BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Rain light sensor retrofit coding HELP!
      03-24-2018, 09:54 AM   #1
Dfahmy
Egypt
140
Drives: F30 335i PWG
2013 BMW 335i  [0.00]
Exclamation Rain light sensor retrofit coding HELP!
Hello everyone, I have an issue trying to code my retrofitted rain light sensor and I was wondering if anyone can help. I am supposed to change
FEM: 3060 FLC_AKTIV from nicht_aktiv --> aktiv, but I do not have that option in the drop down menu on esys. I tried changing the werte value to 01 instead of 00 and it still wont work.
Any ideas? the rest of the codes work fine, and the sensor is installed correctly as its seen in ISTA/D
      03-27-2018, 10:19 AM   #2
Dfahmy
Egypt
140
any ideas??
      03-30-2018, 06:57 AM   #3
THE_AVIATOR
THE_AVIATOR's Avatar
Egypt
Drives: F30 320i LCI M-Sport
I'm facing the same problem with a car that I had retrofitted before but went to replace something and Bavarian Auto updated it. Also, tried to VO code it, but didn't work. I'm trying different things, the problem is it's a friend's car and I don't have much access on it to keep trying.
      03-31-2018, 10:52 PM   #4
Dfahmy
Egypt
140
What's the VO code for the rls I'll try doing that.
2013 335i BSM ~ Stage 3 turbo, forged internals and more check out my build thread https://f30.bimmerpost.com/forums/sh...7#post23789807
      04-01-2018, 06:32 AM   #5
atzebmw
Drives: Tesla Model 3
The VO code for the rain light sensor is the 521.
The manual codings are:
FEM_01 > LceConfiguration 3064 > LCE_BEL_LIN_VAR = nicht_aktiv [Default]
FEM_01 > LceMaster 3060 > FLA_AKTIVIERUNG = nicht_aktiv [Default]
FEM_01 > LceMaster 3060 > FLC_AKTIV = aktiv
FEM_01 > LceMaster 3060 > LDS_MIT_STELLUNG_A = aktiv
FEM_01 > PfLinSteeringWheel 3140 > LIN_VARIANTE_SPARE_SZL = szl_aic_4Band
FEM_01 > PfLinSteeringWheel 3140 > LIN_VARIANTE_SZL = szl_aic
FEM_01 > PfRainLightSensor 3130 > REGENSENSOR_INTERVALL = nicht_aktiv [Default]
FEM_01 > PfRainLightSensor 3130 > RLS_LIN_VAR = RLS
FEM_01 > WipeWashMaster 3080 > WW_REGENSENSOR = RLS_Verbaut
KOMBI L7_MID > ERM_Konfiguration 3004 > BRIG_SURR_APPL = aktiv
KOMBI L7_MID > ERM_Konfiguration 3004 > BRIG_SURR_TIMEOUT = aktiv
KOMBI L7_MID > ERM_Konfiguration 3004 > STAT_FAHRLICHT_TIMEOUT = aktiv
KOMBI L7_MID > KI_Dimmung 3007 > DIM_RLS_NACHT_AUS = mit_rls
KOMBI L7_MID > KI_Dimmung 3007 > DIM_RLS_NACHT_EIN = mit_rls
      11-06-2019, 06:47 PM   #6
Toad535
Drives: F10 535 MSport
Interested in how you did this? I'm trying to figure the same out for a heated steering wheel (VO 248) in an F25 LCI. Don't have eSYS handy, so wondering if you had another way to figure this out...
      06-13-2021, 05:06 AM   #7
spazolla
Drives: BMW F30
Thank you but how to fix FLC_AKTIV from nicht_aktiv --> aktiv, but I do not have that option in the drop down menu on esys?
      09-15-2023, 01:05 PM   #8
PedroRios
Drives: Bmw 320i f30
Does anyone know how to disable the angel eyes completely? Even when you have a position light or headlight on? Via bimmercood
automatic lights, coding, rain light sensor, retrofit
