BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 2012 328i . hesitation at low rpm s
      04-06-2017, 08:14 PM   #1
maurim3
Drives: E90 335i 02 M3
Ive got the worst of luck with this car. It only has like 19.000 miles but it has all kids of problems.
this is my problem
you start to accelerate on low rpm on 1st or 2nd or any gear (like 1500-2000) and you fell like the car is hesitating or like its missing a beat. If you go beyond 3.000 rpms everything is normal. Also I you WOT the car is perfect. Another thing im feeling now is when Im stopped in Drive. And when I release the brake to accelerate I feel a small shake. CEL has not been triggered. I scanned the car and there was NO error stored. I went ahead and changed the 4 spark plugs with gem and the problem remained exactly the same. I also had 4 new injectors and went ahead a changed them and coded them. But the problem persists.
My next guess is changing the coils.
Any ideas.
Ps dealer will not take my car cause its a direct import.
      04-07-2017, 08:52 AM   #2
jparnes1
jparnes1's Avatar
Drives: 2016 340i, 2012 Z4 35i
The shake when releasing the brake pedal may be your start-stop feature turning the engine on. Is start-stop active when you drive?
Are you driving AT or MT? If AT, try accelerating in manual mode and see if you have the same hesitation. I don't mean just throwing the shift lever over to the left. You have to also push it up or down.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA.
      04-07-2017, 11:06 AM   #3
Patrick852
Hong Kong
66
Drives: 15 320iED, 18 X2 sDrive20i MSX
Have you always run the car in low rpm? My dad's 2013 328i has the same problem due to engine speed too slow.
      04-07-2017, 01:03 PM   #4
uncleruckus
no relation
130
Drives: F30 328i xDrive
Does this only happen during cold starts, or can you reproduce this issue consistently ?
      04-07-2017, 02:28 PM   #5
maurim3
Im not using the start stop. It desactivated. Its an automatic. Ive tested in manual mode also. Does the same thing. Im changing the coils today with my 228i and see what happens.
      04-07-2017, 02:31 PM   #6
maurim3
Yes . I always run it in low rpms. Shifts at around 2500 automatically. It has started with this issue just a few weeks ago. And I have the car since 2012 and never noticed it before.
      04-07-2017, 02:32 PM   #7
maurim3
Its going on constantly. Feels like a misfire . But there are no codes stored.
      04-07-2017, 04:12 PM   #8
bimmer456
Drives: 340i
I notice it sometimes after cold starting. It seems the torque converter locks up a little early, feels like when driving stick and you engage the clutch too soon. Happens less in sports mode. However, it seems like the poster is saying this happens all the time.
      04-07-2017, 04:58 PM   #9
uncleruckus
no relation
130
I was actually thinking along the same lines.... I know for my car, the shifting is a bit rough on cold starts. However, it goes away as soon as car is warm, and I cannot consistently produce it, so I don't think it's the same issue.
      04-07-2017, 05:42 PM   #10
Aero7000
Aero7000's Avatar
246
Drives: M340i DravitGrau / Cognac
this is my problem
It's just the car telling you it does not like low RPM's, just drive it the way BMW suppose to be driven, keeping revs high, it completely transforms the driving experience.
I learned this with my first bimmer 1988 318i, drove it gently not even knowing what the car was about, until one day I was told to wake up the beast....
      04-07-2017, 07:20 PM   #11
STR8-6IX
Drives: RWD 528i N52
this is a very well known issue with BMW's and has been thoroughly discussed just about everywhere you look.
you need an ECU tune to code this out.
      04-11-2017, 09:08 AM   #12
maurim3
Really havent found one with the same problem. And they dont want to do a software update if theres no check engine light on .
      04-11-2017, 10:48 AM   #13
STR8-6IX
you've driven others that do not have the lag?
does your engine burn oil?
      04-17-2017, 11:23 AM   #14
maurim3
Its not lag. Its missing while climbing rpms. 2000 to 3000 rpms 1/4 throttle.
at wot the car goes perfectly
      04-17-2017, 11:33 AM   #15
STR8-6IX
scan car for misfire. replace ignition coil on misfiring cylinder. replace all 6 spark plugs.
update.. you have no errors? strange..
      04-17-2017, 11:34 AM   #16
IndotagSwizz
IndotagSwizz's Avatar
525
Drives: F30 320i
are you using premium gas?
      05-18-2017, 05:18 PM   #17
maurim3
Yes.
      05-18-2017, 05:21 PM   #18
maurim3
this is a n20 so 4 cil. Changed the 4 spark plugs and 4 coils.
No misfire codes !!
Im starting to lean on a motor mount or some kind of driveline vibration. Its all too weird. Motor shakes a bit more that i could call normal .
      05-24-2017, 09:04 AM   #19
maurim3
ok, so checked the transmission fluid level on the car, thinking it might have a low level, and to my surprise the fluid was mixed with water. So that might be the problem. I will change fluid, filter/pan and transmission cooler, and report back.
      05-24-2017, 11:04 AM   #20
Krasna
Drives: BMW 640i
I had a 2012 328i and it was always rough at lower RPMs unless I drove in Sport mode. Had a 328i loaner and it was the same; the 4-banger paired with 8-speed tranny seemed to struggle under about 2200-2400 RPMs
      05-24-2017, 11:28 AM   #21
Pavement Molestor
Pavement Molestor's Avatar
Drives: 2011 528i N52 RWD
No misfire codes !!
your mileage is way too low to be having issues like that.
turbo lag.
      10-03-2017, 04:54 PM   #22
cristianro
Drives: BMW 328XI F30, N20
i have the same issue with my 2014 F30 N20 . I found that air filter enclosure wasnt properly alligned and closed even if the 4 clips were closed. Car runs better and the hesitation is very minimal . I am about the order a K&N air filter to improve air flow
