03-06-2021, 10:16 PM | #6711 | |
Rep 1,217
03-07-2021, 06:08 AM | #6712 | |
Rep 17
03-07-2021, 06:19 AM | #6713 |
Rep 17
There is a way to improve the volume for at least for CIC units? It's to low compared with the sound from the OE HU. I've tried almost everything to bring the sound level at appropriate level with the sound from the OE HU. If there is something else, please let me know. From the AUX/External Devices, sound level is at maximum. Another question, how can you add the navigation in the right area of the split screen?!?! I have the following version of sw installed: SDK Version: 25.0.0.5.6.0.0.0; CUST Version: CHL_V1.1.2; MCU Version: 20.9.29.13; HW Version: BMW_CICHL. It is something new? It worth upgrading new versions? Thanks!
03-07-2021, 11:45 AM | #6714 |
Rep 806
Successfully upgraded to v1.2.1 from v1.1.2 without any problems on my andream b. Went extremely smooth.
Is it just me or is there no vol display notification when adjusting the vol controls? I have to switch back to idrive to make sure the vol isn't maxed out. Not a big problem buuut is this just how it is? I've been dealing with this since i installed the mmi and everything works fine but hoping this version might've included it or maybe i'm just missing it? Just a minor annoyance for me. |
03-07-2021, 12:38 PM | #6715 | |
Rep 17
03-07-2021, 12:44 PM | #6716 | |
Rep 24
However the day/night problem is still there - for Waze. Muniz could you please check whether the day/nigh thing in AA works for Waze on your firmware? And it does not work for Google maps for me as well, what are your settings? Did you set phone in dev mode to controlled by phone, and in mmibox settings the automatic option is on or off? I never use Google maps, Waze is highly preferred in the area I live because of wide usage among users who report hidden police behind bushes with speed cameras... |
03-07-2021, 01:29 PM | #6717 | ||
Rep 806
Looks like you're on an older HU (CIC) than me. |
03-07-2021, 01:44 PM | #6718 | ||
Rep 1,217
The custom sw does have a separate setting for automatic day/night mode. It just works based on whether the headlights are on or off. |
03-07-2021, 03:49 PM | #6719 | |
Rep 286
03-07-2021, 05:59 PM | #6720 | |
Rep 1,217
Homersbud202.00 |
03-07-2021, 11:08 PM | #6721 | |
Rep 3
According to bimmerlink / bimmercode I am using CIC High. Using 6 pin NBT MMI too. I don't need to connect the aux cable to the armrest. No sound issue.
03-08-2021, 09:18 AM | #6722 | |
Rep 10
If anyone is looking for a seller in the Netherlands, we are Andream dealer and sell these with VAT and 2 year warranty for EU 290 with fast shipping and support . We also install them |
03-08-2021, 10:10 AM | #6723 |
Rep 2,591
Does anyone find AA kind of laggy? It's not always the most responsive. Is it due to NBT being a little slow, or just my phone? In theory, with the box, it's not relying on NBT at all except for the display, so I have a feeling it's the phone but figured I'd ask.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
03-08-2021, 01:04 PM | #6724 | |
Rep 17
03-08-2021, 04:46 PM | #6725 |
Rep 40
Mine AA is laggy sometimes, but much less on 1.2.1, an finally, on this version no daily crashes. S10+ Exynos with Andream B. No problem on my iPhone 6s .
03-08-2021, 05:46 PM | #6726 |
Rep 44
I have an Andream A unit with custom mod b0 firmware and latest MCU. My problem is that about 40% of the time AA will not start on my Galaxy Note 20 even though the phone is connected to the box in bluetooth device listing (timeout error briefly on screen after a minute) . This forces me to go to the device listing every time and disconnect and then wait around 20+ seconds for my phone to reconnect
Anyone having similar issues or does one of the newer non-custom firmwares fix this? |
03-08-2021, 06:15 PM | #6727 |
Rep 1,217
It could be the phone and/or the mcu. I saw a big improvement when I upgraded my Samsung Galaxy S7 to an S10e. Also, the newer mcu's have further reduced lag.
03-08-2021, 08:45 PM | #6728 | ||
Rep 94
So I suspected the problem is on the MMI side. Quote:
03-08-2021, 10:38 PM | #6729 |
Rep 2,591
Newer, as in the B units?
2015 BMW 535xi
03-09-2021, 12:03 AM | #6731 | |
Rep 2
03-09-2021, 01:31 AM | #6732 |
Rep 46
RoadTop B-Version BR125 - Night mode fix
Hi guys,
long time lurker first time poster here. I have been in contact with RoadTop for quite some time now to get a fix for Night mode problems on AA & Android 11. I got yesterday the below SW release with the fix and have been testing it since then. My findings so far, coming from BR115: - Sound clarity is significantly better. Very flat frequency response and a bit fuller bass. Also a new option was added to the Audio menu "Loudness" that boosts the sound linearly, I would not recommend using it unless you really want the volume to be obnoxiously loud. - There is now an option to switch BACK & HOME button functionalities. So you can long hold MENU for a restart & long hold BACK to switch between MMI & NBT - And ofc last but not least a proper working Night mode for AA (please check the below photos). I have tested it with TomTom GO my main navigation app, Google Maps & Waze & it is always working. As a piece of advice for those of you with 6.5" display, you will need to drop the brightness by 2 and increase contrast by 1 to avoid having washed out colors & increase the graphical sharpness as much as possible. RoadTop B-Version [NBT] [GEMINI_PACK.BIN] BR125 (PIN: 8032) (Not cross compatible) Happy Flashing! Last edited by Eldewy; 03-09-2021 at 02:48 AM.. |
ImpX13.50 Cruez3.00 Rasoul7712.00 x-m4n148.00 muniz_ri447.50 skittletop5.00 Firefly1337846.00 Frrr6.00 emulajavi421.50 |
andream, android, android auto, apple, carplay, mmi, retrofit |
