07-23-2019, 08:41 AM | #2641 |
Rep 540
Screw it, I just bought the Avin Android 9.0 unit. Hopefully have it in a couple of days. Hope it's better than my 7 unit and that the GPS actually works.
I did think about getting one of the higher res screen variants but there aren't as many of those around and of course they cost even more. |
07-23-2019, 12:23 PM | #2642 | |
Rep 45
https://pl.aliexpress.com/item/33047757162.html Now I have unit with android 7.1, I had no issues with this unit except it is sooooo slow and external DAC is not working with android 7.1 units because of no proper drivers built-in. husskad Can you tell me in your opinion was it worth its cost ? I found that there are two types of units with android 9. 1st with old PX6 and 2nd with Snapdragon 625 which we have ordered. |
07-23-2019, 12:35 PM | #2643 | |
Rep 102
Still searching for the best value for money unit If anyone interested, please let me know, so I can contact the sellers for group buy |
07-23-2019, 03:01 PM | #2644 |
Rep 12
@Kuj0n: is your 7.1 unit up for sale now? If so, what version do you have? CCC or CIC? Where do you live in Poland? I'll be in Warsaw next month and I'm really interested in your unit if it's available.
Thanks. |
07-23-2019, 03:38 PM | #2645 | |
Rep 45
I have CCC. I will be able to sell the unit without a reversing camera. Now i have this unit https://pl.aliexpress.com/item/32898657670.html I bought this unit about 10months ago and still working fine. Last edited by Kuj0n; 07-23-2019 at 03:46 PM.. |
07-23-2019, 03:53 PM | #2646 |
Rep 12
Mine only lasted 3 months, now every time I run Waze or any other demanding app, it freezes in 10 seconds. Also CCC, 7.1.1, 2GB/32GB (Andream).
Please send me your price via PM. Thanks! |
07-24-2019, 03:50 AM | #2647 |
Rep 62
i did happen to found the android image and MCU upgrade for 7.1
https://drive.google.com/drive/folde...cjBjFXM34EGaoE Still looking for help with regards to my 8.1 |
07-24-2019, 07:03 AM | #2648 | |
Rep 220
Drives: MINI Cooper, 2020 X1
07-24-2019, 07:45 AM | #2649 | |
Rep 51
07-24-2019, 07:47 AM | #2650 |
Rep 51
i have the black edge looks fab..
07-25-2019, 04:48 AM | #2652 | |
Rep 190
It is always alive in hibernation mode? |
07-25-2019, 06:44 AM | #2653 | |
Rep 118
It has happened a few times to me after the car being stopped a few hours or over night when turning it on, the unit starts right away, only a progress bar appears for a couple of seconds and the unit is fully working. Will try to catch it on video. |
07-26-2019, 05:46 AM | #2654 |
Rep 51
yep looks great and its is the 8 core, i have some issue with it at the mo no audio but i can get it through the usb with a £1.59 sound card and it sounds good, the date will not stay set and when i set the media volume to 80% after a reboot it goes back down. still in contact with the vendor they sent me an update but still the same problems, other than that all good.
07-27-2019, 04:15 AM | #2655 |
Rep 220
Unfortunately, I haven't seen MCUupdate from ALS. Android 8.1 20190611 is here: https://mega.nz/#!VRkSCSpT!1TiqSoyrn...3tIlQsbrfEUz1Y
factory.xml is here: https://mega.nz/#!hRdgjarQ!m1yyJzNc_...1xzbOXE9uv8_iY |
Ericokta0.00 |
07-27-2019, 01:46 PM | #2656 |
Rep 13
Hello,
I have issues with the DAB+ usb adapter. I fianally worked out it is the Android unit itself that is disturbing the DAB signal. I connected the dab adapter to my phone and when I disconnect the Android unit rom the car, then switched the ignition on, the music was playing fine. I then reconneced the unit, switch the ugnition back on and the sound stopped. Is there anyone who has a working dab adapter? If so could you please PM me? If i make any changes using the factory menu, do i need to restart the unit for the changes to take effect? Lastly, this are the options i can see withing factory menu. I am trying to identify wheter it is the psu of the unit or the wireless adaters (bt, wifi etc) so can anyone suggest anything? Thanks in advance |
07-29-2019, 12:51 AM | #2658 | |
Rep 220
RK3066 Android 4.4.2 1.6 Ghz Dual Core CPU 1 GB RAM Memory 8 GB Internal Storage Last edited by smahel; 07-29-2019 at 01:16 AM.. |
07-29-2019, 02:15 AM | #2659 | ||
Rep 19
I think it's not the 20190611 version but 20190520. This is what the build.prop looks like: Quote:
07-29-2019, 03:22 AM | #2660 |
Rep 19
Working on TWRP support at this point.
The populair "Alfawise H96 max" mediabox has the same RK3399 chipset as the PX6. Found the image at: https://basketbuild.com/filedl/devs?...box-110418.img Currently exploring the IMG file. The following needs to be done after I've checked everything (IMO the easy way): 1. Root the PX6 Android 8 Oreo system 2. Copy IMG file to Android unit 3. Install Official TWRP apk from Play Store 4. Install the IMG file 5. Reboot |
07-29-2019, 09:43 AM | #2661 | |
Rep 220
System.new.dat (framework) is May 20, 2019, but oem.new.dat is June 11, 2019. When you install this version, you get the following: Last edited by smahel; 10-18-2023 at 01:32 AM.. |
renedis0.00 |
07-29-2019, 11:16 AM | #2662 |
Rep 80
