05-23-2018, 04:02 AM | #1 |
Rep 1,846
Goodyear runflats to non runflats
Can anyone confirm correct tyre sizes on my 435d xdrive to the move from GY Eagle f1 runflats to GY Eagle f1 non runflats as I believe there's an issue with size and they are different sizes on offer compared to runflats ? I've got 19s. Thanks
05-23-2018, 04:34 AM | #2 |
Rep 1,373
last time i did this i ruined the ride of the car.
Squishy and vague and lacked turn in feel. Modern run flats are much better but you need a digital tire pressure gauge to get them perfect |
05-23-2018, 04:50 AM | #3 | |
Rep 3,055
There are others you can get in the standard sizes in non run flat if you want to keep the same diameters. |
05-23-2018, 05:16 AM | #4 | |
Rep 784
Drives: 2018 F80 M3 CP YMB
05-23-2018, 05:30 AM | #5 |
Rep 1,846
Cheers guys regarding sizes I believe there was a calculator to check the difference?, anyone any idea where that is and what values are of concern?
05-23-2018, 05:45 AM | #6 | |
Rep 784
The overall diameter front compared to rear is the critical thing with xDrive - make sure it is within the same tolerance as the oem tyres - 255x35x19 & 225x40x19. But in doing so accept any tyre not star rated is a risk however minor. In short, unless you know what you are doing keep with oem sizes as going up sizes could start to have clearance impacts and going down will just not look good plus your speedo will be out and I don't know if you will affect DSC etc.... Personally I really don't see the point of changing from runflats as modern ones are fine, unless you have changed your springs and now the ride is too firm - as you will know xDrive as standard is running on SE suspension so putting softer tyres on may not be the ride you want... If you must shift from runflats go to another tyre maker that does the correct sizes... |
05-23-2018, 06:06 AM | #7 |
Rep 1,846
Thanks the reason is because I am sick of buying new tyres then hitting a hole or something and then getting an egg in the sidewall that is terminal.
05-23-2018, 06:29 AM | #8 | |
Rep 2,444
Drives: 2018 630iGT sport
FWIW, I agree the modern Goodyear runflats are much better than those Bridgestones fitted on the E9x, but still they are very firm. I've never regretted putting normal tyres on instead of wallet-ruining run-flats, ride is much improved IMO; nothing wrong with a bit of squish either, as it stops the car skittering around on bumpy surfaces when pushing on a bit. |
05-23-2018, 11:47 AM | #9 |
Rep 3,055
05-23-2018, 01:50 PM | #11 |
Rep 131
I believe you can get the non runflat asymmetric 3 in 225/40/19 now :
https://www.tyreleader.co.uk/car-tyr...r19-93y-789447 Although I am likely to go 245/35/19 next. |
05-23-2018, 02:49 PM | #12 | |
Rep 1,846
05-23-2018, 02:52 PM | #13 | ||
Rep 131
05-23-2018, 03:16 PM | #14 |
Rep 548
A few seconds to check the post is all it needs, so that it makes sense & people can add something useful to the thread, which is for your benefit anyway …. okay rant over …. is it runflats or non runflats please?
Current: 2017 F31 335d M Sport - Estoril Blue, ACS Sports Suspension (Springs & Dampers), Black Grill, HK Sound & some other bits'n'pieces
Gone: 2015 F31 320d M Sport Xdrive Auto |
05-23-2018, 03:41 PM | #15 | |
Rep 1,846
I've stated I want to swap to non runflats in the first post, and commented that the link the above guy kindly posted is most likely a runflat tyre thus description is incorrect. |
05-23-2018, 03:43 PM | #16 |
Rep 1,846
05-23-2018, 04:01 PM | #17 | |
Rep 32,881
Yes I’ve got 245/35 19’s on my fronts, no problems so far and they give the front end more grip. |
05-23-2018, 04:09 PM | #18 |
Rep 548
Sorry, I just couldn't understand the grammar …. been a long day!
05-23-2018, 04:39 PM | #19 |
Rep 1,846
05-23-2018, 04:47 PM | #20 | |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
05-24-2018, 07:13 PM | #21 |
Rep 3
Ok, good to read this discussion.
Going to change all tyres on my 335D xdrive getting close to limit, had not thought about non runflats. Yes handling is poor I had assumed it was the spring rates. If I go non runflats probably better to get a spare wheel, tyre, a jack and wheel spider. Is there a common suggested non runflat. Thanks Last edited by CRT; 05-24-2018 at 07:14 PM.. Reason: spelling |
07-30-2018, 04:25 PM | #22 |
Rep 1,338
Drives: 2014 F30 320D X-Drive
i was looking at getting some prices for Goodyear Eagle 225/40 R19 NON-RUN FLAT but indeed cannot find any, i am sure last year i looked at there were, or am i dreaming? How can such large manufacture not have these sizes in NON-RUN FLAT ? I just believe it
Current Ride: 2020 G20 M340i in Metallic Black Sapphire with Individual Full Merino Ivory White and Piano Black Trim Previous Ride1: 2014 F30 M Sport 320D X-Drive Auto, Dakota Beige Leather, M Sport Brakes, Adaptive M Suspension, Paddle Shifters, 19" 403 Alloys, Folding Mirrors, Pro Sat Nav & Harman Kardon Surround Sound. Previous Ride2: 2004 E46 M Sport 320CI Auto, Montana Beige Leather & 18" 135M Alloys.
