View Poll Results: Which one first? Suspension vs Performance vs Wheels vs Show Car | |||
Suspension | 9 | 50.00% | |
Performance | 7 | 38.89% | |
Wheels | 2 | 11.11% | |
Show Car | 0 | 0% | |
Multiple Choice Poll. Voters: 18. You may not vote on this poll |
12-28-2016, 01:05 AM | #1 |
Rep 953
Suspension Vs Performance Vs Wheels
Hey guys, I'm not sure what I want to do next, so i'm here to ask you guys for your opinions for the next mods. So far i've owned my F30 for 2 years, in the two years I have done the following: Injen cold air intake, JB4, ER Catless Downpipe, Kw V2 coils, and VMR V710 wheels. I plan on starting to track the car in the new year, so with this I ask you to pick which route to go first and why. Should I do suspension first, or performance or wheels. Or jut say screw it and never track the car and go for looks, a Show car. Feel free to say whatever you want
1. Suspension: Ground Control front camber plates (race), Ultra Racing 2 point front strut bar, Dinan Roll Bar set, Megan Racing Rear camber front upper arms and rear camber rear upper arms 2. Performance: ER Front mount intercooler, ER Charge pipe (IC to TB) and (IC to Turbo) 3. Wheels: Volk Racing TE37SL (18x9.5 square setup) 4. Show Car: ER Front mount intercooler, Volk Racing TE37SL 19x9.5 (Aggressive setup), M sport conversion, lots of carbon fiber goodies, Sparco Seats. (Go lower than I am now, maybe max out the coils)
2014 328i - FBO/KW v2/VMR v710's IG@F30_Joe
12-28-2016, 01:21 AM | #2 | |
Rep 2,639
IMO, I track occasionally, and I can tell you that you need the FMIC asap. Temperatures will rise and it will run very hot quickly. Afterwards, you should get lighter wheels+track tires. And then sway bars afterwards. And then chargepipes.
12-28-2016, 01:30 AM | #3 |
Rep 14,115
Drives: G82 M4C X-Drive
What kind of tires are you running? I would go tires, suspension, then performance. What's the point in going faster if you can't make a turn
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
12-28-2016, 01:33 AM | #4 |
Rep 953
Toyo proxes t1's
12-28-2016, 01:35 AM | #5 |
Rep 14,115
Do you seriously want to do well at the track, or are you just having fun?
Racing Sport minded: I would go tires, brakes (pads or calipers depending on your budget), suspension then performance. What's the point in going faster if you can't make a turn? Fun track day minded: Tires, suspension, performance, brakes. Brake fade and stopping distances will hurt you here, but if you are not timing your laps, you can still have fun opening up your car!
12-28-2016, 10:04 AM | #6 |
Rep 1,560
The best upgrade for the track is the driver. Before spending any money on the car, spend some money on training for the driver. I have seen many good drivers in stock cars blow away normal drivers in well setup cars. Both the BMW CCA and SCCA have training programs at reasonable prices. At the same time you will be able to get a lot of feed back from the trainers about what your car needs to have upgraded.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
12-28-2016, 10:16 AM | #7 | ||
Rep 3,947
1. Tires (Max Performance Summer or Extreme Performance Summer) 2. Brakes (Pads, fluid) 3. LSD Quote:
12-28-2016, 10:24 AM | #9 |
Rep 3,947
12-28-2016, 05:14 PM | #10 | |
GasCompressor
333
Rep 564
The inter-cooler will heat soak and performance will drop dramatically.
2022 Porsche 911 Cabriolet Agate Grey/Black PDK 2019 440i M-Sport Smoke Topaz Metallic/Opel (Sold) 2014 335i M-Sport Black/Beige MPPK/MPE (Totaled) 2013 328i Sport xDrive Imperial Blue/Grey (Sold) |
12-28-2016, 05:31 PM | #11 |
Rep 233
Just start tracking the car first. Turn the boost down so stock I/C can handle the temps and after spending lots of money having fun on a track, then decide what to do next.
I had a set of Volk TE37's on my 240 years ago. Beautiful wheels. Probably my all-time favorite for looks. Sold them pretty quick though for some flow formed cast wheels that were much cheaper and I wasn't nearly as worried about getting scratched or damaged from hard driving. I bought them used and sold them for a little less and so it only cost a few hundred dollars to own them. Don't think I'd ever spend that much to buy a set new.
