05-07-2017, 03:53 AM | #1 |
Rep 7
Drives: 2013 bmw 328i mineral grey
Key fob buttons not working but comfort access working just fine!!!
Hi guys so I mostly use comfort access to lock/unlock my car but today I tried using the key fob to do both and the buttons did not work also the trunk button did not work, I was wondering if anyone has had any similar problem or if there is a fix to this, thanks in advance
05-07-2017, 07:08 AM | #2 | |
Rep 370
Drives: 2013 AW 335i
2013 Alpine White 335i -M Sport/// Akrapovic Catback Exhaust/// KW Street Comfort Coilovers/// BMS intake/// JB4/// ER front mount intercooler/// ER Charge pipe/// ER catless downpipe/// 18" Apex Arc-8 in Anthracite/// Michelin Pilot Super Sports
Billfitz8243.00 |
03-26-2019, 11:57 PM | #3 |
Rep 4
Resurrecting this as I am having the exact same issue. Brand new battery, tested @ 3v. Comfort access works but none of the keyfob buttons work.
Did you get this resolved OP? |
03-27-2019, 10:59 AM | #4 |
Rep 1,452
03-27-2019, 05:57 PM | #6 |
BMW CCA #257
75
Rep 190
Try cleaning the battery contact in the key fob. I changed the batteries in mine and it didn't work until I cleaned the contact with alcohol or another good electrical cleaner.
2014 F31 328 xDrive Touring
2020 G20 330 xDrive Sedan 2023 G01 X3 xDrive BMW CCA # 257 |
05-08-2019, 09:20 AM | #7 |
Rep 43
Any additional updates on this issue?
I am having the same problem. Dealer changed battery and was not able to make it work. Stated I need a new Key Fob so I hope for an updated solution to this. My second key fob works just fine. |
11-21-2021, 10:01 AM | #9 | |
Rep 277
If you aint first, your last.
12-04-2021, 10:08 AM | #10 | |
Rep 4
ideas? |
12-04-2021, 11:57 AM | #11 |
Rep 1,386
12-04-2021, 05:46 PM | #12 |
Rep 4
Ironically, both key fabs starting working this afternoon (about 6 hours later). It has to be a software issue.
