11-06-2022, 08:04 PM | #375 | |
Rep 1,148
I think I'll pull the trigger From the sounds of it you really felt a positive difference in the character of the car, full send. You're lower with more aggressive fitment so I think it's safe if you're only getting rubbing on extremes. |
11-06-2022, 09:40 PM | #376 |
Rep 220
I still need to upgrade my tension arm, I’m thinking I may go the m3 part and then use a spacer similar to this
https://cmpautoengineering.com/colle...ol-arm-spacers I think the m3 tension rod is a solid rubber bushing vs fluid filled for the stock item? Cost between the two parts seem similar |
11-06-2022, 09:56 PM | #377 | |
Rep 1,148
I just been on the fence because all the mixed feelings about f80 components but I think I'm going to pull the trigger on it. |
11-07-2022, 04:51 AM | #378 |
Rep 220
Aaa yer that’s a good idea! I need to replace all my rear arms soon too. They all are a bit worn. May go Megan racing parts
Pussiwillow522.00 |
11-07-2022, 07:36 PM | #379 |
Rep 1,148
11-11-2022, 03:24 AM | #380 | |
Rep 220
I need to do my rear bearings too Have started a new thread: https://f30.bimmerpost.com/forums/sh...3#post29534393 Last edited by Tobz_au; 11-11-2022 at 03:41 AM.. |
Pussiwillow522.00 |
11-12-2022, 01:05 PM | #381 |
Rep 78
I've been following this thread the last couple months as I've been preparing to have my rod bearings service. My cars has 118k miles with oil change's ever 3k-5k miles. I do drive my car spiritedly and am running bm3 stage 2h with ps2 turbo. I have an mmr oil baffle I am going to have installed when I get the bearings done. I am gonna use oem bearings and oem bolts as they have served me and many others well for a long time.
Is there anything else I should look at when the car is open and have the shop potentially replace? Car goes in the shop next week. |
11-13-2022, 12:59 AM | #382 |
Rep 220
Nows the time to do the swaybar…. Engine mounts also could be good? Easier to access the downpipe, water pump and thermo while the subframe is out…. Also check the condition of the turbo oil and coolant pipes…. Maybe pure stage 2 turbo as well?
Pussiwillow522.00 |
11-13-2022, 04:35 PM | #383 | |
Rep 78
Since the oil pickup tube is plastic is there any possibility of that becoming brittle over time? Just trying to brainstorm anything the could need refreshing while the pan is off. |
11-13-2022, 07:57 PM | #385 |
Rep 78
Perfect. I can't wait to see what my bearings look like. Shouldn't be to bad as I'm on top of my oil changes.
11-30-2022, 02:05 PM | #386 |
Rep 78
I just got a call from my shop saying the mmr oil baffle won't fit with my oil pan. I'm going in now to try and look at it. Any ideas? I have a 2014 335i rear wheel drive m sport
11-30-2022, 02:29 PM | #387 | |
Rep 1,148
What exactly is the problem do you know? The baffle mounts to the windage tray, it mounts to 4 existing bolts that are replaced with longer bolts provided. It literally hugs the pick up tube nicely, so I'm confused by what they're saying, it's fool proof. |
11-30-2022, 05:21 PM | #388 |
Rep 77
It fit my 2014 RWD M235i perfectly as well.
Pussiwillow522.00 |
12-03-2022, 10:36 AM | #390 |
Rep 78
it was shop error. After going there we where able to fit it properly and fit the oil pan over it. Everything else went perfectly. The old bearings showed very little wear which is makes me happy.
Definitely hope to keep this engine running for another 100k miles |
12-24-2022, 08:50 AM | #392 |
Rep 1,148
Cost, and the baffle works really well at what it’s designed to do. My car isn’t a dedicated track toy and won’t even see r compound tires in its life. I did it for peace of mind.
12-27-2022, 06:16 AM | #393 |
Mechanical/Automation Engineer
Rep 25
Ahh, gotcha. That makes sense. I never looked into the cost of the S55 conversion, I only knew it was an option other than the $460 MMR baffle from ECS.
