01-12-2020, 10:21 AM | #45 |
@_sunbish
282
Rep 611
So far zero issues. My first ethanol map experience was with the v6.4, starting with 3.0 gallons of e85 mixed with 11.0 gallons of 93 which ran well. I eventually worked my way up to a of mix 4.0 gallons of e85 and 10.0 gallons of 93. Flashed over to v7.0 e30 map and everything is still good even with a 4.0/10.0 mix.
01-12-2020, 10:26 AM | #46 | |
Rep 289
01-13-2020, 07:17 AM | #47 | |
Rep 1,499
Can you post logs?
01-14-2020, 12:24 AM | #49 |
@_sunbish
282
Rep 611
01-15-2020, 12:48 PM | #50 |
Rep 1,499
PTF replied to me and suggested I utilize the boost by gear feature. I set boost by gear reduction in gears 1-3 to 10% reduction. This worked beautifully. HPFP takes a bit of a drop but doesn't crash. I think this is the limit of my HPFP. I probably won't run this full time as I don't' want to stress the HPFP (or maybe I will and have a good reason to upgrade when it poops out :-) and save this tune for track days or spirited outings and run the Stage 2 93 octane map as my typical map since I didn't have any HPFP issues on that map.
http://www.bootmod3.net/log?id=5e1f48dfae729b183f099229 http://www.bootmod3.net/log?id=5e1f48c4ae729b183f099228
01-15-2020, 12:53 PM | #51 | |
Rep 289
i havent tested the new map yet im still cycline 91 to reset my ethanol content mix. i do have same issues on stage 2 V7 ( Non e30) so maybe ill try to do reduction on 1-3 by 10% and see what happens also. |
01-15-2020, 01:28 PM | #52 |
Rep 1,499
This was the Stage 2 E30 v7.0 OTS map, not the test map
01-15-2020, 01:44 PM | #53 | |
1296
Rep 3,532
01-15-2020, 03:58 PM | #54 | |
Rep 1,499
Did you have the same issues on v6.4? Funny enough, even with 10% boost reduction, the v7.0 map feels stronger on my butt dyno than the v6.4 map with no boost reduction.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids Last edited by JaredG_F30; 01-16-2020 at 07:14 AM.. |
01-15-2020, 06:11 PM | #55 | |
1296
Rep 3,532
Im flashing back to stock shortly and logging and see how it looks.. then im gonna flash stage 2 7.0 and log.. im not gonna touch the e30 map again till spring time. Hopefully there is an update by then. |
01-15-2020, 09:19 PM | #56 | ||
Rep 289
01-15-2020, 10:49 PM | #57 |
Rep 289
ACN91 Stage 2 / 10% reduct on 1-2-3/ V7.0
smoother but overboost and hpfp crash with no throttle closure... lol, I think its best I stay in the 6.4v till it gets solved... http://www.bootmod3.net/log?id=5e1fe3fac090c630ab60cc53 http://www.bootmod3.net/log?id=5e1fe578c090c630ab60cc5a http://www.bootmod3.net/log?id=5e1fe5d5c090c630ab60cc5c |
01-16-2020, 07:11 AM | #58 |
Rep 1,499
I took another log this morning. The boost by gear reduction has proven to resolve the HPFP crash in my case. I do see a dip in rail pressure vs target, but not enough to crash. The main issue for me right now is overboosting causing throttle closure. I've sent logs to PTF for resolution.
http://www.bootmod3.net/log?id=5e2054e9ae729b183f09966a
01-16-2020, 07:14 AM | #59 | |
Rep 1,499
Yeah you are overboosting pretty significantly. over 20PSI with 17.2 PSI target.
01-16-2020, 07:23 AM | #60 |
Rep 1,499
I just received a revised test map from Halim. I'll flash and log on my lunch break and report back.
01-16-2020, 07:25 AM | #61 |
Rep 289
01-16-2020, 12:07 PM | #62 |
Rep 1,499
I'm continuing to see overboosting, throttle cuts and drops in rail pressure. I'm not sure how much longer I feel comfortable being the guinea pig. I might go one more revision but that's it. I'm not seeing any real progress in these test maps.
Stage 2 E30 v7.0 Test 2 - No Boost By Gear Reduction http://www.bootmod3.net/log?id=5e209d0cae729b183f09975c Stage 2 E30 v7.0 Test 2 - 10% Boost by Gear Reduction in gears 1-3 http://www.bootmod3.net/log?id=5e209a9bae729b183f099757 http://www.bootmod3.net/log?id=5e209a6aae729b183f099755
01-16-2020, 12:28 PM | #63 | |
Rep 289
01-16-2020, 12:31 PM | #64 |
1296
Rep 3,532
I cant even log anymore. Updated the app and gave me the i dont have an account error, logged out and back in and now i cant use the dashboard to log runs. Complete waste of a day off. Tells me im in offline mode but im not. Ive deleted and reinstalled, no change.
Im losing faith in that he told me my logs looked good at one point, then blamed too much e85 when i pressed it. Despite the obvious pverboost and throttle cuts. Im likely gonna just get a custom map done in the spring. Im able to flash maps so im running stage 2 93 map currently. |
designatedposter175.00 |
01-16-2020, 01:08 PM | #65 | |
Rep 289
n55david1295.50 |
01-17-2020, 10:02 AM | #66 |
1296
Rep 3,532
still no update for me and no replies since i sent screen shots of my issue
