BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > 6WB coding tread
      11-03-2024, 08:32 AM   #661
mihaimetal
Drives: BMW X3
It works!
Wow, thanks man! It works!
I just changed it to
Code:
kein_nbt
with advanced mode in Bimmercode. There's no way it was that simple...
      11-03-2024, 02:36 PM   #662
Siki78
Siki78's Avatar
181
Drives: F30,G30
Check this all settings and see if help you
;DKMOBI
NAVICOLOR_TABLE=farbwelt_id5
;HU_NBT2
KOMBI_CIC=kombi_high
KOMBI_AUFLOESUNG=aktiv
MFID_KOMBI_VARIANT=nicht_aktiv
HUD_AUFLOESUNG=aufloesung_1
HUD_KOMPRIMIERUNG_ART=rle_1
NAVI_HUD_AVAILABLE=aktiv
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      11-08-2024, 12:13 PM   #663
mihaimetal
Drives: BMW X3
If I wasn't clear it worked with kein_nbt to have the navigation directions shown.
But sometimes the language switches automatically to the cluster's default language and I have to go into HU normal settings to set it back to English UK.
      12-02-2024, 03:34 PM   #664
muzicantini
Drives: BMW F10 535i
Hello. I’d like to ask is there something which could make the oil gauge on the 6wb on my F10 to stay precisely at 12 o’clock when at operating temp? Because when I compare the oil temp reading from the hidden menu the oil gauge correctly starts to move at 50C and but when the oil reading is at 90ishC the gauge is already past 12 o’clock. I am running a BMS oil cooler valve and I know for a fact that the car is not overheating. Is there a way to code/reset the oil gauge. I was contemplating to run the “system test” from the hidden menu but I am afraid since the cluster is not original something might go wrong.
