04-01-2021, 05:52 PM | #1 |
PdV Motorsports
121
Rep 165
Drives: 2014 335i xDrive sedan
93 octane limits
I'm looking into a speedtech kit and all the fuels as long as its 93 octane only. No E-anything, no port injection, no meth. I am wondering where I'd end up with all the supporting mods and basically run into the octane limit for the compression ratio. I assume that is the limiting factor.
I've seen maybe 525whp. Thoughts?
Ryan M. PdVMotorsports.com Owner https://www.youtube.com/@pdvmotorsports
2014 EB M-Sport 335i xDrive - PdV/BC custom coilovers, PdV spherical rear shock mounts, PdV big brake kit, MHD Stage 2+ Next up: PdV genuine GTX3582R Gen2 turbo kit, Nostrum HPFP & Stage 2 injectors, PdV PM5 w/ "Veyron" Bosch E5LM |
04-01-2021, 06:11 PM | #2 |
Rep 462
04-02-2021, 01:27 AM | #3 | |
@lbb_kev
490
Rep 512
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | Dorch Stage 3 HPFP | Nostrum S2 Injectors | Walbro 535 | EOS EKP | BendCalibration Flex Fuel Kit | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage |
04-02-2021, 03:15 AM | #4 |
Rep 2,354
500whp sound optimistic to me. The approach would probably be to run less boost but more timing and in that case I think anything bigger than a PS2 i overkill..?
I get 490-500 crank hp with 93+meth on a PS2. PS2 OTS with 93 (PWG) https://datazap.me/u/harkes/ots-ps2?...a=3-9-16-17-21
(A Dane in China) |
Insane435476.50 |
04-02-2021, 06:30 AM | #5 |
PdV Motorsports
121
Rep 165
I would future proof with the 8374 assuming I swap 9.5:1 pistons down the road.
2014 EB M-Sport 335i xDrive - PdV/BC custom coilovers, PdV spherical rear shock mounts, PdV big brake kit, MHD Stage 2+ Next up: PdV genuine GTX3582R Gen2 turbo kit, Nostrum HPFP & Stage 2 injectors, PdV PM5 w/ "Veyron" Bosch E5LM Last edited by RbBugBitMe; 04-02-2021 at 06:43 AM.. |
04-02-2021, 09:10 AM | #6 | |
@lbb_kev
490
Rep 512
With a great tuner, my Speedtech 7670 kit managed to do 540whp on E40 on a very conservative tune. As OP plans on lowering their compression ratio to be able to run higher boost with lower octane, that makes Speedtech an even more reasonable choice.
04-02-2021, 09:15 AM | #7 | |
@lbb_kev
490
Rep 512
Alternatively since you may go lower compression, you can ask Jeff at Speedtech about the 8474 if you want to shoot for more. Its a newer style turbo that's pretty much better than the 8374 in every way with the caveat of an additional 100-200rpm in spool time.
RbBugBitMe121.00 |
04-02-2021, 11:05 AM | #8 | |
Rep 1,105
04-02-2021, 11:35 AM | #9 | |
Rep 1,148
04-07-2021, 03:51 AM | #10 | ||
Rep 2,354
(A Dane in China) |
04-07-2021, 04:00 AM | #11 | ||
Rep 2,354
Search YouTube for Torqbyte and npharkes then you will find some videos
(A Dane in China) |
Pussiwillow521.00 |
