collar nut for about $50 and had a shop do the repair. I paid about $400 for them to replace the seal and drain/fill with diff fluid.
2022 CT4-V Blackwing 6-speed
01-22-2022, 09:41 PM | #9 | |
Rep 216
I currently have about 100,000km on the car so I'm no longer under warranty. I will likely try and find a smaller shop to do the repair for a better price
03-28-2024, 12:04 PM | #10 |
Rep 100
Did you get a solution for this? I was notified last Friday that my front diff pinion seal was leaking and quoted me over $700 for the fix, including a fluid drain and replace. The parts are not expensive and I'd much prefer to do it myself.
03-28-2024, 01:38 PM | #11 |
Rep 1,452
Paddock did mine. They're in Denver. Autosport Werks in Broomfield also do good work and they're relatively affordable. But yeah, you just need the seal and the fluid.
