02-03-2017, 07:48 PM | #1 |
Rep 488
LED Fogs flicker after about a minute with turn signal on
So I got the LED fogs awhile back, and coded them in so that they run as normal without flickering (tested by leaving them on for 10-15 minutes parked in the driveway). I noticed today, that when the headlights are on and I use my turn signal, the fog light illuminates as expected but then starts rapidly flickering after about a minute. It also does this in reverse, but with both lamps. As soon as the signal stops or I go into drive, normal usage of both resumes.
What coding value did I miss? I read over several guides and hit all the values I've been able to find, with no luck. |
