10-28-2020, 12:59 PM | #177 |
BMW CCA Member
488
Rep 808
blumagic - thank you for replying and taking the time to post that video clip! That looks like a fairly easy fix. I'll give it a look when I pull my wheel off.
There's only so many places that noise/rattle/etc. can travel off the wheel to the body of the car: 1. Upper control arm 2. Lower control arm 3. Shock tower 4. Steering rack 5. Sway bar/end links At this point I pulled the camber plates off and am running the stock mounts. The rattle is still there but about 95% quieter. So it's wheel/hub related. The only thing not stock is my Turner Monoballs which I plan on pulling out and replacing with new OEM control arms. Given the nature of the control arm/thrust arm (incoming road impacts) and the monoball (can translate harsh road surfaces)... I suspect my swap back to the stock arms will elimnate the rattle with the stock pieces and will luck, produce no rattle once I get the street camber plates back on. Caveat, I'm running a 19 x 9 forged rim with a 235/40 Hankook Tire. The tire is about as stiff as bricks, so I'm getting more ride noise/harshness than say those running 18s or softer compound tires. |
10-28-2020, 02:31 PM | #178 |
Rep 272
Hope you figure it out, mine is pretty quiet now that I have bent back the bracket to clear.
I’m 225/40 on 19x9 with leaking front control arms lol |
02-02-2021, 02:25 AM | #180 | |
Rep 15
The 60mm adapter should normally be included with the suspension. So make sure you not pay twice for this. Just send me a message if you need some help. |
MacklinUSOB518.00 |
02-02-2021, 09:23 AM | #181 | |
Rep 3,189
02-02-2021, 09:43 AM | #182 | |
Rep 15
422 Euro or 487 USD ex.tax. direcly from us. Maybe you seen some other prices on our dealers webpages? P.s I don´t want to add links to our page with respect for forum rules. |
02-02-2021, 12:38 PM | #183 | |
Rep 272
But when you go to checkout via PayPal it is only charging €3996 SEK to usd. €422 = $507usd $3996SEK = $474.57usd If they just move to checkout they’ll get the proper price |
02-02-2021, 01:15 PM | #184 |
Rep 1,004
for me it shows in euros :
Plates 422.78 2 Adapter for 60mm 42.32 2 Adapter for 60mm to 65mm 28.44 23.28 shipping total 516 euro which equates to $620. and the f30 plates now say back order as of this morning. |
02-02-2021, 01:23 PM | #185 | ||
Rep 3,540
Also, for 60 to 65mm adapters just get these (~$21 shipped for two). I've used plenty of them.
02-02-2021, 03:01 PM | #186 |
Cheapskate
4450
Rep 4,995
Why do you need adapters? They should fit any stock/aftermarket spring that fits our oem strut mounts.
02-02-2021, 08:42 PM | #187 |
Rep 1,004
im going to email millway tonight. i thought i needed the adapters for ohlins coilovers.
and farkle, i've used the diftech adapters before, i can get them for $15 on ebay. |
02-02-2021, 09:05 PM | #189 |
Rep 1,004
04-14-2021, 10:10 AM | #190 | |
Rep 3,540
If you're wondering how to replace the monoballs in your Millway camber plates I made the video below on the process.
kern4174449.50 |
05-20-2021, 05:04 PM | #191 |
Rep 1,372
Just curious, when you disconnected the end link, the 5 strut tower + 1 strut brace bolts, did the strut drop far enough to the point you could have removed the top hat had the strut retaining nut been removed? In other words, if you had jacked up the strut an inch or two, then removed the strut nut from strut threaded rod, lowered the jack (slowly), would it be enough for the threaded rod to pass through the top hat, allowing you to free just the hat from the strut tower? I have an xDrive so I don't have the luxury of being able to tip out the strut.
05-21-2021, 08:44 AM | #192 | |
Cheapskate
4450
Rep 4,995
05-21-2021, 09:01 AM | #193 | |
Rep 3,952
I think the greater challenge is the re-install and how you're lining up the spring. |
05-21-2021, 09:31 AM | #194 | |
Rep 1,372
I saw this guy's video where he swaps out the top hat of his F82 without removing the strut. My complication is that I have xDrive so that might make things a bit trickier. Jump to 6:20 https://www.youtube.com/watch?v=MUguUIoqpVQ I wondering if this guy's idea is just luck or would it work for other Fx platforms, even xDrive??
05-21-2021, 02:25 PM | #195 |
Rep 15
Never remove the strut with the topmounts left in the strut tower. I will only work with very short after market springs. With oe spring it is dangerous and you will not be able to remount the parts that way.
MacklinUSOB518.00 |
05-21-2021, 05:40 PM | #196 |
Rep 1,372
Thanks Samuel. Looks like the longer road of removing the strut.
05-22-2021, 08:07 AM | #197 |
Rep 15
I have done this at least 50-times so here the best way I found out. Every time I’m tempted to try to get the job done quickly by not removing the strut. But trust me. It will take more time with all struggling with springs and spring compression tool in that tight space.
Below written from memory and could be faulty so please follow it with care. And be sure you have a proper spring compressor tool, it is dangerous and always a risk to compress springs. 1. Pop the hood and put masking tape around the +connector above the top mount on the right side. You will be very close to with your tools later so be carful to not make shortcircuit between + and the body. 2. Put the car on jackstands so both front wheels in in the air. If you only raise one side at a time you will have problems with removing the swaybar links. 3. Remove front wheels. 4. Loosen the height sensor that is attached to the left control arm. If you have M2, M3 or M4 continue to point 7 below. 5. Remove enough plastic covers underneath so you can reach the inner control arm bolt. 6. Loosen the nut on the inner control arm bolt. Just enough so there is no preload on the bolt. Do not remove completely. 7. Remove the swaybar link in the strut (leave it connected to the swaybar.) 8. Put a wood piece on your jack and pump up on the front disc just until it touch. 9. Loosen the brake hose and ABS sensor cable from the sheet metal. Only one point of each hose/cable needs to be removed. Just so the canle will be longer. Take photos before this so you can remember how the cables goes around the strut. 10. Remove the strut bolt completely. 11. Put some tool in the gap where the strut is clamped so you can expand the gap. 12. Lower the jack slowly and let the strut slide out from the carrier. Continue until it fall out completely. Push the strut towards the engine and make sure the carrier will not till too much so it will stretch the brake hose. 13. Hold the strut and remove the top mount from above. 3 or 5 bolts. (Not the damper nut) 14. Put the complete strut in a vice and clamp in the swaybar link bracket. To be continued.... |
05-25-2021, 12:16 PM | #198 |
Rep 1,372
Hi Samuel
This step 6. Loosen the nut on the inner control arm bolt. Just enough so there is no preload on the bolt. Do not remove completely. Why do you take this step? Thanks
