03-13-2017, 01:58 PM | #1 |
Rep 6
ASD coding F36 (2016 september model)
Hi,
I'm pretty new to car-coding (and the forums). So the point is that I have an F36 (GC) from this september. I have coded some other stuff (chirping when opening/closing the car - handy because I hate the new don't-turn-just-push start engine button - I forgot to turn of engine a couple of times ). So this car should have ASD right? (420d xdrive) But I can't find it in ESYS... I have "activated" asd inside another modules CAF but I don't see an ASD module in ESYS... Or is this benzine engines only? If anyone could help me out, I'd really appreciate it. Kind regards and have a nice day, |
03-13-2017, 06:21 PM | #2 |
Rep 193
If you are not seeing the ASD module in the SVT tree then you are not having it.
03-14-2017, 10:02 AM | #3 |
Rep 6
03-14-2017, 10:16 AM | #4 |
Rep 193
03-15-2017, 07:45 PM | #6 |
Rep 193
03-28-2017, 12:54 AM | #7 |
Rep 116
Drives: F36 420da
20d have no ASD.
Only 28i and 30d if iam not wrong and your country variant is equal to germany. But if you had ASD, however you couldn´t code it to another Engine Sound because of the 2016 I Step. |
03-27-2018, 11:54 PM | #8 | |
Rep 357
What I think is that in my case, the ASD is only exterior sound. I don’t have the module that is connected to my speakers in interior and I think that is why I cannot find the module in coding. Although there should sill be something I suppose because in comfort mode my car is close to silent so there has to be coding somewhere in this regard... I’m trying to figure it out because I want to play with the different options as well I don’t know why this part is not there though, is it related to fact that it is 20d or did my dealer “forget” that part or is it only available on non Diesel cars, dunno |
03-28-2018, 12:03 AM | #9 |
Rep 116
Drives: F36 420da
M Performance exhaust for 20d is also with an ASD Modul but only for outside the car. Its a different ECU than the ASD for inside the car. Because the ASD3 from the M Performance exhaust is also a KCAN2 participant you should see it. ASD3 have to be coded.
04-03-2018, 04:11 PM | #10 |
Rep 357
Ok, so it’s installed correctly I imagine then, strange enough we didn’t see ASD module but perhaps it’s due to Carly app not seeing it
then and I should check with BMW connector instead if we can find it then. Wondering how easy or not it would be to swap out module with another module |
04-05-2018, 11:17 PM | #11 |
Rep 116
Drives: F36 420da
With module you mean the ASD Ecu powering the outside "Speaker"?
ASD01 for in car you can code to other soundsets with the correct early i Step. ASD03 for outside the car you can also code but only from 20d to 30d. In future i will try to code to i8 sound, because it uses the same ecu but is KCAN4 participant not KCAN2 like F3x. |
04-28-2018, 12:02 PM | #12 | |
Rep 14
I've searched the forums to see if one of the Remote Coding options can turn back integration of a specific model, but I've come up empty handed. |
04-28-2018, 02:19 PM | #14 |
Rep 765
Short cut is saved on my iPad which I don’t have. Check this forum n you’ll find ur answer. But u def have to flash to older istep since the newer ones stop u from being able to change engine type
05-31-2018, 04:13 PM | #15 | |
Rep 357
05-31-2018, 04:17 PM | #16 |
Rep 116
Drives: F36 420da
