02-06-2022, 10:03 AM | #2 |
Rep 3,832
Use of any "waterless" product on a soiled car is strongly discouraged!
Apart from that, not sure what you'd be trying to achieve with such a product in the engine bay? It is neither a strong cleaner, nor a sealant intended for plastic. There are much more suitable products for cleaning the engine bay and especially for preserving/sealing it. For the latter they need to be able to tolerate high temperatures typical for that area.
WrxToBeamerGuy490.00 |
02-06-2022, 10:43 AM | #3 |
Rep 15,962
I guess you can use it, but you're not going to get the results that an appropriate detergent and rinse will.
02-06-2022, 03:19 PM | #4 | |
Rep 935
02-06-2022, 04:29 PM | #5 |
Rep 3,832
Sure. Fur the engine bay I use and can highly recommend:
1. Cleaning - Koch Chemie Green Star 2. Sealing and preserving - Koch Chemie Motorplast This one is specifically made for the engine bay and is high temperature resistant and easy to apply. Leaves a great finish.
04-21-2022, 04:23 AM | #6 |
Great Teacher
1026
Rep 1,272
Drives: 06 e91 325ix
I use brushes and simple green overall, rinse, then Chemical guys hydro shield on plastics, CG speed wax on underhood paint.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
04-23-2022, 10:35 PM | #7 |
Great Teacher
1026
Rep 1,272
Pic two weeks after cleaning. Just had to wipe a little dust off.
04-24-2022, 11:41 PM | #8 |
Rep 935
04-25-2022, 12:33 AM | #9 |
Great Teacher
1026
Rep 1,272
Low pressure water.
My pressure washer has a “soap” nozzle that I actually use instead for rinsing by keeping the soap tank empty.
04-25-2022, 08:19 AM | #10 |
Rep 131
04-25-2022, 04:09 PM | #12 | |
Great Teacher
1026
Rep 1,272
Been doing it for 30 years now. It’s not nearly as bad as straight Castro super power which is far far far more acidic.
06-21-2022, 07:34 PM | #13 |
Rep 23
My engine bay wasn't too bad, but I sprayed Ammo waterless wash on it, as they recommend, and it seemed to work pretty good. You still have to wipe it off, but it appeared to get most the grime and dust off all the plastic and metal. Anything you miss evaporates away which also makes it way easier.
06-21-2022, 09:58 PM | #14 |
Rep 15,962
An easy way to get a spot free result is to do a final rinse with distilled water, applied with a pump sprayer. A gallon will do it, and considering how infrequently you need to wash the engine bay it's not all that expensive at a dollar.
