05-08-2021, 02:56 PM | #1 |
Rep 296
HELP: Timing correction/knock on good gas
Context: Since I got the car year ago it always had trouble with timing corrections despite being on 100ron(93oct+) gas only - even with octane boosters, ethanol/meth. Car now has Pure800, dorchst2 HPFP, DP, WMI, intake, exhaust etc.
I replaced plugs 4x, coils, flow-checked injectors - all good. No codes. Just lots of timing corrections and knocks in logs. Also interesting - 99% of my corrections are during spool or up to 4-5k rpm. My top end is clean always. Usually when I see bad gas from others - its the other way around (top end suffers). I put Shell VPower Racing 100ron in (same result with OMW 100ron and Orlean 100ron). To rule out tune, I flashed stock tune & sure enough car pulls timing on all cylinders on stock map while cruising on highway. And shows several knocks. See here. I then did 2 pulls and again - lots of correction down low - top end clean. See here and here. I just dont see how on stock map with 100ron it could be this bad. Any ideas? 1. Again plugs? 2. Knock sensors? 3. Impact of free flowing exhasut w/o resonator (but had corrections like this before too)? 4. Compression & leakdown test? 5. Check valves and pistons for carbon deposit (valves unlikely - I have meth in chargepipe which should clean them) 6. New injectors (heard when taken out they may be bad)? THANKS A TON! Any help appreciated!!! I'm really at a loss here |
05-08-2021, 03:48 PM | #2 | |
Rep 532
what kind of WMI are you running ? ( where are you located ? )
Bmw M240i Xdrive , Dorch Stage 1 , pure turbo 800 , Midpipe , Remus exhaust. Bootmod3 , 100+ E5
luke1990132.50 |
05-08-2021, 04:25 PM | #3 | |
Rep 296
No wmi active. Should not be able to need wmi for that. On 100ron it shouldn't correct timing like this. People should be able to reasonably run this map on 91oct. I'm thinking it's not the gas but something else. ESP since I get correction in the bottom range not on top |
05-09-2021, 02:32 AM | #4 | |
Rep 532
cylinder 1,2 and 5 have issues 3,4 and 6 stays clean. Did you also check if you have some erros. i think better to bring it back to the tuner, he should give you a better diagnose i hope ( Are you from Belgium ? )
luke1990132.50 |
05-09-2021, 04:02 AM | #5 |
Rep 296
You're right. However this is stock map . Factory setting. I pulled my tuner map to test stock and realized I get massive corrections during spool on stock map as well with quality 100ron/93oct+ fuel. Plus on the highway I get these knocks - again - stock map, no tune. This should not be happening . I would understand if I put 95ron or 91ron, but not with 100.
Also like I said above. Typically on bad gas you see corrections also on top of the rev range. I don't have those. My tuner told me he is impressed how well the car handles top end vs how much correction I have down low |
05-09-2021, 06:01 AM | #6 | |
Rep 532
05-09-2021, 11:17 AM | #7 |
Real Car Enthusiast
288
Rep 2,082
You can't flash your stock map and expect it to log like a stock car when you have an upgraded turbo. P800s are going to flow alot more air at the same boost psi as stock turbos, so..... in the log I'm looking at, i see an AFR of 13.97 at peak boost. That's not good.
05-09-2021, 12:30 PM | #8 | |
Rep 532
luke1990132.50 |
05-09-2021, 09:08 PM | #9 | ||||
Real Car Enthusiast
288
Rep 2,082
https://www.enginelabs.com/engine-te...-applications/ Fuel AFRst FARst Equivalence Lambda ---- ----- ----- Ratio ----- =======================--==================================== Gasoline stoich 14.7 0.068 1 1 Gasoline Max power rich 12.5 0.08 1.176 0.8503 Gasoline Max power lean 13.23 0.0755 1.111 0.900 =======================--==================================== E85 stoich 9.765 0.01235 1 1 E85 Max power rich 6.975 0.1434 1.40 0.7143 E85 Max power lean 8.4687 0.118 1.153 0.8673 =======================--==================================== E100 stoich 9.0 0.111 1 1 E100 Max power rich 6.429 0.155 1.4 0.714 E100 Max power lean 7.8 0.128 1.15 0.870 |
05-09-2021, 09:21 PM | #11 |
Real Car Enthusiast
288
Rep 2,082
05-10-2021, 01:20 AM | #13 | |
Rep 532
( never to old to learn something more )
05-10-2021, 09:12 AM | #14 |
Rep 3,189
As mentioned above you can't expect the stock tune to work with an upgraded hpfp and turbo. After throttle closure doesn't fix the overboost it starts to cut timing. You need a custom tune even for just pump gas.
luke1990132.50 |
05-10-2021, 10:16 AM | #15 | |
Rep 532
first 2 logs where tuned ( but if i look at the log, the bootmod log says stock tune )
05-10-2021, 12:45 PM | #16 | |
Rep 296
I have no codes - there is no misfire. Injectors were flow-checked, coils swapped and new |
05-10-2021, 01:10 PM | #17 | |
Rep 296
After all these corrections - even on highway cruise, I ran the car on stock map to see if this was indeed tune related or not and saw same issues. So was thinking its mechanical. On highway cruise there is very little boost - 1.6psi so not sure how that would cause issues. My view is - on stock map and 100ron gas I should not be getting knocks on the highway cruise no? The AFR of stock map of course is crazy; same with throttle closure. I have those timing corrections on meth map too see here. This was a day before that with much less correction. Same fuel - looks like same IATs. Overall - I feel like I have way more correction given the quality of fuel. Those timings corrections happen a lot on spool on already very low timing which should not happen. Usually when people have bad fuel, their top end timing suffer - mine doesnt as much. |
05-10-2021, 01:12 PM | #18 | |
Rep 296
05-10-2021, 01:15 PM | #19 |
Rep 296
Please have a look at this log. This is highway run on custom map. I dont think timing here for cruise at 130kph is too much - you can see the massive amount of timing corrections in the middle and knocks.
Also - please note, I'm not trying to bash my tuner, he has been very helpful throught. I'm just looking for opinions and maybe experiences that people may have had with this before THANKS all for replying! |
05-10-2021, 01:16 PM | #20 |
Rep 3,189
Timing drops while cruising is normal. You should just be worried about drops on WOT pulls.
05-10-2021, 01:31 PM | #21 | |
Rep 296
See here comparison when it was running fine |
