03-24-2021, 07:46 PM | #1 |
Rep 102
Help with coding
Has anyone successfully coded flashing brake lights? I've been struggling with this for a week now. Followed steps from thic30 on YouTube but still won't flash for me. Wondering if our f34 are different than f30.
2015 328i xDrive GT
03-24-2021, 08:42 PM | #2 | |
Rep 121
first it will turn red as normal breaking then will start flashing. In bimmercode you can set force used for flashing brake lights.
Mess with the Best - Die like the Rest
roachesneverdie0.00 |
03-24-2021, 09:58 PM | #3 |
Rep 16,082
The only way to know if they're flashing is if you're following yourself watching your brake lights while driving at a high enough speed to allow you to apply enough braking force to get them to flash.
03-24-2021, 10:12 PM | #4 | ||
Rep 102
2015 328i xDrive GT
03-25-2021, 10:52 AM | #6 |
Rep 102
Been reading every article I can find on this and noticed that in 1 post someone deactivated it and then deactivated it again and it worked for him. Will try that next.
2015 328i xDrive GT
03-25-2021, 10:53 AM | #7 |
Rep 102
I know this is an option on my car because it was an option to code in BimmerCode. What I mean is - if it wasn't an option, it would not show up.
2015 328i xDrive GT
03-26-2021, 12:43 AM | #8 |
Rep 121
Try Front Electronic Module -> Brake force display: Set to Flashing. Then in Activation Speed set to 5k/h and Brake Force Display Activation Brake Force: Weak
After coding go to Rear Electronic Module set your Brake force display flashing frequency 3 or 5. After that select Expert (still in REM) and check Lce LampMapping1 if mapping_breakforce_L_output is set to bl_l and same for mapping_breakforce_R_output is set to bl_r PS: It’s called brake FORCE display, not brake SOFT display. Unless you use it for some video not sure why someone would code it, buy hey each to their own
03-26-2021, 10:42 AM | #9 |
Rep 266
I tried it awhile ago and never got it to work on my f34. Did all the coding via bimmercode. All other coding is successful with using bimmercode but brake force display 😂
Oh well not a big deal to me. Hope someone can figure it out one day lol |
03-26-2021, 01:06 PM | #10 |
Rep 102
Yes BimmerCode has it as brakeforced. I used BimmerCode to deactivate it and then reactivated again yesterday. Did several runs with a friend watching and it only flashed 1 time out of 5 runs. Weird. Not a critical coding item so I hereby give up. Lol
