12-02-2016, 01:05 AM | #1 |
Rep 499
xDrive and tire chains: Chains go on the rear?
I did a search of the forum (can't find much) AND looked in the manual (can't find anything):
Certain times of the year, in WA and OR, tire/snow chains are required to carry when going over the mountain pass, even if not needed -- and even if you have dedicated winter tires. I'm getting dedicated winter tires, plus I have xDrive, so I'm sure that will be plenty -- but, as I stated, I will still need to carry chains in case I get pulled over or something like that. If I ever had to actually use the chains though, would I put them on the front or back wheels? I can't find a definitive answer info anywhere. Since the car is xDrive I was assuming I'd need two sets -- for both the front AND back -- but I was inspecting the car and there's barely any clearance between the front shock and the inside of the front tire. You can't see this visually -- you have to wrap your hand around the top of the front tire (through the wheel). Between the inside sidewall and the shock there's barely a finger's width of space. So I'm skeptical chains would fit on the front at all. I'm guessing they would go only on the rear. But I'm afraid just rear chains might screw up the AWD differential. Does anyone know what the answer is? I'm driving a 2016 328i xDrive. Thanks! -Nathan Last edited by natesi; 12-02-2016 at 01:10 AM.. |
12-02-2016, 02:16 AM | #2 |
Rep 3,622
My opinion having been in severe winter weather in both states, AWD and good all season tires is more than enough. I honestly don't think you need both. (Edit I mean both winter tires and chains w/ AWD) I have been in AWD rental cars with all season grand touring tires
BMW CCA Member #516012
ErkanTR16598.00 |
12-02-2016, 06:05 AM | #3 |
Rep 4,724
SO FALSE. All seasons cannot stop or grip at all. I used to run no seasons on my xdrive. Switched to true winter tires 3 winters ago and I'll never go back.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
12-02-2016, 07:28 AM | #4 | |
Rep 1,472
Coming from Bay area, this might be true, but NOTHING could be further from the truth in true winter conditions. Sure, you can get away with it (I did when I was younger, not as "wise" and with less disposable income), but in general, not a great advice. In my family, we own both, RWD and AWD vehicles and live in area with tons of snow for 4-5 months a year, so I'm speaking from experience, AWD vehicle does not justify lack of winter ties, all advantage of AWD drivetrain is completely lost if you chose to go this route. Just the other day, fully snow covered roads, I encountered not one but two xDrive 3 series struggling to move around on what I assume are all season tires (any car would not be able to move at all on summer tires that day, so I'm assuming all seasons), while I was managing perfectly fine with RWD and winter tires. |
12-02-2016, 07:38 AM | #5 | |
Rep 2,639
Always buy winter tires for winter. If you get barely 5cm per winter season and it doesn't drop below -5C, then maybe you'll get away with all seasons, but if you get a dump of snow per season (100CM+) and it drops below -10C then winters are a must. You really don't want to increase your insurance premium and have your car in the shop because you rear ended someone or went into a ditch just because "All seasons" are enough.
Bbb34730.50 |
12-02-2016, 08:33 AM | #7 | ||
Rep 4,983
That said, after 24 years of driving in snow, dedicated winters are the tits, and I would always recommend them over anything else. At the end of the day though, nothing beats driving slower and with your head on a swivel. I take calls from home now and have to drive through some pretty awful shit no matter what and my xdrive with all seasons does fantastic.
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
12-02-2016, 08:35 AM | #8 | |
Rep 16,086
But that's not what the OP asked about. OP, in Washington if you have AWD and AS or snows you don't need to have chains on the tires, but you do need to have a set for one axle on board, in the event that you have to put them on. http://www.wsp.wa.gov/traveler/traction.htm Oregon is probably similar. With XDrive put chains on the rear tires, as the rear wheels are the primary drive mechanism. A set for the fronts as well isn't a bad idea, but chances are if you need them the snow will be too deep for chassis clearance anyway. Studded winters is another option. Studded winters on AWD meets chain requirements. If I was living in the mountains where there are chain regs that's what I'd use. |
12-02-2016, 08:50 AM | #9 |
Rep 6,990
OP, your rear wheels are the primary driving wheels, so if you feel the need to chain up, put them there. Putting them on the front would be advisable only in an extreme situation, as the added weight of the chains and their tendency to "flail" at anything above very slow speeds could have a negative effect on steering. Studded tires would be better, but many states won't allow them due to potential road surface damage.
12-02-2016, 08:58 AM | #10 |
Rep 962
RWD + winters >>> AWD + all-season...because stopping.
Ideally chains should go on all wheels. If not, then put on rear as that is where most of your torque split goes. |
12-02-2016, 10:06 AM | #12 |
Rep 1,472
Very true, but it's not "just stopping" it's lateral grip and recovery from loosing it as well. All season tire might be fine on xDrive, but so could unprotected one night stand with complete stranger, but....you know, you're taking a chance either way.
With winter tires xDrive is incredible on snow. Once you try the same car on snow covered or icy roads, with all seasons and winter tires, it's beyond me how anyone can even argue this. Sorry OP, don't mean to derail the thread further, but I think general agreement is if you have to go with chains, rear wheels first. |
12-02-2016, 10:24 AM | #13 |
Rep 499
Thanks for all the feedback guys.
I just sent off for 1 set of rear chains. Like I said, I don't think the fronts really have the clearance between the inner tire and shock -- not much more than a finger's width of space is available. Mostly I was just worried about the AWD differential due to asymmetric diameters between the front and rear -- once the chains are on only one axle. That being said, I doubt I'll ever have to use the chains -- as I'll be getting Pirelli Sottozeo 3 winter tires on next week. But I didn't want to do anything that would mess up the car, in case I ever do need to use them. Thanks all, -Nathan |
12-02-2016, 11:31 AM | #14 | ||
Rep 3,622
Bbb34730.50 |
12-02-2016, 11:38 AM | #15 | |
Rep 3,622
12-02-2016, 11:56 AM | #16 |
Rep 22
Correct answer. But I've never bothered buying chains for my AWD sedans... spend the money on dedicated snow tires instead. Braking performance and traction is significantly improved over A/S tires. Snow tires will last several seasons if you install in Dec and remove in Apr.
Bbb34730.50 |
12-02-2016, 02:21 PM | #17 | |
Rep 2,639
12-02-2016, 02:42 PM | #18 | |
Rep 1,472
I know you ski, I know you live in area with lots of snow, but what you're saying is absolutely not true, not in theory, not in real life. When I visit Jay Peak this winter we can meet up for a day of skiing, maybe a pint of beer after , then we'll compare, hopefully it's snow covered roads that day . You let me know which one you want me to bring, AWD or RWD both with great winter tires, and we'll compare. |
12-02-2016, 03:22 PM | #19 |
Rep 16,086
I've driven in 51 'real' winters so far, 25 of them as manager of a mountainside ski shop, where I had to open the doors every morning, no matter what. I've driven more miles through snow in hilly terrain than many plow drivers.
CalCarNut1060.50 |
12-02-2016, 03:45 PM | #20 |
64-bit
598
Rep 814
Drives: 2018 BMW 340i xDrive
Here we go again Tires and xDrive.
12-02-2016, 03:49 PM | #21 |
Rep 1,170
One of many video's @ Tirerack.com which will pretty much answer any winter tire question you may have. OP just my opinion but under no circumstances would I put chains on my BMW. If conditions are that bad I would park it and wait.
http://www.tirerack.com/videos/index...454&tab=Winter
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. |
12-02-2016, 04:05 PM | #22 |
Rep 1,472
