11-28-2018, 11:26 AM | #23 | |
Rep 338
That one seems very difficult to remove. And for the trims on the tailgate, does it just pop right out? coz I dont see any screws thx |
08-05-2019, 09:41 AM | #24 |
Rep 218
I got a used pair of LCI rears recently, hoping to fit them sooner rather than later. However, the wires attached to the lighting units already were all cut. I was hoping if anyone could shed some light as to if I need new wires? Or if this is fixed up using the new LCI harness?
I have attached some pics of the wiring I am talking about. Thanks in advance. Last edited by otee10; 08-05-2019 at 09:42 AM.. Reason: pics added |
08-05-2019, 04:54 PM | #26 | |
Rep 3,863
You will need LCI wire harnes from Dealers which will have all plugs etc with it so you can remove these wires with plugs . You will need coding for taillights to work , outside lights are plug and play |
08-06-2019, 12:19 AM | #27 | ||
Rep 218
08-15-2019, 07:00 AM | #28 |
Zim Zimma
Rep 58
Is it a retrofit fit LCI harness that is required or is it just the same harness that comes in the LCI vehicle?
08-15-2019, 08:03 AM | #30 |
Rep 1,475
10-17-2019, 09:19 AM | #32 |
Rep 272
I'm attempting to install the LCI lights and harness this weekend on a 440i F36.
Any tips on how to cable through to the Rear REM, looks tricky as it goes through into the headlining first.
2017 F36 440 LCI - Smoked Topaz | Auto | M Sport Plus | HUD | ICON Adaptive Headlights
11-12-2019, 02:10 PM | #33 | ||
Rep 15
11-13-2019, 06:01 AM | #36 | |
Rep 272
Found two outer lights on eBay for £80 which were luckily unmarked. Couldn't find a set of inner tailgate lights second hand so bought them direct from BMW Kirkcaldy - £315 for the pair. It's a minefield with breaker yards selling parts that are scratched, chipped, wiring cut and mounting points damaged.
UKF302524.00 |
01-18-2020, 05:24 AM | #37 | |
Rep 11
01-18-2020, 08:49 AM | #38 | ||
Rep 413
https://www.newtis.info/tisv2/a/en/f...nel/1VnXmbW7ir https://www.newtis.info/tisv2/a/en/f...nel/1VnXG4js4z
2017 440i F36 - Drexler LSD - B58TU HPFP - MHD Stage 2 - xHP - 200 Cell DP - MPE
01-18-2020, 09:25 AM | #39 |
Rep 8,780
It's strange, but whenever I see a F32/6 now I prefer the pre-LCI lights to the LCI version. To me the rear looks purer with the original lights, the LCI adds unneeded busyness to the corners.
Drives - 2020 LR Discovery HSE-L Previous - 2019 LR Discovery HSE-L // 2016 F36 440i // 2009 E90 320D SE |
01-18-2020, 02:32 PM | #40 | |
Rep 11
01-18-2020, 03:19 PM | #41 | |
Rep 272
See links below. https://www.newtis.info/tisv2/a/en/f...ing/1VnY22BSj7 https://www.newtis.info/tisv2/a/en/f...ate/1VnXpvr7YF
01-19-2020, 02:24 AM | #42 | |
Rep 11
01-19-2020, 02:25 AM | #43 | |
Rep 11
01-19-2020, 02:41 AM | #44 |
Rep 272
I never had any issues removing that screw. It might have been over tightened in the past. Can you not use pliers to pull and turn at the same time so it grips the thread and starts backing out.
