11-01-2019, 01:41 PM | #1145 |
Rep 18
11-01-2019, 01:46 PM | #1146 | |
Rep 18
I have one more log that was a hard pull in second gear and a shift into third at the link below. There was initial hesitation when I hit the gas in second, a second later it starts boosting. I then shift into third, huge hesitation at the start of third gear before it starts pulling. http://www.bootmod3.net/log?id=5dbad64ac090c63fb7ba59e1 I can generate some new logs if these are no good too. I have a ticket logged with PTF but just wondered if anyone with a brain could help me in the meantime. I'll reiterate that this only happens when I have burbles set to 'OTS', cold start disabled and max cooling mode on. On the base stage 1 91 octane it is fine, no problems. Cheers, Lox |
11-01-2019, 05:55 PM | #1147 |
Rep 797
The max cool mode is pretty cool .. maybe too cool. An in-between setting or being able to pick a number would be great. I'm all for cooler under hood temps but I don't want to burn anything out, not sure if I should keep using it
11-01-2019, 11:29 PM | #1148 | ||
Rep 446
Mod bug will bite you if you buy a BMW ================================= |
11-02-2019, 03:41 PM | #1149 |
Rep 47
Just did a Stage 2 93 octane flash on my car (catless down pipe), and I have to say... damn. That was just what I was looking for. Completely transforms the car. You can still drive it around casually as well... but when you give it gas... it GOES.
Also, shout out to PTF for making this so user friendly. I was expecting to have some residual codes and things to work through to clear. Once I completed the flash and started my car, the cold start was gone and I knew it had worked. Great work, so much power - I'm loving this new feel. |
11-03-2019, 01:22 AM | #1150 | |
Rep 446
11-03-2019, 07:16 AM | #1151 | |
Cheapskate
4447
Rep 4,993
Does it do the same thing in sport mode? It might help to reset adaptations so the trans can relearn. Also is anything done to the trans like coding or an XHP flash? slightly worse emissions. |
11-03-2019, 09:18 AM | #1152 |
Rep 1,369
Not if you're catless. If you retain the cat, it won't reach operating temps as quickly, especially in colder weather.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
11-03-2019, 05:37 PM | #1153 |
Rep 4,876
I've found that even with cold start delete, the car still holds higher revs while it warms up (around 900 rpm, dropping to 600 rpm once hot). I have no complaints losing the cold start delete on high flow cats, in cold arse Canada....
Probably spews a bit more emissions in the first couple miles of driving, but doing high flow cats will be doing something similar anyways. |
11-03-2019, 06:09 PM | #1154 | |
Rep 1,452
We had 4 days of snow and sub-freezing temps, and it does do a mini-cold start. It will rev to 1,200rpm or so, then drop down very quickly. Not exactly a regular cold start, but not a quiet one either. Sort of in-between. Once I drive it and it warms up and I don't let it sit for days, the cold start is back to quiet. |
11-03-2019, 06:15 PM | #1155 | ||
Rep 246
M240i xdrive - K&N Drop in, MPE
12.3 @ 108 Stock |
11-04-2019, 12:07 PM | #1157 | |||
Rep 446
11-04-2019, 05:35 PM | #1158 | ||||
Rep 1,452
2022 CT4-V Blackwing 6-speed
11-04-2019, 07:55 PM | #1160 |
Rep 190,750
This is highly dependent on your driver skills and tires
kern4174446.50 |
11-05-2019, 03:01 AM | #1161 |
Rep 135
Guys it worth to make custom tune from BM3/MHD if I have acces just on Ron98 (no E85,race gas, no meth)? will be more power than OTS stage2 map? safe like OTS map? and how much it is?
Thanks |
11-05-2019, 09:09 AM | #1162 |
Rep 775
Just install my Bootmod last night...few questions. Is there a setting so I can have cold start on? Or with the bootmod does it eliminate cold start? And under the "exhaust flaps" section, I clicked "open" but when the car is on and in sport mode, the flap in the left tail pipe is still closed. Am I doing something wrong?
2016 340i xDrive 6MT (regretfully sold)
2020 M340i xDrive |
11-05-2019, 09:30 AM | #1163 | |
Rep 246
12.3 @ 108 Stock |
11-05-2019, 12:46 PM | #1164 |
Rep 1,369
Tom Wrigley Performance got big gains on 93 with a Cary Jordan tune. I’m planning on going that route myself after I upgrade the HPFP.
janea120728.50 |
11-05-2019, 01:33 PM | #1165 |
Rep 1,862
Drives: powered by bootmod3
UPDATE: Map configuration screen descriptions for all settings and values available.
This should help those using the screen for the first time get a sense of what the values are if or when they may not be clear. I realize some of you will enjoy these being added right in the screen even though all of them are documented in the actively maintained bootmod3 User Manual.
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
11-05-2019, 01:40 PM | #1166 | |
Rep 303
I'm not a BM3 user yet but i'm very interested in programming my M240i with the Stage 1 91 map but i'd like to keep all of my OEM values (cold start, engine cooling, shift speeds) except for the map of course. What values should i keep in the OEM. I did not understand the last image with the percentages (sorry i'm not expert with this programs)... |
bm3, bootmod3 |
