01-04-2020, 03:34 AM | #45 | |
Rep 298
01-04-2020, 06:35 AM | #46 | |
I can haz cheezburger?
6803
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
01-04-2020, 07:06 AM | #47 |
Rep 2,672
Would the engine run if it looked like that? Mine still runs...
01-04-2020, 08:44 AM | #48 |
Rep 80
The busted piston damage looks exactly line LSPI damage and the common cause has been determined by oil not formulated for LSPI. There are white papers on the subject. Amsoil has reformulated all of their oils to eliminate LSPI. See page2 of the attached document. I don't know if the Amsoil European have been updated because they are constrained by BMWs specs.
01-04-2020, 09:03 AM | #49 |
Rep 2,672
Funny that's the oil my younger cousin recommends - he a mechanic in South Carolina.
01-04-2020, 10:31 AM | #50 |
Rep 80
LSPI didn't exist before the prevalent use of turbo chargers where the turbo develops high boost a low rpm. BMW automatics hold the engine in high gears at high power levels and low rpm and the tinest bit of the wrong oil in the first ring groove gets so hot that it ignites on it's own. No gasoline needed. Blown pistons are the result.
I try to tell folks that oil is not all the same, you can lead a horse to water but you can't make him drink. |
01-04-2020, 11:12 AM | #52 |
Rep 2,672
The muffler shop actually asked me if I was sure the oil was changed (I change mine every 5k miles)( Valvoline).
Meaning from the way the car was idling and since the new plugs, coils did nothing - they thought it sounded like an oil issue. Oil levels were always full though. |
01-04-2020, 11:24 AM | #53 | |
Rep 627
All this isn’t just relegated to LSPI and the N20. Look at all the problems people had with tuned WRX/STIs. Most modern turbo engines coming out for these cars are engineered at the ragged edge to achieve high hp and good mpg and reliability at their respective hp. It goes without saying that tuning will eat away at that reliability and the OP just learned this the hard way. |
01-04-2020, 01:45 PM | #54 |
Rep 414
A lot of good info on this thread. Seems like a lot of concerns were raised back in 2013 when the engine was first introduced and over time not talked about as much as the new tunes and piggybacks came out. I’ll be moving on from this engine a lot earlier than I anticipated.
01-04-2020, 01:59 PM | #55 |
Rep 2,672
I had a car with a rebuilt transmission once - when I sold it the buyer was happy to have the new trans.
But with BMW - when I trade it in - will the engine with 35k miles decrease the value if trade in is close to $11k? Or will it not matter? Because once its fixed I'm certainly not keeping it. Since I won't be tuning it again. |
01-04-2020, 02:14 PM | #56 | |
6803
Rep 3,677
01-05-2020, 08:48 AM | #57 | |
Rep 80
https://www.oronite.com/about/news/l...-ignition.aspx |
01-05-2020, 11:22 AM | #58 |
Rep 2,672
I'd like to read that as well but link didn't work for me? Maybe because I'm on my phone.
01-05-2020, 12:04 PM | #59 |
Rep 788
Hopefully BMW will provide financial assistance since the motor is under 50,000 miles. In my opinion, being out of warranty is irrelevant. They can't build an engine that makes it to 50,000 miles, then they need to help.
01-05-2020, 12:15 PM | #60 |
Rep 2,672
Regardless of stage 2 tune? Would be great if they did. Who should I call? Bmw NA?
01-05-2020, 12:30 PM | #61 |
Rep 268
I have blown engines in two BMW's and one Subaru. I would recommend trading it in and moving on unless you are a mechanic or really have one you can trust. I always ran into extra costs as once there they look around they recommend more parts to change and its a slippery slope. I was never fully satisfied with the car after dropping in a new engine. It also takes longer than expected and you really don't know the quality of your new engine. It also shows up on your carfax and resale value is affected. They assume you beat on it.
01-05-2020, 12:31 PM | #62 | |
Rep 5,457
Drives: F30
flyt1006.00 |
01-05-2020, 12:44 PM | #63 |
Rep 5,457
Drives: F30
FWIW... Bootmod3 Stage 1 / 91 seems to work real well for my FBO setup. 86k and running like a top. Oil changed every 5k, only Shell V-Power (or worst case, Top Tier alternative) and a catch can. Not sure if any of this matters but figured Id mention it...
Honest opinion, the BM3 Stage 2 and Trans tune is a bit scary for me since this is my DD. Probably just stay where Im at. Runs strong, pulls pretty hard and has been very reliable so far. Im good. There's always faster. I do plan to get a BMW straight 6 at some point but the time is not now. |
01-05-2020, 06:07 PM | #65 |
Rep 3,748
floridaorange10204.00 |
01-05-2020, 08:15 PM | #66 | ||
Rep 2,672
